CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Feb 11, 2021 at 6:01 AM
    #2491
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I haven't read of anyone having a reoccurrence on the repair...
    TheBeast and Cpl_Punishment like this.
  2. Feb 14, 2021 at 9:05 AM
    #2492
    digger21
    digger21 New Member
    Kane
    Tennessee
    2018 SR5 4x4 Crewmax
    LED interior and bed lights, steel off rd wheels with 285/55/20 Toyo Open Country ATIII. Tow mirrors, winnjet taillights, undercover ultra flex bedcover, chrome delete
    @trdlife whats your thoughts on this. It’s not wet to the touch but still curious
  3. Feb 14, 2021 at 9:16 AM
    #2493
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Unsolicited answer. If you have any powertrain warranty left, take it in and get it documented. Don't be surprised if the dealer makes light of it though. And then keep an eye on it, maybe even take photos at regular mileage intervals, say 5k.
    Cpl_Punishment likes this.
  4. Feb 14, 2021 at 9:32 AM
    #2494
    digger21
    digger21 New Member
    Kane
    Tennessee
    @Wynnded it doesn’t have any warranty left and honestly it looks fine to me, however with trdlife being a master tech, just wanted a professional honest opinion, especially after reading some of the comments from people on here about not so honest dealerships. I did however purchase and extended warranty from the dealership that I bought the truck at but they are not a Toyota dealership and I feel they may not have knowledge about the cam shaft tower leak.
  5. Feb 14, 2021 at 9:38 AM
    #2495
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's fair. It doesn't look bad at all in my opinion, but it never hurts to keep an eye on it. If you have the time and inclination though, you could invest in examining the details of you extended warranty in an effort to see if even what appears to be very minor is covered. It's really dependent on the details of that warranty.
  6. Feb 14, 2021 at 9:42 AM
    #2496
    digger21
    digger21 New Member
    Kane
    Tennessee
    Thanks, I have the platinum extended warranty that will cover it, it’s good for 4 years or 36,000 miles. I will just monitor it over the next 10,000 miles, which may take a year to put that much on there but that’s the exact reason I bought the warranty.
    Wynnded likes this.
  7. Feb 14, 2021 at 10:15 AM
    #2497
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Is this covered by the 5yr powertrain warranty or just the standard 3 yr?
  8. Feb 14, 2021 at 10:19 AM
    #2498
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    sask3m[QUOTED] likes this.
  9. Feb 15, 2021 at 2:12 PM
    #2499
    Solutions2 Low-Voltage
    Solutions2 Low-Voltage New Member
    Georgia
    2008 White Tundra DC, LB, 4x4
    Borla Duals - TRD Intake - Bedslide - ARE Shell
    IMG_9539.jpg IMG_9536.jpg From my mechanic, "All engines leak, eventually. And, it may turn into a bigger leak somewhere else if you fix it", as in my case. Now, if your vehicle is still under the REAL Manufactures warranty period then hold them accountable for that leak and any other leak as a result of repairs...you can "extend your leak warranty". If your warranty is not really clear or some kind of junk warranty than that is between you and a lawyer and them. If you know for a fact you are out of warranty and you are facing the issue of repair, selling, keeping it, or whatever then you have to make a decision too. In my case, I have dealt with the leak for many years. So much so that I call this my 365 day Oil change because, I am adding about a quart every 2 weeks.
    Now, the real question to those who have leaks...
    ARE YOU USING SYNTHETIC OIL? I AM. I am using Royal Purple and have been since the first oil change. I read that it does cause leaks AND then I read that it does NOT cause leaks! I am going to switch to the most basic, Conventional, Mobil1 5w20 Oil and do 3 oil changes over the next 15K miles and see if my leaks at least decrease some or hopefully go away completely. I am concerned that the change over from synthetic to conventional may cause damage but maybe that is just my personal worry because I am reading it will not cause damage.
    My truck runs strong. It cranks everyday and is as peppy as it was the first day. The only thing that does not work are my door locks...AND It LEAKS! I decided to keep this truck. It now has almost 450K, all original minus the basics. Its cheaper to keep her.
  10. Feb 15, 2021 at 2:14 PM
    #2500
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Why would the oil formulation affect if your seals leak or not?
    TTund16 likes this.
  11. Feb 15, 2021 at 2:22 PM
    #2501
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think it stems from the days of yore when seals were made from a different material.
    TheBeast likes this.
  12. Feb 15, 2021 at 4:25 PM
    #2502
    Georgia
    I'm no auto expert and do not claim to be but in my researching data and talking to sports car owners, the common factor is Royal Purple and other Synthetics are quoted as "thinner" oils. They are also quoted to be "cleaners". The other claim is that conventional oil is less likely to leak because of buildup. I have stretched oil changes out as far as 12K miles between intervals. I gave it plenty of time to build up and my last course of action is switching to conventional for about 15 to 20K miles and see what happens.
    For the record, the first leak ever was actually where the oil filter housing bolted to the block. My mechanic told me not to mess with it and it was no big deal. He further told me that putting a stop on that small leak will cause a leak elsewhere. He was right.
