CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Feb 22, 2018 at 6:48 AM
    #241
    fishman1
    fishman1 New Member
    2017 TundraTrd off-road crewmax
    Thanks Trdlife, I will keep everyone posted when it goes in for surgery....
    Watt maker and trdlife like this.
  2. Feb 22, 2018 at 7:26 AM
    #242
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Is the black FIPG different then the gray used at the factory? I read somewhere the color was just for warranty purposes so you would know if its been repaired. I'm curious if its a different sealant altogether. Mine was leaking bad enough that the dealer went ahead and processed it to be fixed. You mention Toyota getting picky on the reseals, will they only allow the side that's leaking to be fixed? Most I see on here the dealer fixes both sides even if only one is leaking. My dealer told me they wont do the driver side since its not leaking, seems to me if the passenger side is leaking then the driver side isn't far behind.
    I'm right there with you, 2017 here and they have to pull engine and crack her open to fix so I feel for ya.
  3. Feb 22, 2018 at 7:28 AM
    #243
    token2k6
    token2k6 New Member
    2021 Tundra CM SR5
    I already have 35k on my 2017 CM. I haven't noticed anything on my garage floor, but will try to peek under soon. I assume these are areas behind the wheels, or do I need to go straight under the engine? Also, if you do change the oil at every 10k or drop down to 5k, is it that big of a deal? What could go wrong if you don't do anything??
    I drove my Tacoma for 225k after they told me the valve cover gasket was leaking, just had a stained engine block, which wasn't a big deal for me..
    TheBeast likes this.
  4. Feb 22, 2018 at 7:33 AM
    #244
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Mine was visible by look up at the manifold form underneath, and it was actually dripping onto the manifold heat shield. Some members have just a seep which doesn't seem to bad. Mine is visibly dripping and I've lost 1/2qt oil in 6k miles so I would say it can be pretty substantial. I don't know if it will stay the same or get any worse. But I would think once the oil starts seeping under the fipg seal, its going to intensify the leak. m
  5. Feb 22, 2018 at 7:36 AM
    #245
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    As far as what it is made up of i'm not sure but it very well could be, could be made to set up in a different time frame. but the color yes is an easy way for us to tell if something has been resealed. from the factory you have light grey seal, and on some i have notice 15 or newer like mine, it is a dark grey sealant, and from those i have not seen leaks in my area.
    As far as one or both sides, that may depend on the tech or the area, if they are having issues with claims or something. I have seen some people do just one side, and then low and behold the other side start leaking. and generaly they both are leaking one may be worse than the other. I have been told from higher up to just do both it just makes sense, since i am already there.
    driverdog likes this.
  6. Feb 22, 2018 at 8:17 AM
    #246
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    If you don't mind me asking what dealership do you work for? Was at dealership yesterday where I purchased truck and they barely acknowledged a problem and said it's very rare. Lol
  7. Feb 22, 2018 at 8:29 AM
    #247
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I'm down in Kansas. And honestly if may be rare in some areas or dealers. I know it seems weird but some areas see problems other dont. Like in general, we do a lot of door lock actuators, its know, and i know a mastertech at another dealer been there like 5-10 years and they have never had one fail.
    driverdog and Casper3[QUOTED] like this.
  8. Feb 22, 2018 at 8:40 AM
    #248
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Thanks for the reply, my dealer is in CT and supposedly one of the top seller's of tundra trucks. I find it hard to believe when they say it's rare but then again I kinda expected that response. Time will tell i guess, as of now no leaks.
  9. Feb 22, 2018 at 8:48 AM
    #249
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Well they may look at it the way i do sometime. We are the largest truck sell in the midwest and one of the top nation, so per tundras we sell and see on a daily basis, yea the numbers are extremely low.
  10. Feb 22, 2018 at 9:19 AM
    #250
    TheBeast The Beach
    @trdlife I can see you open your own shop later on.."Tundra cam tower leaks expert" :)
  11. Feb 22, 2018 at 9:43 AM
    #251
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    My left side is leaking a little. I clean it off and make sure the Oil is topped.
    Would I like it fixed, sure, maybe, idk, only if it was detrimental. But I won't ever be able to afford to fix it at the prices i see getting thrown around and I'm @ 132K miles, so well out of any warranty.
    I'm used to cars that drip a little oil, doesn't bug me.
    OBXTundra, Watt maker and trdlife like this.
