CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Jan 2, 2020 at 8:21 PM
    #2131
    sjvicker
    sjvicker New Member
    I'm looking to buy my first Tundra (upgrade from a 13 Tacoma) and found one that's the right price and options but it might have the seal leaking issue. It has 88,000 miles and looks like its leaked some but doesn't appear to be major. Would it get worse over time? Would you guys still consider purchasing this truck or move on to a different one? From what I've read I'm getting the feeling that its not if but when the leaks will start, is that true?
  2. Jan 2, 2020 at 8:38 PM
    #2132
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    They can leak no matter what age or miles if you read back enough you will see brand new ones and old ones. Keep in mind it should be fixed if it’s leaking. It can be a great truck but that is a major fix in the thousands so if they take that off the price go for it.
    @sjvicker
  3. Jan 2, 2020 at 8:54 PM
    #2133
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Its a Minor leak, no danger, of fire even. Look deeper into the vehicle, this isn't why not to buy it. And it doesn't need to be repaired unless it really bothers you.
    Luck and enjoy those Toyotas. : ^ )))
    Rex Kramer likes this.
  4. Jan 2, 2020 at 8:58 PM
    #2134
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Many have reported issues sub 30,000 miles. Unfortunate.
  5. Jan 2, 2020 at 9:03 PM
    #2135
    Trdwillie14
    Billy
    2014 trd off road
    That being said I Bought mine the passenger side leak. Yota covered it I love my truck before and after. Good luck
    TheBeast likes this.
  6. Jan 3, 2020 at 4:03 AM
    #2136
    WNY PAT
    WNY PAT New Member
    Western New York
    2025 GMC Sierra 2500HD AT4 2017 CM Limited (Sold) 2019 CM SR5 l
    I see picture after picture, case after case of this issue and think to myself... what corners is Toyota going to cut on the next Tundra? This is such an easy fix... and a clear defect happening right at the factory... yet Toyota doesn’t bother to fix it. I don’t get it. Then I read about the transmission cooler delete on the 2019/2020s and really hope that Toyota isn’t going the way of Honda/Acura and cashing in on their hard earned reputation for quality and durability by charging top dollar for very average cars until consumers catch on....
    equin and BuckWallace like this.
  7. Jan 3, 2020 at 7:47 AM
    #2137
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I would have thought they learned their lesson with the runaway Camrys.
    equin likes this.
  8. Jan 3, 2020 at 4:01 PM
    #2138
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    What runaway camrys are you talking about?
  9. Jan 3, 2020 at 4:58 PM
    #2139
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  10. Jan 3, 2020 at 5:23 PM
    #2140
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  11. Jan 3, 2020 at 5:26 PM
    #2141
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I guess I'd better get sunglasses and sunscreen for my computer... o_O
    Wynnded[QUOTED] likes this.
  12. Jan 3, 2020 at 5:48 PM
    #2142
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    I work for Toyota and i am well aware of the recall.
    As for a runaway camry caused by a person stacking multiple floor mats is two different things.
    The recall was implemented to put safeguards in so that if the accelerator was depressed and stuck open while applying brake the throttle would default to an idle.
    The other part was to trim the pedal so to not interfere with a bonehead getting the floormat pushed under it.
    There was no proven vehicle unintended acceleration. All was alleged.
    This recall was spotlighted so much at a time when our government was bailing out US auto manufacturers.
    But when GMs ignitions were shutting off causing crashes and deaths, that was quieted up quickly.
    viha22, stewtopia, P-Factor and 2 others like this.
  13. Jan 7, 2020 at 3:32 PM
    #2143
    tundra4466
    tundra4466 New Member
    2020 1794 4x4
    My 2011 has 148k on it, never had an issue. I thought I had a rear main leak starting but while doing my brakes today noticed both sides have the cam leak, hopefully it’s collecting at bottom the of bellhousing and I don’t have the rear main as well but we’ll see.
    So I noticed it has the grey rtv, I bought the truck as certified used in 2013 with 45k on it or so. Wasn’t this known well before 2013? So much for the we update everything certified bs.. of course it waited until my extended warranty ran out to start leaking but still..
  14. Jan 8, 2020 at 1:48 PM
    #2144
    Blue4x2
    Blue4x2 New Member
    2007 SR5 Double Cab
    AMP power steps Corsa catback exhaust BHLM Toytec Boss Aluma series Leveling kit 295/60 Falken WildPeak AT3 20” XD Monsters II w/ 0 offset
    FB78DD79-7EAD-4648-9BEA-9C685A0A513E.jpg 07C983C5-6C1D-48A2-B3DD-ECE74BD75869.jpg Am I unfortunately part of the club now?
  15. Jan 8, 2020 at 2:35 PM
    #2145
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Need to take a pic towards the rear of the engine through the fender well just below the valve covers.
