Cam Tabs
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jonross227, Nov 17, 2019.
  1. Nov 17, 2019 at 1:24 PM
    Jonross227
    Jonross227 [OP] New Member
    When I had my truck aligned after dropping from a 3" level kit with pucks to 6612's they told me I had a bent cam tab and couldn't get camber in to spec. Left it set at -.5 degrees.
    Been a few weeks so I figured the coils had settled all they're gonna settle, went to bend the tab back to hopefully get it aligned and of course it broke off.
    Whats the best option to fix it? The TC gussets? I've been fighting shit alignments for months, destroyed a set of tires, and I'm about to lose my mind.
    I'm just gonna take it it and have them do a toe and go on it for now but I've got to get this damn thing aligned before I buy new tires
  2. Apr 26, 2020 at 2:27 PM
    codename607
    codename607 New Member
    Chicago
    2024 Tundra
    Hey OP, any updates on this? I just realized that one of mine is bent and I need to figure out a solution. I haven't tried to bend it back up but I'm sure it will break off....that's just my luck.
    94311001_3120756644641654_49708106451852_57d9233f313aa1ed5c0c302a09ea616efeeb0bf4.jpg
    92457851_3120756654641653_72367449986731_e228814c17c9e5f1164904cde1ea0df087aaa229.jpg
  3. Apr 26, 2020 at 2:54 PM
    TXTundra2722
    2015 Black Tundra
  4. Apr 26, 2020 at 2:55 PM
    TXTundra2722
    2015 Black Tundra
    The OP hasn't been on here since January.... so probably not getting a response from him
    codename607 likes this.
  5. Apr 26, 2020 at 2:55 PM
    TXTundra2722
    2015 Black Tundra
  6. Apr 26, 2020 at 4:07 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You can get Total Chaos cam tab gussets. Or if you don’t want to spend the money and time, I honestly think you can just weld on a little bar in place of the bent tab. Either way it needs to be fixed.
  7. Apr 26, 2020 at 4:13 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Same thing happened to me.
    https://www.tundras.com/threads/suspension-slip.63836/
    I took it to a small shop and had it welded, then back to the alignment shop. All good
    Just make sure the shop uses a "jump box" on the battery....it makes it safe to weld on the frame, or bad things can happen. Exhaust shops have them
  8. Apr 26, 2020 at 4:16 PM
    codename607
    Chicago
    2024 Tundra
    Thanks guys for the feedback/info. I'm dropping my truck off tomorrow at a local off road shop, they are going to install some UCAs. I'll also ask them to take a look at this as well. I'll ask them to bend it back and if that doesn't work I'll see if they can weld it back.
    I'm pretty sure this was caused by a local Toyota shop....smh.
  9. Apr 26, 2020 at 4:19 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Even if they can bend it back without it breaking, I would still weld on a little backing. The metal is already fatigued and it’ll just bend again.
    EDDO likes this.
  10. Apr 26, 2020 at 4:22 PM
    codename607
    Chicago
    2024 Tundra
    Okay, that's a good point. I'll ask the shop if they can do this.
    joonbug[QUOTED] likes this.
  11. Feb 26, 2021 at 6:43 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    This just happened to me today :( time to go with the total chaos kit
  12. Feb 26, 2021 at 8:31 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    You have a 2021. Make Toyota fix it. That’s unacceptable on a brand new truck!
    TILLY likes this.
  13. Feb 26, 2021 at 8:45 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Bring it back to Toyota, should be totally fixed under warranty.
  14. Feb 27, 2021 at 6:25 AM
    Sitting Sideways
    Beaverton, Oregon
    I am getting push back due to the Icon suspension. Plus I have no confidence that this won’t just happen again with the factory p.o.s. piece of metal.
  15. Feb 27, 2021 at 8:29 AM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    How is having a suspension and the tabs getting bent/broke off a denial for fix? Lifted or not they have a potential of getting mangled when getting a alignment. Unless I’m missing something here, the dealer is lazy unless they deem it’s a wearable part per Toyota????
  16. Feb 27, 2021 at 8:30 AM
    The Patriot 1776
    '16 TSS CM 4x4
    Push back harder. That’s BS. Get them to fix them then weld a bead to the backside of the tabs and never worry about it again.
  17. Feb 27, 2021 at 8:37 AM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    My local Toyota dealership installs lifts.. warranty by demand
  18. Mar 1, 2021 at 1:26 PM
    Sitting Sideways
    Beaverton, Oregon
    You're both right, there should be no reason why the suspension would affect the cam tabs shearing off. I have figured out the root of the issue, Les Schwab did not tighten the cam bolt all the way..... when it was last aligned.
