CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Feb 23, 2022 at 2:34 PM
    #2731
    Knox_Tundy
    Knox_Tundy New Member
    Knoxville, TN
    Am I crazy or is it seeping in the back?
  2. Feb 23, 2022 at 2:36 PM
    #2732
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It doesn't look like it to me....is that picture upside-down?
  3. Feb 23, 2022 at 2:40 PM
    #2733
    Knox_Tundy
    Knoxville, TN
    lol yeah, not sure why that is. I didn’t take the picture upside down.
  4. Mar 6, 2022 at 10:25 AM
    #2734
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    WAtundra4x4 likes this.
  5. Mar 6, 2022 at 10:32 AM
    #2735
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It looks to me that there's a little caked dirt from a very slight oil seep on the rightmost eyelet in your picture. I would not worry about it, but would keep an eye on it were I to see the same on my truck.
  6. Mar 6, 2022 at 10:34 AM
    #2736
    MEWaters
    MEWaters New Member
    Maine
    I’m currrntly on a test drive in it. 150k on the clock. New frame, UCA, ball joints, rear shocks, cross members, fuel tank. Would you consider buying with this weep? Passenger side. Is this def cam?
  7. Mar 6, 2022 at 10:41 AM
    #2737
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It'd be worth at least considering, but you'd need to consider the big picture and I can't do that without being there. That could possibly be seeping from the valve cover though too. A surer way would be to clean it up and do a dye test to try to better determine exactly where it's coming from.
    MEWaters[QUOTED] likes this.
  8. Mar 6, 2022 at 12:04 PM
    #2738
    Rw429
    Rw429 New Member
    Rob
    2017 Black Toyota Tundra SR5 Crewmax TRD Off Road
    I have a 2017 that had a similar looking pic on the driverside. I cleaned it up and monitored it, due to paranoia with this forum. I would definitely call mine a slow seep if anything. I noticed a drop, maybe of what could be oil a few weeks ago but never had anything leak onto the manifold / heat shield below, or had any oil loss for over 30k now. It seems to be more obvious that there is a “seep” after the truck sits overnight. After the engine is warm it appears dry. So my point is if you clean it up based on the pics I see, I doubt it’s an issue. If anything check it at every oil change interval but would not worry about it. Apparently, all model years from 2010 up to 2021 have had some sort of leak in that area and 9 out of 10 owners do not experience serious leaks onto the engine / related parts or ground.
    MEWaters likes this.
  9. Mar 17, 2022 at 10:46 AM
    #2739
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    I took my 2018 in to Charley's this morning for an oil change. We looked at the driver's side and the leak has reached the end of the heat shield and is about to drip off. So it goes. 26k miles.
  10. Mar 17, 2022 at 1:53 PM
    #2740
    Rw429
    Rw429 New Member
    Rob
    That sucks man. I am sure I have a seep but the dealer said it was just condensation. Not sure it makes sense if the A/C run off is on the other side of the engine I believe. Been the same for about 15k so I just clean the drip I see, whether it’s oil or not. Not tearing apart my engine for this annoyance unless it worsens, like everything else with age and mileage.
  11. Mar 17, 2022 at 7:11 PM
    #2741
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    If I had a 07 that looked that good, I’d be happy. I guess I’m getting to the age the I had old cars where you could use a putty knife to scrape the oil and dirt stuck to it off.
  12. Mar 19, 2022 at 10:01 AM
    #2742
    ToyoBob
    ToyoBob New Member
    Central Oregon
    2018 DC SR5 TRDoffroad
    My 2018 truck just passed 48K miles. About a month ago I started smelling burnt oil when the truck was parked in the garage after driving it all day and it has continued. Today I looked into the wheel wells and saw what I believe to be leaked oil on the engine, both driver and passenger sides. I'd like to get opinions on the next steps I should take. Should I try to clean off the offending areas and see if it returns or should I just make an appointment with the local dealership and have them take a look? BTW, do dealerships charge owners for taking a look or is this something that falls under the umbrella of drivetrain warranty? The first photo is driver's side and the second is the passenger side. Driver's side.HEIC.jpg Pass side.HEIC.jpg Thanks in advance for your thoughts.
    Y0TA PR0 likes this.
  13. Mar 19, 2022 at 10:18 AM
    #2743
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Yes get it checked out at the dealer. It looks like my 15 did, they never charged me for looking at it. And they fixed both sides.
    Wynnded and Blue Thunder like this.
