CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Apr 9, 2020 at 6:33 AM
    #2311
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought the timing chain cover only had to come off of both sides were being done. But I could be wrong about that.
  2. Apr 9, 2020 at 8:03 AM
    #2312
    Pot Hole
    Pot Hole Where dem Mallards at?
    Mount Ulla, NC
    2020 White Limited TRD
    TRD skid plate, Stainless Running Boards, JDA Astar turn signal bulbs, VLEDs footwell lighting, Wet Okole seat covers, Weathertech Window Deflectors, more to come!
    You are likely correct, but I kept hearing that its removal was part of the repair process and I wondered if the new way to fix this issue didn't require it having to be taken off
  3. Apr 18, 2020 at 6:46 PM
    #2313
    fishman1
    fishman1 New Member
    2017 TundraTrd off-road crewmax
    Well, I am at 26000 miles on my 2017 crewmax and still love the truck! She has been leaking from the passenger side cam tower beginning at @6000 miles and finally got to the point where it started to smell and smoke occasionally so she went under the knife this week. I have delayed this repair as long as I could and have been extremely hesitant due to the invasiveness of this procedure but it needed to be repaired. It’s still in recovery and I pick it up Monday..When I dropped it off the other day they were great, the toyota supervisor is a quite, soft spoken guy, but extremely knowledgeable and after looking at it for less than 5 minutes with his light, he showed me both cam towers were leaking as well as the timing chain cover too and they would take care of it. He advised he sees way too many of these 3rd generations with this problem and they have repaired many(over 100 for small dealership). Appears that the sealant material for the timing cover is the same and leaks are common so be on the look out.....On a positive note, he has never had any come back after the repair..Toyota has not recalled this but has acknowledged the issue and is repairing.... Time will tell, pick it up next week but so far Toyota has been great on this issue. Wish me luck.
  4. Apr 18, 2020 at 9:08 PM
    #2314
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    good luck! I haven’t decided if I’m going to do it yet or not.
  5. Apr 22, 2020 at 6:33 PM
    #2315
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Finally decided to drop mine off today to have passenger side cam tower and front cover resealed. Also at 26000 miles. Really didnt want to do it but it started to drip. Been visibly leaking since 4000 miles. Sucks that it is so invasive to fix a darn leak on a new truck.
  6. Apr 22, 2020 at 7:16 PM
    #2316
    fishman1
    fishman1 New Member
    Just got mine back today..all is good so far but time will tell.....
    georgiey22, NoRcptn and Y0TA PR0 like this.
  7. Apr 26, 2020 at 10:13 AM
    #2317
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Which dealer?
  8. Apr 27, 2020 at 12:51 PM
    #2318
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    I don’t see any signs of leak or residue but not sure I’m looking in the right spot. Does this look good to go?
  9. Apr 27, 2020 at 6:27 PM
    #2319
    msikk
    msikk New Member
    Finally found the dreaded cam shaft tower leak. I have a 2012 w/69K on the odometer. Took it in today, Toyota offered $1300 towards the repair. Not bad considering I'm out of warranty by a few years. Hopefully have my truck back in a few days (although they gave me a 2020 Tundra to drive around).
  10. Apr 27, 2020 at 6:44 PM
    #2320
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I think it is preference. The guy that did mine tried without taking everything apart but said it was a pain so he took it apart to get the best seal he could (he is a tundra owner). 20K miles later and no issues yet. It sucked seeing a new truck torn apart but its over with now and I dont have to worry
  11. Apr 27, 2020 at 7:17 PM
    #2321
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    From your pictures, I see no evidence of a leak.:thumbsup:
  12. Apr 28, 2020 at 7:27 AM
    #2322
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I looked on my '20 with 3k miles, no signs. Clearly had it on my '18 that I traded.
  13. Apr 29, 2020 at 11:46 PM
    #2323
    Millski
    Millski New Member
    2020 Sport Premium Crewmax
    Nada
    I just picked up my '20. Not sure if anyone with a 2020 has reported a leak yet. Hopefully I don't end up with one but time will tell.
  14. May 1, 2020 at 1:35 PM
    #2324
    jshannon613
    jshannon613 New Member
    Justin
    2019 White Tundra TRD Pro
    None yet!
    I do not see any evidence of a leak on my truck. Should I check it after drive or would it be visible after sitting in my drive way for a couple hours. I do get a whiff of what seems to be an oil burning smell occasionally while driving. Could that be because of this?
  15. May 1, 2020 at 1:41 PM
    #2325
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Check after both occasions, that way you're more certain to catch it if it is prone to leak.
    jshannon613[QUOTED] likes this.