  12. Feb 22, 2018 at 10:28 AM
    #252
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Thanks for the info, I to was thinking they are only doing one side because that's all they are paid to fix. Once the engine is out and the engine torn down about how many hours are we talking for the driver side to be resealed if you were already in there for the passenger? I'm curious and trying to get as much knowledge about it before I call Toyota.
  13. Feb 22, 2018 at 10:41 AM
    #253
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    your looking at and addition 2-3 hours for the other side i say is what book time is on it.
  14. Feb 22, 2018 at 11:37 AM
    #254
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Thanks! Seems like a waste to pull the motor and not give 2 more hrs for the driver side. I will see if corporate will allow the dealership to reseal the driver side as well.
    TheBeast and trdlife[QUOTED] like this.
  15. Feb 22, 2018 at 1:10 PM
    #255
    Murph28
    Murph28 New Member
    2010 Blue Streak Metallic Double Cab
    So far so good. Both sides were leaking so they did both. I don't have very many miles on it since it was repaired, it's not my daily driver.
  16. Feb 22, 2018 at 1:21 PM
    #256
    Murph28
    Murph28 New Member
    My dealership said the same thing. It was rare and they have not done many.
    Casper3[QUOTED] likes this.
  17. Feb 22, 2018 at 6:46 PM
    #257
    TTund16
    TTund16 New Member
    @trdlife
    Thanks for your response.
    To clarify I was wondering if the cause of leak/seepage could be due to the bolts getting loose over time due to vibration or expansion/contraction due to temperature ... have you seen any cases like that?
    Waterboy45661 likes this.
  18. Feb 22, 2018 at 6:49 PM
    #258
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Lol oh my bad I read that wrong. To answer that no I do not think it is a torque issue, every one I have done had to be broke loose by hand.
    TheBeast and TTund16[QUOTED] like this.
  19. Feb 22, 2018 at 6:58 PM
    #259
    TTund16
    TTund16 New Member
    i see, I was hoping it was the loose bolts! i had some in my Tacoma ... i prefer loose bolts over the over-haul of the engine ... lol
    trdlife likes this.
  20. Feb 23, 2018 at 5:45 AM
    #260
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    lol yea I would love to have my own, shop, for Tundra performance and even cam towers, but being isolated in kansas, thats long drives for people lol
  21. Feb 23, 2018 at 10:02 AM
    #261
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Called Toyota today and opened up a case for an warranty extension, I will hear back in 1 day. So we shall see...fingers crossed.
    Watt maker likes this.
  22. Feb 24, 2018 at 8:51 AM
    #262
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Got my truck back today. They fixed the cam tower seals on both sides. Paperwork shows that both were indeed leaking but I only really noticed it on the drivers side. Job shows 20 hours.
    I had a 2017 Avalon hybrid for a loaner. Gotta admit getting 38mpg average for my weekly commute was nice compared to my normal 14 in my Tundra. Might have to look at a Highlander hybrid to replace the wife's Sienna.
  23. Feb 24, 2018 at 10:17 AM
    #263
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Did you find out the method they used? Pull engine, in truck or pull cab?
    Glad you got yours back and as is well.
    Y0TA PR0 likes this.
  24. Feb 24, 2018 at 11:21 AM
    #264
    IndyTundra
    Ronnie
    Indianapolis, IN
    In truck.
    Thanks, hope you get yours done quickly as well.
  25. Feb 24, 2018 at 9:53 PM
    #265
    Snipe06
    Snipe06 New Member
    Georgia
    2012 Magnetic Gray Tundra RWDC
    First post here, but Sir you are a God sender. Found out this cam tower fiasco in my 12 RW and I'm getting to ship the truck to Alaska. Let's see what if the local dealer will do the fix even I don;t trust them for some BS jobs done in other cars.
  26. Feb 24, 2018 at 10:42 PM
    #266
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome!
  27. Feb 25, 2018 at 12:59 PM
    #267
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    First post but sigh 2018 tundra 580miles right side leaking.
    TheBeast and Y0TA PR0 like this.
  28. Feb 25, 2018 at 1:01 PM
    #268
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Welcome! Sorry to hear. Hope dealer fix it for you.
  29. Feb 25, 2018 at 1:02 PM
    #269
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Lame. I'd definitely be asking for a new truck. Totally unacceptable to have the top end broken into on a truck with less than 1,000 miles.
  30. Feb 25, 2018 at 1:02 PM
    #270
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    Thanks gonna have to call them Monday second time it’s been in for work in the 2 weeks I had