    Also, for the record, I have followed the maintenance schedule all the way...I am on my 4th book.
  13. Feb 15, 2021 at 7:21 PM
    #2503
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    That’s impressive mileage.
  14. Feb 15, 2021 at 11:20 PM
    #2504
    TTund16
    TTund16 New Member
    :monocle:
  15. Feb 15, 2021 at 11:39 PM
    #2505
    TTund16
    TTund16 New Member
    There is no "buildup" in new engines and very small percentage leak with few thousand miles on them and many haven't leaked for hundreds of thousands of miles using the same or similar "synthetic" oil.
  16. Feb 16, 2021 at 4:21 AM
    #2506
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    All 5w20 are synthetic I thought.
  17. Feb 16, 2021 at 5:46 AM
    #2507
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    I thought Mobil 1 was synthetic? Isn't conventional oil dyno oil? Am I missing something here?
    Also, for those that have leaks and the dealers are doing their oil changes, how do we even know what type of oil they are using, and does it matter? I'm just wondering what difference does it make what type of oil is used, these are modern vehicles and any recommended oil should work. This appears more to be a Toyota manufacturing or process issue.
    BuckWallace likes this.
  18. Feb 16, 2021 at 6:01 AM
    #2508
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Correct. All Mobil oils are either synthetic or synthetic blend. No conventional.
  19. Feb 16, 2021 at 6:45 AM
    #2509
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think this is basically what it boils down to...
  20. Feb 16, 2021 at 8:11 AM
    #2510
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    This is interesting. I have run Royal Purple also since 18k when I bought. Now at 182k with a small leak passenger side. Maybe just a valve cover, but never had to add oil in between changes. Performance has not suffered. Would performance suffer if it was a cam tower leak?? Nobody has an answer to that one as far as I know.
    Keep us posted & let us know how this experiment turns out!
    And BTW, at 450k your allowed to leak oil!
  21. Feb 17, 2021 at 4:46 PM
    #2511
    turkeycreek29010
    turkeycreek29010 New Member
    Chuck
    Bishopville SC
    2019 Cement Tundra Crew Max
    3/1 Level Kit, 20 inch Gear Wheel, 285/65/20 BFG
    Dropped off at the dealership today. They are going to do both sides. In top of this, they found the timing chain cover and rear main seal also had a leak. Just tripped 19,000 miles. I'm starting to get a not so warm and fuzzy feeling about long-term reliability. Maybe I'm wrong, this seems like pretty major repair for this low of miles.
    Leo's first likes this.
  22. Feb 17, 2021 at 4:54 PM
    #2512
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Man I hate that but at least they found everything and will take care of you and nothing out of pocket on your end. Even though I am still going back and forth with Toyota this is still the best truck I have ever had. I have no doubt it is more reliable than any Ford, Ram, or Chevrolet out there. I have owned all three and wasn't impressed. How long is the dealership going to have it?
  23. Feb 17, 2021 at 4:56 PM
    #2513
    turkeycreek29010
    Chuck
    Bishopville SC
    Should be done Friday
    Clemshady likes this.
  24. Feb 17, 2021 at 5:21 PM
    #2514
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Sorry to hear. I agree with you, though. Obviously for the most part these trucks are very reliable, but this major of a repair opens the door for other issues while they have the engine opened up, which was the case with my 2018. Just be careful on this forum talking any negativity about Toyota reliability for fear of being flamed.
    :crapstorm:
  25. Feb 17, 2021 at 5:53 PM
    #2515
    TTund16
    TTund16 New Member
    anytime you do a major surgery it's possible that something can go wrong. I wouldn't like a major engine work on a new car.
    what happened to your car or do you have a link?
  26. Feb 17, 2021 at 5:58 PM
    #2516
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
  27. Feb 21, 2021 at 6:51 AM
    #2517
    philnj
    philnj New Member
    My trucks going in for the repair with 59,850 miles on her, Tried to get my dealer to do both sides while they are in there. They said to call corporate, gave them a call they were super cool. Waiting to hear back monday if they are going to do the other side also. My dealer was a bit of a pain in the ass about this at first.
    WAtundra4x4 likes this.
  28. Feb 21, 2021 at 9:21 AM
    #2518
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What year truck?
  29. Feb 21, 2021 at 9:38 AM
    #2519
    philnj
    philnj New Member
  30. Feb 24, 2021 at 7:52 AM
    #2520
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    Just stumbled upon this thread and decided to go check mine out. Recently purchased a 2017 Tundra with 77k miles on it. looks like I have the issue as well :(
    Only warranty on it is a 3 month warranty from the small dealer I purchased it from. I’m sure it wouldn’t be covered or a huge hassle/fight to try and get it.
    Is it looking like I’m going to need to do something sooner than later?? Sealant appears to be black, yes?
    Passenger (droplet of oil on ear):
    Driver: (droplet of oil on ear, burned oil drippings on heat shield):
