CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. May 15, 2020 at 6:03 PM
    #2341
    970KOM
    970KOM New Member
    James
    18 TRD
    Add me to the list, 2018 5.7 with 44,000. Passenger side leakage..
    georgiey22 likes this.
  2. May 17, 2020 at 4:13 PM
    #2342
    0100
    0100 New Member
    I am looking at a 2014 Sequoia. Was wondering if these oil marks on the frame would be indicative of a cam shaft leak.
  3. May 17, 2020 at 5:35 PM
    #2343
    NWPirate
    Zach
    WA
    Good chance of it, look through the wheelwell with a flashlight towards the back on both sides to confirm.
  4. May 17, 2020 at 6:12 PM
    #2344
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    My 2018 looks fine now at 27000km or 16875miles. Why is new trucks still have problems with cam tower leaks.....I don't get it.
  5. May 17, 2020 at 6:14 PM
    #2345
    Rotaryphoneuser
    Ontario. Canada
    2018 Cement CrewMax
    Don't buy it. Walk away........you can do better.
  6. May 17, 2020 at 6:43 PM
    #2346
    0100
    0100 New Member
    Yeah thanks guys, I agree I am going to walk.
    NWPirate likes this.
  7. May 17, 2020 at 7:53 PM
    #2347
    NWPirate
    Zach
    WA
    The consensus is the robot isn't putting down enough of the gray sealant. Sounds like a simple programming fix to me. :monocle:
  8. May 17, 2020 at 8:11 PM
    #2348
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I mean, it's kind of hard to not acknowledge visible oil leaking out of the engine. On many trucks. For 13 years. I think actually "acknowledging" it would mean they redesign the obviously-faulty method of sealing the cam towers after the first few years of this happening. Just my two cents...
  9. May 25, 2020 at 12:14 PM
    #2349
    Anthony605
    Anthony605 New Member
    Anthony
    2020 Limited Double Cab
    I just bought a 2020 Limited this past December. I took a look at the cam towers today. They are dry. I did notice that there is plenty of gray sealant seeping out around the perimeter of the cam towers. That is a good thing. Anyone know if Toyota did this to fix the leak issue?
    TTund16 likes this.
  10. May 25, 2020 at 12:34 PM
    #2350
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Only time, and diligent owners keeping an eye out for leaks, will answer that.
    TheBeast likes this.
  11. May 25, 2020 at 1:30 PM
    #2351
    Anthony605
    Anthony
    I agree. The only reason I pointed mine out was because of the extra sealant that was oozing out. My understanding was there was not enough sealant from the factory. The oozing sealant is hopefully a good thing as this shows that the sealing surface was covered. Hopefully it remains all good!
    TTund16 and TheBeast like this.
  12. May 25, 2020 at 2:02 PM
    #2352
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Mine was "oozing" out of my 2018 and leaked anyway. I'm pretty sure they all ooze out to some extent.
    jtwags likes this.
  13. May 25, 2020 at 3:33 PM
    #2353
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep. The sealant has always been visible, even on vehicles that experienced failures.
  14. May 25, 2020 at 3:42 PM
    #2354
    Anthony605
    Anthony
    OK good to know. I will keep an eye on it.
  15. May 26, 2020 at 11:28 PM
    #2355
    jpandya
    jpandya New Member
    2016 FFV 5.7 Tundra Ltd
    Can someone here help a newbie ...
    I recently got a used 2016 5.7 limited.
    Inspecting for the famous cam tower leaks, I found that passenger side has black sealant and clean. But driver side looks like dirty/ oily a bit. It also has light silver lining instead of black.
    • Does it mean that this vehicle was already repaired for passenger side?
    • Is there any definite way to confirm the leak on driver side? It’s difficult to get through the wheel well. I might go under tomorrow and try to clean.
  16. May 26, 2020 at 11:33 PM
    #2356
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Welcome. It's very possible that the passenger side was already repaired, especially if you're seeing black sealant. On the driver side, you'll want to look through the wheel well toward the rear of the engine (closest to the cab) behind the brake lines. You can also get under the truck right behind the front driver side wheel and look up at the engine from there.