  16. May 1, 2020 at 1:59 PM
    #2326
    fishman1
    fishman1 New Member
    Just to add to the discussion. I got mine back a week or so ago and the dealer ended up removing the cab to do both cam towers and timing cover...Seems pretty invasive but less time involved to lift the cab up than working around all the components and allows for better access for resealing. So far so good....
    rodm1 and jtwags like this.
  17. May 1, 2020 at 2:38 PM
    #2327
    jtwags
    League City, TX
    2018 Tundra CM
    Wow, that is wild that they have to remove cab for seal. Did they take any pics with cab off for you?
    I got mine back the other day too. Only did passenger side and used shortcut that didnt involve removing timing cover. Still have a wet spot on timing cover but will have it addressed at a later date.
  18. May 1, 2020 at 3:28 PM
    #2328
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    There was another post earlier in this thread talking about cab off repair. Think they had pictures. Seems excessive but what do I know.
  19. May 1, 2020 at 4:34 PM
    #2329
    fishman1
    fishman1 New Member
    Here ya go... explanation I got and makes sense was since mine was leaking from both cam towers and timing cover,(at 26000 miles) best access to all 3 seals in order to get a good clean repair, the dealership prefers cab removal. I know everyone has an opinion, I trust the service manager, their repair background and history so who am I to criticize. Their opinion is they don’t want to see the same truck twice for the same issue, if any are weeping or show sign of failure they go after all of them....So far so good, time will tell..802CB5C2-87B5-411F-A783-F9DF3BA3C040.jpg
    Lake.Life24, saybng, equin and 6 others like this.
  20. May 1, 2020 at 4:57 PM
    #2330
    jshannon613
    Justin
    None yet!
    This actually doesn’t look as invasive now that I see a picture of it. Makes a lot of sense to work on the motor like this.
  21. May 1, 2020 at 5:05 PM
    #2331
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    As long as they don't have any bolts left over when they done... :rofl:
  22. May 1, 2020 at 5:10 PM
    #2332
    jtwags
    League City, TX
    2018 Tundra CM
    Great pic.
  23. May 1, 2020 at 5:19 PM
    #2333
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Too bad I didn't see this sooner I could have told you the bed didn't have to come off, you can actually do it with just the cab off. JK It's a little tight though and you have to bungie cord some things to keep aligned. Save some $$ an time.
  24. May 1, 2020 at 5:43 PM
    #2334
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    you can sneak the cam phasers off the cams and hold the chain tight with a bungee cord and the gears on. its a very tight fit, but it does allow the job to be done without the timing cover coming off. That cover is time consuming to take off. Removing the cab like above is a bit excessive. but seeing how we do frames it also does not take long at all to get a cab off...
    Pot Hole[QUOTED] likes this.
  25. May 2, 2020 at 8:39 AM
    #2335
    Used to watch the SR-71 Habu's take off every late afternoon at Kadena AFB, Okinawa in 1980. The SR-71 hanger was next to ours. They'd taxi out past us and you could see fuel dripping from it. Awesome aircraft. No cam tower leak...heh...heh...
    jshannon613, StihlBuckin and Wynnded like this.
  26. May 2, 2020 at 9:29 AM
    #2336
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    There’s some merit to that. I’d do it if warranty would cover it but I’d probably not if I had to pay for it - unless it was real bad. My Lexus RX350 has a very small leak near the rear seals - a couple drops a week and it’s out of warranty. Won’t bother to fix it.
  27. May 2, 2020 at 9:32 AM
    #2337
    jshannon613
    Justin
    None yet!
    Nice! When I was a kid, I lived at Edwards AFB in California and got to see the SR-71 fly a couple times. Was even able to meet a few pilots since my dad worked with them. I got the nick name Habu as a BMX racer because one of the popular brands at the time was mongoose. This brought back a flood of memories for some reason.
    Oh yeah I think my truck had this leak, going to go drive it today for a bit and see if I can find the source of the burning oil smell.
  28. May 3, 2020 at 6:10 PM
    #2338
    msikk
    msikk New Member
    Got my truck back on Friday. Repair complete, I'm out around $1K after Toyota chipped in $1.3K. On a brighter note, apparently some squirrels made a nice nest in my intake. I'm watching for them now. I'm going to start with spray and move up the ladder to more extreme methods.
    Blue Thunder and rebmo like this.
  29. May 4, 2020 at 10:27 AM
    #2339
    Tisoy281
    Tisoy281 New Member
    What year is your truck? Why did you have to pay out of pocket?
  30. May 4, 2020 at 5:57 PM
    #2340
    msikk
    msikk New Member
    My truck is a 2012 w/70K miles. I was pretty happy they paid what they did. The dealership didn't think they were going to offer anything at first.
    Y0TA PR0 and Tisoy281[QUOTED] like this.
