CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Feb 19, 2020 at 12:33 PM
    #2221
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    I don't get it? If you are still in the warranty period/mileage limits then it's not up for debate. It's not like they can flip a coin and deny coverage - if you're covered then you're covered.
    ntg[QUOTED] and Cpl_Punishment like this.
  2. Feb 19, 2020 at 12:51 PM
    #2222
    ntg
    ntg New Member
    2016 TUNDRA TRD
    Topper, Drawer System / Bed Platform,
    I agree completely. I don't know why they wouldn't fix it. I'll see what he has to say and if he says they won't then start the whole process of going to Toyota Corporate etc. etc.
  3. Feb 19, 2020 at 2:15 PM
    #2223
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Toyota should be using the black sealant from the start instead of putting owners through the fiasco of having the top half of there engine torn down.
    ntg, TheBeast[QUOTED] and Y0TA PR0 like this.
  4. Feb 19, 2020 at 2:16 PM
    #2224
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Exactly!! :censored::censored:
    ntg likes this.
  5. Feb 19, 2020 at 2:18 PM
    #2225
    TheBeast The Beach
    I'm with you.
    ntg likes this.
  6. Feb 19, 2020 at 2:27 PM
    #2226
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    I might be mistaken but thought I read somewhere that both sealants are the same. The black color allows Toyota to identify that the sealant has been reworked vs the grey that is from the factory. The cause of the leak is due to inadequate/un-uniform amount of sealant that is being applied in assembly.
    Black Wolf, BuckWallace and TheBeast like this.
  7. Feb 19, 2020 at 2:28 PM
    #2227
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I don't think the black sealant is "better" or any different than the grey stuff. It isn't that they should use the black sealant - they should git rid of the crappy design. A FIPG for this application is stupid. But, Toyota is a huge fan of the stuff. My current project vehicle is a 1996 Land Cruiser. Right now I am rebuilding the engine and fixing all of the numerous leaks it had. The amount of FIPG that is used on it is sort of staggering.
    WAtundra4x4 and ntg like this.
  8. Feb 19, 2020 at 2:39 PM
    #2228
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    One would think Toyota could just QA the crap out of the part of the engine assembly if they didn't want to change the design...doesn't seem like an insurmountable issue to me....
  9. Feb 19, 2020 at 3:03 PM
    #2229
    TheBeast The Beach
    I'm pretty sure they wont fix it because the next Tundra will have a different engine so we will see cam leaks til the end of the 5.7L...
  10. Feb 19, 2020 at 3:05 PM
    #2230
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    At this point no...but this issue has been around from the beginning. Unless it's a truly tiny % of affected vehicles it just seems like something that wouldn't be too hard to fix from a QA POV - you know - train someone to put on the correct amount of sealant crap and problem fixed!
  11. Feb 19, 2020 at 3:47 PM
    #2231
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    The grey sealant is definitely not the same. It gets hard and brittle over time. The black does not. It stays semi flexible
    Y0TA PR0 likes this.
  12. Feb 19, 2020 at 5:13 PM
    #2232
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Agreed, Toyota should have solved this a long time ago. They tout reliability and constantly moving towards improving, this issue just shows you they are no different then other manufacturers. This should have been fixed back in what like 07...2020 here and we still have cam tower leaks.
    I was also under the impression it was different as well, I think someone mentioned it was more "tacky" then the grey.
  13. Feb 19, 2020 at 6:10 PM
    #2233
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Do the plugs get pulled when this tear down is being done? My plugs need to be changed and while it’s torn down I may as well get them done too
  14. Feb 19, 2020 at 6:16 PM
    #2234
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    Coil packs are removed, but plugs do not need to be removed. But very easy to do at that point
    DalTee[QUOTED] likes this.
  15. Feb 20, 2020 at 4:36 PM
    #2235
    Ralo
    Ralo New Member
    2016 TSS SR5 5.7
    Are there any statistics on the percentage of vehicles affected by the cam tower issue? I looked at 10 different Tundras when I was looking to purchase, and only saw 2 that were leaking badly, and one other that was weeping.
    I concluded that the percentage was small and bought a Tundra anyway. What I didn’t know was that I would continue to worry that mine would start leaking one day. Not a good feeling since I have no warranty.
    Does babying the truck reduce that chances of it leaking? That may be the route I take until it’s gone.
