CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Jan 23, 2021 at 10:35 AM
    #2461
    7.62X51
    7.62X51 New Member
    Virginia Beach
    My 2018 with 41K on it just succumbed to the dreaded tower seal leak. Will be covered under powertrain warranty.
  2. Jan 29, 2021 at 9:58 AM
    #2462
    Walleye1875
    Walleye1875 New Member
    16 Limited Crewmax Midnight Black
    At the Toyota dealership today they had 5 used Tundras on the lot and 3 of the 5 had a leak. This one being the worst.
  3. Jan 29, 2021 at 10:31 AM
    #2463
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Dang, what bad luck! Because we all know this isn't a widespread issue, right? :rolleyes:
  4. Jan 29, 2021 at 10:44 AM
    #2464
    Walleye1875
    Now mine is at the shop and I had them check it out since I noticed a small pass side cam tower leak. They came back and said it’s valve cover... I am at 59 months on warranty. What should I do since they are saying it’s a valve cover leak and not cam tower?
  5. Jan 29, 2021 at 12:24 PM
    #2465
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Have their been any 19-21s that have had the leak? Just wondering if the issue was ever corrected
  6. Jan 29, 2021 at 8:16 PM
    #2466
    Blue Thunder
    Washington
    Okay, but what years and how many miles? That pic doesn't look like it's from a 2020 with 5k miles.
  7. Jan 30, 2021 at 1:35 PM
    #2467
    Walleye1875
    Never said it was? Don’t know the mileage, didn’t care enough to check and shouldn’t matter. Oldest was a 2017 newest was a 19.
    They all will leak eventually, including yours. Just a matter if you care enough to have the seals replaced. Most people don’t even notice or know what to look for. Luckily mine at 37k is just a small leak from the valve cover (for now) and getting replaced under warranty next week!
    BuckWallace likes this.
  8. Jan 30, 2021 at 2:15 PM
    #2468
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Is it proven that all Tundras will leak eventually?
  9. Jan 30, 2021 at 2:26 PM
    #2469
    Walleye1875
    Based on my observation and talking to my Service manager, yep pretty likely! Love my truck, personally won’t buy anything other than Toyota but nothing is perfect.
  10. Jan 30, 2021 at 3:10 PM
    #2470
    Blue Thunder
    Washington
    Apparently yes... I just hope mine starts before the end of the warranty
  11. Feb 5, 2021 at 11:30 AM
    #2471
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Well, fixing to pull into dealership with 63,000 on odometer and get passenger side cam tower checked...fingers crossed they do the right thing.
  12. Feb 5, 2021 at 3:36 PM
    #2472
    SugarCityBoy
    SugarCityBoy New Member
    2011 rock warrior
    I just got denied by corporate. Can anyone out of warranty detail exactly what they said to get this covered? I was told that this is not a known issue and that unless it’s for a recall or under warranty there’s nothing they can do.
  13. Feb 5, 2021 at 4:18 PM
    #2473
    Clemshady
    Jeff
    They are jerking your chain saying it isn't a known issue. When a thread has 83 pages and counting with this issue then it is what it is. A recall on this would be devastating so they handle it on a case by case basis.. Mine is being reviewed as we speak and I am only 3000 miles over 60,000. I see yours is a 2011 so I can see where their loophole is with you. If I were you I would try to negotiate with them on covering some of it. Good luck.
  14. Feb 5, 2021 at 7:58 PM
    #2474
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Yeah, that's what they told me, along with the likely hundreds of others that have bothered to contact Toyota directly. My dealer claimed they see one or two of these per month, so it's obviously BS that this "isn't a known issue". Pretty despicable.
  15. Feb 5, 2021 at 8:12 PM
    #2475
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Your truck is 10 years old. I think it's crazy you're even trying to get it warrantied.
    Wilbur, Vang530 and Malinois38 like this.
  16. Feb 5, 2021 at 9:33 PM
    #2476
    SugarCityBoy
    2011 rock warrior
    I think you’re right
  17. Feb 7, 2021 at 1:32 PM
    #2477
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Any engine will leak eventually, seals don't last forever. My 2014 with 210k miles isn't leaking. Guess it's the luck of the draw.
    TheBeast, cnoyes72 and Clemsonman14 like this.
  18. Feb 8, 2021 at 9:54 AM
    #2478
    turkeycreek29010
    turkeycreek29010 New Member
    Chuck
    Bishopville SC
    2019 Cement Tundra Crew Max
    3/1 Level Kit, 20 inch Gear Wheel, 285/65/20 BFG
    I just checked mine, 2019 with 18,700 miles. Can you tell from the pictures if mine is leaking. This is the drivers side. You can see where I wiped my finger across to show.
  19. Feb 8, 2021 at 9:59 AM
    #2479
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    It might just be dirt, but based on the fact that the FIPG sealant looks wet in that area vs the relative cleanliness of the surrounding area I'd say you're the newest member of the club. Sorry!
    TheBeast likes this.
  20. Feb 8, 2021 at 10:04 AM
    #2480
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I would certainly go in and have that documented by the dealership.
  21. Feb 8, 2021 at 10:04 AM
    #2481
    Clemshady
    Jeff
    I agree with Buckwallace, welcome to the club. That area should be completely clean. At least you are under warranty, hopefully they will do both sides while they have the engine pulled.
  22. Feb 8, 2021 at 10:10 AM
    #2482
    turkeycreek29010
    Chuck
    Bishopville SC
    Sweet!.. My next service is in March. I will be sure to bring it up. Passenger side is clean.
  23. Feb 9, 2021 at 6:51 AM
    #2483
    mthbowhunter
    mthbowhunter New Member
    Michael
    2020 Tundra SR5
    None yet except for lockable bed cap
    Is there any chance this could be called a wear or maintenance issue? Just bought a 2020 with 50,000. Thankfully I bought the extended warranty and was told it is exactly like the new vehicle warranty. If it is occurring by chance I want to be sure I say or do what is necessary to get it covered if it is leaking.
  24. Feb 9, 2021 at 7:08 AM
    #2484
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Haven't heard of any dealerships calling it a wear issue but some have called it a "seep" or "weep" and said they won't fix it until it's actually a "leak".
    Rw429 and pickeledpigsfeet like this.
  25. Feb 9, 2021 at 7:20 AM
    #2485
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    In my mind, to call it a wear or maintenance item would suggest that there would need to be a schedule or regimen for the item (the sealant) to be cared for (serviced) or a replacement interval.
    Terndrerrr likes this.
  26. Feb 9, 2021 at 8:43 AM
    #2486
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    So... they are fixing the leak on your "cam toner"?
    What did you drive in there, a Xerox?
    TheBeast and Cpl_Punishment like this.
  27. Feb 9, 2021 at 9:16 AM
    #2487
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Damn... that’s a lot of miles! My 2019 only has 16k on the clock. :goingcrazy:
  28. Feb 9, 2021 at 10:46 AM
    #2488
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Gives me a lot of confidence the repair is going to be done with quality.
  29. Feb 10, 2021 at 8:43 AM
    #2489
    mthbowhunter
    Michael
    2020 Tundra SR5
    Yea I know. But it enabled me to buy it at an affordable price. $33.5k don’t think I got hurt too bad given the aftermarket add ons it had.
  30. Feb 11, 2021 at 5:02 AM
    #2490
    turkeycreek29010
    Chuck
    Bishopville SC
    I'm taking it in today to have it looked at and confirmed. What are the chances of having the same issue again again down the road? Should I look into an extended warranty?
    Wynnded[QUOTED] likes this.