    This all happened while I was in Bend for the weekend and when this happened I brought it to a Les Schwab there and they said the bolt was super loose. So the Bend Les Schwab aligned it and tightened the heck out of the bolt so I could drive back home. I just got back from the Les Schwab that didn't tighten the bolt and they are covering it fully. They will work with the shop I trust who will install the Total Chaos Cam gusset kit and Les Schwab will cover the cost. Happy they made it right but more happy this all didn't happen while on the freeway.
  19. Mar 1, 2021 at 3:17 PM
    marsbar
    marsbar New Member
    Bob
    CO
    2018 DC Long Bed SR5 O.R.
    Leer cab high topper, Toytec Aluma 2.0 kit, + 1.5 shackles + deaver 3 leaf add, SPC UCAs, SPC LCA bolt kit, 295 70 18 Revo 3 tires.
    I think many of these problems stem from the different design of the front / back cam bolt parts. They differ in terms of loosening the bolt, or nut.
    I suspect that some techs are cranking on the cam washer before properly loosening the cam nut / bolt.
    Regardless, if you want to improve the odds of success you should make sure all of those bolts and nuts can be broken free before you drop off the car.
    These folks are expected to get a certain number of cars done per hour or day, nobody has time to take care of your baby, you have to prep your baby for the best results. Spend a few hours, do an "at home" alignment, this way you understand the terminology for real, get all the nuts / bolts broken free, then drop off for a more "precise" alignment.
    fwiw, my cam bolts / nuts were also very under torqued after an alignment. Glad I checked!.
  20. Mar 31, 2021 at 3:42 PM
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    Another one down. Got an alignment on the 6th after the lift kit. At some point this happened in the last 600miles. Not sure if it happened day of or happened after. Shop that did the work wants it back to check it out(200 miles away). All highway miles besides my fairly maintained county road....and I was just about to take in on a trip to my folks 4hrs away:mad:
    Sitting Sideways likes this.
  21. Mar 31, 2021 at 4:19 PM
    Sitting Sideways
    Beaverton, Oregon
    I feel your pain! My truck gets the Total Chaos cam gussets on Friday finally. I would check that the bolt is tight, that bolt would have shifted a pretty long way.
  22. Mar 31, 2021 at 4:21 PM
    HidetownRed
    Top O Texas
    Did you continue to drive it. I did my best to see if it was tight then marked it with a paint pen. It drives straight and feels normal.
  23. Mar 31, 2021 at 4:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It happened after. Because the shop didn’t torque them high enough. If it happened before the alignment, they would’ve noticed it while doing the alignment.
  24. Mar 31, 2021 at 4:38 PM
    HidetownRed
    Top O Texas
    Am I correct in thinking the “tabs” are just to aid the cam washer in moving the cam during alignment?
  25. Mar 31, 2021 at 6:00 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The tabs hold the cams in place. As the cam is turned it changes the position of the LCAs. If the tabs are flattened, you can’t get a proper alignment. And the tech would’ve said so. It’s also very unlikely they damaged it during the alignment. Overwhelmingly likely scenario is the tech didn’t torque them tight enough and as the cams moved while you were driving, the tabs got flattened. This happened to another member a few months ago and I believe the shop took responsibility and replaced the tabs with Total Chaos gussetted tabs. Because just bending them back won’t hold anymore. Hopefully your shop will take responsibility and replace it for you.
  26. Mar 31, 2021 at 6:11 PM
    HidetownRed
    Top O Texas
    Thanks for the reply. After some time thinking....this is the likely situation. It’s a very frustrating issue. I live remotely and dont have many options locally. I went to a larger town(where my in laws live) to have leveling kit, tires, and alignment done. To date all my wheels are scared(they agreed to have them refinished), asked for 2” level and got 3” , then today found the alignment issues. Been a fucked up month.....time for another beer.
  27. Mar 31, 2021 at 6:19 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The alignment shop should be responsible for it and they know it. Hopefully they work with you and offer to replace it. It’s likely going to take some work and maybe some welding. If they absolutely refuse to and only offer to bend it back, ask if they can atleast weld on a little piece behind it to reinforce it.
  28. Mar 31, 2021 at 6:32 PM
    HidetownRed
    Top O Texas
    It’s a chain that doesn’t offer that level of work. They wanted to check alignment and tighten is so it won’t move. Per the assistant manager. The main guy is supposed to call me tomorrow. Honestly at this point they will more than likely not touch my truck again. I think they will own up to the repairs as they are large enough to have insurance for it....we will see.
  29. Mar 31, 2021 at 8:56 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Bend it back, put a good weld on the backside so it doesn't happen again then get it realigned. You'll be GTG.
  30. Apr 1, 2021 at 4:33 AM
    HidetownRed
    Top O Texas
    What precautions should be taken on a vehicle with modern electronics when talking abound welding on the frame?
