CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Dec 24, 2022 at 5:15 PM
    #2761
    richsadams
    richsadams New Member
    Northwest
    2000 SR5 AC 4x4 4.7L
    I'm planning on test driving a '14 CM Ltd with 97K miles and an '18 DC SR5 with 106K miles, both 5.7L next week. (Both about the same price). I read through a lot of this thread, but then my eyes started to glaze over. Would someone be so kind as to post a link or links to photos of what I should be looking for?
    Plus after various statements, all in good faith, I can't be sure if this is something Toyota is still repairing under any kind of extended warranty or recall situation or not.
    Have had Toyota/Lexus for decades and all except an ES300 that had a transmission give out, they've been close to bullet proof. I had a '10 Tundra Ltd DC and with normal maintenance it was flawless after 150K. Have an '00 SR5 Tundra AC pushing a quarter million miles now. New timing belt and suspension recently, but otherwise solid as a rock as well.
    A little concerned about what I'm reading here so welcome any advice.
    TIA!
    EDIT: I just found what I think are good photos of the issue on an older thread, but if not or if you have any additional advice I'm all ears! I think I'm looking just beyond the top of the front shock towers? Thanks!
    https://www.tundras.com/threads/ple...tower-seal-recall-petition.22500/#post-539227
  2. Jan 6, 2023 at 11:35 AM
    #2762
    richsadams
    Northwest
    The '14 CM Ltd wasn't my cup of tea, so we're going to test drive a '14 CM 1794 tomorrow. It's a private party and he had the truck detailed, including the engine bay, about three weeks ago. Hopefully that'll be long enough for any leaks to start showing again.
  3. Jan 16, 2023 at 9:57 PM
    #2763
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I definitely have some seeping going on. I spotted it while draining the coolant from the block. I've watched a YouTube tear down of this engine. The head/cam designs are not trivial. I'm not going to fork out $1000s so an overworked tech can go deep into my engine to fix an inconsequential oil leak.
    I'll watch for it to become a problem, until then...:burnrubber:
    JJtruckon, vilord and Cpl_Punishment like this.
  4. Jan 25, 2023 at 10:10 AM
    #2764
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    Give it a couple years. The TTV6 will be more economical and durable than our old 5.7’s.
  5. Jan 25, 2023 at 11:41 AM
    #2765
    tsinajinii
    tsinajinii Black Streak Wood People | Free Folk have no King
    Jamin
    AZ
    Tundra - Crewmax TRD Sport; Tacoma - DCLB TRD Sport
    I don't know of any instances where a turbo'd engine has proven to be more durable than a naturally asparated engine with similar performance numbers. :notsure:
    It would be awesome if this turns out to be the case though.
    nasher75, Rodbolt and Cpl_Punishment like this.
  6. Mar 16, 2023 at 9:28 AM
    #2766
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    I'm under warranty and felt the same way. I changed my mind yesterday and was at the dealership this morning. Parts being ordered and it'll take three days to do both sides.
    Oil is about to drip off the heat shield and make things stinky. Six months left on the powertrain, so it's time to fix it. It only took four years to decide.
  7. Mar 19, 2023 at 7:28 AM
    #2767
    TUNDRA180
    TUNDRA180 New Member
    MATT
    2017 BLACK TUNDRA PLATINUM
    I just had the cam tower leak repaired at the dealer. Glad I bought the extended warranty. I found it when I pulled the wheel skirt back to drain the engine coolant from the engine drain on both sides.
    Mike59 and Wynnded like this.
  8. Mar 29, 2023 at 8:19 AM
    #2768
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have a '13 Sequoia with 136k. I bought a warranty that is expiring so had it checked by the dealer and they found seeping on one side. I do 5k oil changes & never have to add oil so it is very minimal, should I let it go or have it done seeing as there seems to be many horror stories of poor work causing issues after the repair?
  9. Mar 29, 2023 at 9:19 AM
    #2769
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    I have a '14 Tundra that is leaking on both sides. Its not a signifcant leak and I've been driving it that way for 40K miles. I prefer not to have the thing torn apart and feel like I will just run into more issues after the repair. Not fixing it unless it gets really bad...I guess its your call
  10. Mar 29, 2023 at 9:21 AM
    #2770
    e30cabrio
    I'm very aware (I thought) of my tree's needs & was unaware. I feel like it's an if it ain't broke don't fix it deal. The dealer says they do alot & their lead will be doing the work. I'm torn.
    Thanks
  11. Mar 29, 2023 at 9:54 AM
    #2771
    Boisefly
    Boisefly New Member
    Boise, ID
    yeah, only you can decide. If you go for it, good luck!
  12. Mar 29, 2023 at 10:48 AM
    #2772
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Could ask them for the cost to do it and decide if you would rather pay that out of pocket if the leak gets worse down the road or potentially replace the truck in the near future if they mess something else up during the repair.