  16. Feb 20, 2020 at 5:32 PM
    #2236
    WNY PAT
    WNY PAT New Member
    Neither my 2017 nor my 2019 are leaking at this point. I’d love to be a fly on the wall in a room with the Toyota engineers talking about this issue. Toyota has the best data at this point but obviously they’re not going to share it. Coming to a forum and starting poll is just going to give a skewed, self-selected sample that would likely grossly overestimate the percentage of those reporting this particular problem. Maybe some Sunday when the weather is warm and the dealers are closed I’ll stop and look a some used Tundras to see if any have evidence of the leak. It really sucks for those stuck with motors that have the leak at low mileage and aren’t getting any support from Toyota.
  17. Feb 20, 2020 at 5:35 PM
    #2237
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    Not to mention this engine is used in nearly $100K vehicles. My guess is it's not wide spread...
    Wynnded and WNY PAT[QUOTED] like this.
  18. Feb 20, 2020 at 5:49 PM
    #2238
    Ralo
    Ralo New Member
    2016 TSS SR5 5.7
    How many miles do you have on your trucks? I have almost 85k on mine.
  19. Feb 20, 2020 at 5:54 PM
    #2239
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That's been discussed before, vehicles like the landcruiser have a Japanese built 5.7 I think. It could be an issue here in the states with the facility that produces the 5.7 for the tundra.
    Mileage isn't a key to this issue, its been all over the map from very low mileage to higher mileage trucks.
    MEGALODON18 likes this.
  20. Feb 20, 2020 at 5:59 PM
    #2240
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    All the ones I’ve done at work have had FPIG (the gasket) applied way to thin at the point where they all leak. Out of the 20-25 I’ve done in 4 years, none have come back leaking. Pretty sure there’s a assembly line fuck up somewhere personally.
  21. Feb 20, 2020 at 6:05 PM
    #2241
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    Which makes it even more (sadly) amazing! Does it just come down to someone in management in San Antonio saying, "Now Jim, you're the FPIG application guy today, so listen to me closely. You have to apply this sufficiently and uniformly on each and every engine", and yet somehow San Antonio messes it up? It doesn't seem like it's a difficult task.
  22. Feb 20, 2020 at 6:30 PM
    #2242
    empty_lord
    05 rollover special
    Robot does it I believe. Some never leak, I can’t explain it lol.
    the jap 5.7s never leak.
    equin and Wynnded like this.
  23. Feb 20, 2020 at 6:33 PM
    #2243
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    So the Japanese robot is more skilled than the American robot? This whole issue exists because they couldn’t email the code for the Japanese robot to San Antonio? Doesn’t make sense...
    In the least they could position a QA dude to inspect each one...
    empty_lord[QUOTED] likes this.
  24. Feb 20, 2020 at 6:41 PM
    #2244
    empty_lord
    05 rollover special
    I honestly have no clue what goes on in the factory. All I know is I’m stuck reselling these. And let me tell ya, warranty time on these is terrible. Eek
    PWMDMD[QUOTED] likes this.
  25. Feb 20, 2020 at 6:52 PM
    #2245
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I've watched a few vids on the re-seal being performed and the general consensus was that it took about 8-10 Hrs. , is that about right?
  26. Feb 20, 2020 at 6:57 PM
    #2246
    WNY PAT
    WNY PAT New Member
    My 2017 CM Limited has 40,000 some and the 2019 SR5 is at about 6,000 something. The wife’s 2013 LX570 just flipped 90,000 and is dry too.
    FWIW, the LXs and the LCs leak too as I visit those forums from time to time. Apparently no magic happens in Japan. I’m fact, my 2017 Tundra is tighter and has less little noises than my 2018 4 Runner, which was assembled entirely in Japan. The two were assembled within 7 months of one another and the 4 Runner only has 13K miles on it or so.
    WAtundra4x4 likes this.
  27. Feb 20, 2020 at 7:08 PM
    #2247
    empty_lord
    05 rollover special
    Roughly. You get paid like 7
  28. Feb 20, 2020 at 7:11 PM
    #2248
    TILLY
    Massachusetts
    Bummer. As a former Tech myself who worked flat-rate, i feel your pain. :(
  29. Feb 20, 2020 at 7:17 PM
    #2249
    empty_lord
    05 rollover special
    Oh trust me, there’s worse ones. But this one ain’t fun, it’s hell on your back! Oh well.
    TILLY[QUOTED] and Y0TA PR0 like this.
  30. Feb 20, 2020 at 7:20 PM
    #2250
    Y0TA PR0
    Rafael
    2017 TRD PRO
    With All the ones you’ve done, has it been all under warranty? Any of them paid by costumers?