  17. May 26, 2020 at 11:37 PM
    #2357
    jpandya
    jpandya New Member
    Thank you for your prompt reply.
    how come I cannot find any service record of this passenger side repair on Toyota app or Carfax ?
  18. May 30, 2020 at 8:30 AM
    #2358
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    Found this on drivers side yesterday :(
    2018 with 72k
    Filthyphil likes this.
  19. May 30, 2020 at 10:01 PM
    #2359
    jassanch
    jassanch New Member
    Jason L.
    2015 Tundra 5.7L CM
    Greetings - first time poster (sadly). I purchased a 2015 Tundra CM about a week ago. It’s has around 36,000 miles on it now. After driving it around for a few days I started to smell oil, looked under the hood and there was nothing obvious. Went online and found this! Sure enough, the passenger side cam tower appears to be leaking. The warranty has expired as the original owner purchased the vehicle in November, 2014. The thought of having to fork out a penny for a truck with relatively low miles to fix a known problem is sickening, especially since I just bought the truck!
    My question, anyone have suggestions on how I should proceed? I cleaned the oil as best I could, hopefully that will help determine how bad the leak is. Any chance of Toyota helping with the cost of the repair? Any positive experiences out there? The thought that the warranty expired 6 months ago doesn’t help.
    Any help is appreciated.
  20. May 30, 2020 at 10:08 PM
    #2360
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Sorry to hear that. Did you buy it from a Toyota dealer? If so, you might have a better chance of getting Toyota to help, otherwise it's probably a crap shoot. You're not super far out of the powertrain warranty, though, so Toyota might be willing to assist. Good luck!
  21. May 30, 2020 at 10:15 PM
    #2361
    jassanch
    jassanch New Member
    Jason L.
    2015 Tundra 5.7L CM
    No, it was a private party purchase. I will give Toyota a call on Monday. Hopefully they will help. Thanks!
  22. May 31, 2020 at 6:50 AM
    #2362
    jpandya
    jpandya New Member
    sorry to hear... check the VIN on Toyota website and see if the warranty actually expired. As I read it starts from the first sale of vehicle. May be there still few months left depending on when it was first sold.
  23. Jun 10, 2020 at 6:24 PM
    #2363
    handstriker909
    handstriker909 New Member
    SupaCharged Inferno 4x4 Tundra
    Sup fellas so I have a 2017 5.7 with 55k miles with a different leak.. took it to Toyota and their tech took a look at it and said it was the "Cam Cradle" leaking.. it's just seaping out they said, and that Toyota won't cover it unless it's actually leaking or dripping and since it's just seaping out they wont fix it under warranty. I mean how stupid is that it's going to leak eventually and I'm 5k miles away from being out of warranty 5yrs/60k warranty. What you guys think? Pretty much the same thing as a cam tower leak no?
    20200610_202012.jpg 20200610_201946.jpg 20200610_201830.jpg 20200610_201910.jpg
  24. Jun 10, 2020 at 6:39 PM
    #2364
    TheBeast The Beach
    with 36K on it, you might be able to buy extended warranty then later on use it to fix the leak.
  25. Jun 10, 2020 at 6:40 PM
    #2365
    TheBeast The Beach
    leaking for me. they should fix it.
  26. Jun 10, 2020 at 7:05 PM
    #2366
    handstriker909
    Easier said than done.. they want to see leaking and drips, which it will come to that but after warranty is up.
  27. Jun 11, 2020 at 1:50 PM
    #2367
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Id wait a few weeks then go under your truck with a oil squirt can and squirt those areas right before you take it back to the dealer . If they want to play the "its just seeping" game , you can play hard ball as well :)
  28. Jun 11, 2020 at 2:43 PM
    #2368
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Smart man.
    jordoncloutier likes this.
  29. Jun 11, 2020 at 3:02 PM
    #2369
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Has this issue become an actual recall by now?
    TTund16 likes this.
  30. Jun 11, 2020 at 3:40 PM
    #2370
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    No.