  13. Mar 29, 2023 at 11:25 AM
    #2773
    e30cabrio
    My problem is I have the truck where I want it. Short of a 2018+ with a SC it can't be replaced (for what I am into it for)
    For those that are not familiar, I have an 18+ cluster & 18+ lights, 95% TRD PRO etc. The cluster was the pita and I sold the original cluster so that would be a problem. It really is barely moist on teh "bad" side, I never have any oil on the ground & the truck is as I said the truck is 99.9999% "done"
    I almost wish I had not taken it in.
    lol
  14. Mar 29, 2023 at 11:36 AM
    #2774
    Boisefly
    Boisefly New Member
    Boise, ID
    If its not even leaking bad enough to drip on the heat shield, there is absolutely no way I would mess with it. My $.02
  15. Mar 29, 2023 at 11:47 AM
    #2775
    e30cabrio
    It is barely seeping, there is no actual liquid I can see. It's just a little dirty. Thanks, I'm living with it. The year warranty is a joke seeing as it will be much longer to go bad most likely (unless they do a severely poor job)
  16. Mar 29, 2023 at 11:50 AM
    #2776
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    They won’t fix it if it’s not super bad they will put it off
  17. Mar 29, 2023 at 11:52 AM
    #2777
    e30cabrio
    I have an extended warranty, it expires 4/8, they want the money. It's now or never. I am letting them do the upper & lower control arm bushings.
  18. Mar 29, 2023 at 11:55 AM
    #2778
    Trdwillie14
    Billy
    2014 trd off road
    Do it. Have them do both sides
  19. Apr 2, 2023 at 6:46 PM
    #2779
    sbxx312
    sbxx312 New Member
    I've been dripping on the heat shield for about 30k miles. Slow seep from the driver's side. Now there's enough to drip off and I think it's going to become a problem.
    I have a 2018 with 34k miles. I've debated this repair since 5k. Dealership was ready then to fix both sides, but I hoped it wouldn't get worse. Truck goes in on Tuesday because the powertrain warranty expires in September. Three days. Makes me sad because I worry it won't be the same. But I want the new Magnuson s/c. This needs to get fixed successfully first.
  20. Apr 4, 2023 at 10:28 AM
    #2780
    sbxx312
    sbxx312 New Member
    Dropped off the truck this morning. I was at the topper place at 8:00 am to have them pull my Leer shell off and store it until the truck is fixed. Dealership says at least three days for both sides.
  21. Apr 4, 2023 at 10:42 AM
    #2781
    e30cabrio
    Mine is going this afternoon, I have the SC & want it to stay happy. :p
    sbxx312[QUOTED] likes this.
  22. Apr 4, 2023 at 11:05 AM
    #2782
    Trdwillie14
    Billy
    2014 trd off road
    Not bad at all one side for me was 2 weeks
  23. Apr 5, 2023 at 8:40 AM
    #2783
    e30cabrio
    Dropped the Tree off to get the warranty work done, first time it isn't sleeping at home, they grow up so fast.
    They claim I'll get it back Thursday.
    They gave me a '23 Tacoma.
  24. Apr 5, 2023 at 1:11 PM
    #2784
    sbxx312
    sbxx312 New Member
    Good luck. I'm driving my Tacoma. Like the Tree, it has a little boost.
  25. Apr 5, 2023 at 1:55 PM
    #2785
    Marvthehamster
    Marvthehamster New Member
    Tom
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI Armor, OTT Tune
    Got a 2018 with about 85k miles and I believe I've got this issue going on. I didnt realize it was a cam tower issue, but after reading this thread I believe that's it. It's definitely leaking enough to drip off the engine and fall on the heat shield. I discovered this while installing new coilovers a few weeks ago. This is a photo from the passenger side, not sure about the drivers side.
  26. Apr 6, 2023 at 6:20 AM
    #2786
    e30cabrio
    I really hope I get the tree back today. The Taco is nice but it's small, the cupholders are a joke its motor is buzzy & the brakes are touchy.
    My Tree has 2 cupholders there my 36oz Yeti fits.
  27. Apr 6, 2023 at 8:08 AM
    #2787
    e30cabrio
    Dealer sent a pic of the open head, looks new! I
    equin, JDR76, Boisefly and 2 others like this.
  28. Apr 6, 2023 at 12:18 PM
    #2788
    Boisefly
    Boisefly New Member
    Boise, ID
    welcome to the crew. Mine looks about the same (not quite as bad) and hasn't got worse in 40K miles. Hoping it stays that way.
  29. Apr 6, 2023 at 4:46 PM
    #2789
    e30cabrio
    Picked up the Tree, all well, no new sounds & it runs fine
    sbxx312 and Cpl_Punishment like this.
  30. Apr 6, 2023 at 6:39 PM
    #2790
    sbxx312
    sbxx312 New Member
    Congrats! Mine's done. Picking it up in the morning.
    e30cabrio[QUOTED] likes this.