  14. Apr 10, 2022 at 7:09 PM
    #2744
    Tundra_Sam
    Tundra_Sam New Member
    2 years later and my driverside fix is leaking
  15. Apr 10, 2022 at 8:41 PM
    #2745
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Oh man that sucks. Maybe they should of removed everything and did it right the first time, instead of finding a quicker way to fix it. What year is your truck?
  16. Apr 10, 2022 at 9:02 PM
    #2746
    Tundra_Sam
    2018
    Y0TA PR0[QUOTED] likes this.
  17. Apr 10, 2022 at 10:00 PM
    #2747
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Less than 60k miles? Are you going to take it back to the dealer?
  18. Apr 10, 2022 at 10:55 PM
    #2748
    Tundra_Sam
    41k miles. I plan to give them a call this week.
  19. May 10, 2022 at 9:05 AM
    #2749
    sbxx312
    sbxx312 New Member
    Met with the service advisor at the dealership this morning. We've been watching the driver's side leak for 22k miles. It's about to drip off the heat shield, so it's time. Parts were ordered and he said he'd like to have the truck for at least a week or two.
    Cab is coming off and both sides resealed although the passenger side tower is dry. The tech he assigned it to is his best friend and since no one eats breakfast, I'm bringing Left Hand 1265 and Upslope Craft lager for the crew.
    My truck is a 2018 with 27k miles and about 16 months left on the powertrain warranty. Service advisor said they've done 100s of these and it's the robot's fault, as we've discussed here. He said the robot can't detect air bubbles.
  20. May 10, 2022 at 12:02 PM
    #2750
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Mine leaks on the passenger side enough for me to smell the oil on the heat shield on hot summer days. Hasn't got worse and don't expect it to. Definitely not having the goons at the dealership tear it apart. Will be fine.
    willy and Mfanatic22 like this.
  21. May 10, 2022 at 12:54 PM
    #2751
    sbxx312
    sbxx312 New Member
    I wasn't going to fix mine either. It's getting worse. If it gets fixed without issues, I'm getting a Magnuson supercharger that'll probably be installed by the same tech.
    My position has changed a couple times during this thread. For most of the thread and since my post at 5500 miles, I didn't plan on fixing it. I also expected to be all over the new Tundra or Sequoia. If I can get through this stupid cam shaft issue, I'm throwing another $10k at my V8 and committing longer term to the 2.5.
    07DCLimited and Boisefly[QUOTED] like this.
  22. May 10, 2022 at 1:38 PM
    #2752
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Let's hope they drink that after they finish the repair! :rofl:
    JLS in WA likes this.
  23. May 16, 2022 at 3:02 PM
    #2753
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Operative term being AFTER
    Cpl_Punishment likes this.
  24. May 16, 2022 at 4:02 PM
    #2754
    sbxx312
    sbxx312 New Member
    I would have preferred coffee and a Moe's bagel sandwich. Breakfast/coffee was suggested in the Ask a Toyota mechanic thread.
    Still waiting on parts.
  25. Sep 10, 2022 at 5:39 PM
    #2755
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    What you are seeing is a bit of light reflection (sheen) off of the light gray RTV. I’ve actually reached in and touched my cam towers to confirm. You are giving yourself a frigging heart attack over nothing.
  26. Oct 19, 2022 at 8:32 PM
    #2756
    TexasTJ
    TexasTJ New Member
    Toyota
    How common is this on the 4.6? 2017 with 58k miles and the driver side is wet. Best picture I could get tonight. Planning on stopping by the dealership over the weekend.
    mjn75 likes this.
  27. Oct 25, 2022 at 5:53 PM
    #2757
    FrostyTundra22
    FrostyTundra22 No longer new member
    2020 Toyota Tundra 1794 Crewmax
    I’m wondering if this is happening to late 2.5 Gen Tundras. I have a 2020.
    CountryBoyCanSurvive likes this.
  28. Oct 25, 2022 at 6:01 PM
    #2758
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I agree, best left be.
  29. Oct 25, 2022 at 6:08 PM
    #2759
    TexasTJ
    TexasTJ New Member
    Toyota
    Dealership found an extended warranty that we didn’t know we had. They’re fixing up both sides an estimate it’ll be done in two weeks. ignore the recommended services at the bottom.
    JJtruckon likes this.
  30. Oct 25, 2022 at 7:26 PM
    #2760
    tsinajinii
    tsinajinii Black Streak Wood People | Free Folk have no King
    Jamin
    AZ
    Tundra - Crewmax TRD Sport; Tacoma - DCLB TRD Sport