  16. Jan 8, 2020 at 3:11 PM
    #2146
    Johnsonman
    Austin
    Sequoia
    If it was a recall (?) then Yes, otherwise only if they see the problem Then.
  17. Jan 8, 2020 at 3:55 PM
    #2147
    tundra4466
    2020 1794 4x4
    I don’t think it was a recall. I’m a faithful Toyota guy I guess I was just hoping for good faith on they’re part. But that said it made it to 148k without costing me a
    Dollar so I really can’t complain too much.
  18. Jan 8, 2020 at 4:29 PM
    #2148
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    A known issue like this shouldn’t cost you a dollar regardless of miles. One issue Toyota really has dropped the ball on.
  19. Jan 8, 2020 at 8:04 PM
    #2149
    Phishindude
    Phishindude New Member
    Both cam towers have been seeping for months. Enough now to smell oil after a short drive. Noticed some oil on the garage floor near the rear diff not long ago. Sure enough its seeping too. Went away for a few weeks and the truck barely started when I returned. Looks like the battery is failing too. Its a 2018 with just under 8k miles. Thanks a lot, Toyota...WTF
  20. Jan 11, 2020 at 12:09 PM
    #2150
    Filip G
    Filip G New Member
    Filip
    2016 Crew Max 1794 4x4 Sunset Bronze Mica
    DF974BA8-014E-49E2-BD21-FBF8A56875DC.jpg 3F2A836E-5FED-4C6D-ACFE-9B51FA664768.jpg 392773EC-FCAF-4646-B640-81DC2763245B.jpg Hello all,
    I love/hate this forum, wifey alerted me to a burning smell in a cabin of 2016 - 1794 edition. Just passed the 50K mark on my truck a day or so ago, after a little digging with the help of the this forum, I discovered a cam tower leak on my Tundra. Fair to say I am beyond furious, called TC, opened a case to have every detail documented, filed a complaint with NHTSA and will not stop there. Went to a dealer, took 10 seconds for the dealer to confirm the leak. Dealer told me they get approximately 1 per year, just so it happens they are working on one currently, I don’t think I buy the story.
    Keep my fingers crossed, 2016 with 50 K, expecting it to be covered by warranty without a “peep” from Toyota. Unbelievable!!!!!!!!
    I am against the “open heart surgery” but when noxious fumes enter the cabin and make my family sick it is a different story. I guess I am member of the cam leak as of now.
    equin, WAtundra4x4 and jtwags like this.
  21. Jan 11, 2020 at 12:47 PM
    #2151
    tundra4466
    2020 1794 4x4
    Good luck I sent them an email last week about mine and no response. I changed my diff and t case oils today and it’s looking like I do have a rear main leak starting too. What a mess that’s going to be to fix a couple seals.
  22. Jan 11, 2020 at 3:50 PM
    #2152
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    While i have seen a few leak, we service approximately 12 tundras per day on average. With all sorts of high mileage. We havent seen one leak in 2 years.
    It is not as common as you think.
    And i believe(just a theory) that its more common in colder areas where there is such a temp swing. Different surfaces contract and swell with temperature.
  23. Jan 11, 2020 at 5:25 PM
    #2153
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    My '18 was doing it, I'm in SC.
  24. Jan 11, 2020 at 5:33 PM
    #2154
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I think its more common then people think, I live in a warmer climate and had it and neighbor down the street also has it. Both on passenger side.
    This is what pushed me to have mine done, I only made it to 21k when I discovered the leak. But the fumes in the cab I couldn't deal with.
    BuckWallace and equin like this.
  25. Jan 12, 2020 at 7:31 PM
    #2155
    DrGonzo
    DrGonzo New Member
    Brad
    So what's the verdict on this? Looks like my '10 is leaking. Call Toyota?
  26. Jan 23, 2020 at 1:34 PM
    #2156
    BobaChris
    BobaChris New Member
    2017 Cement Grey Tundra TRD Pro
    So I checked my 2017 TRD Pro and it looked to have a small leak on the passenger side. I took it to my local dealership and they confirmed that it's leaking a little oil, but not enough to constitute having it changed under warranty. I'm currently at 55,900 miles, so close to the end of warranty. Wasn't happy they wouldn't cover it. I was told it would have to be dripping oil for them to replace the seal.
    Anyone else have this issue when dealing with their dealership? Should I take it to another dealership?
    Y0TA PR0 likes this.
  27. Jan 23, 2020 at 1:43 PM
    #2157
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I'd try another dealership.
    BobaChris likes this.
  28. Jan 23, 2020 at 2:03 PM
    #2158
    owb2gp
    owb2gp New Member
    ID
    I would try another dealership.
    My dealership actually brought it up when I was getting my oil changed. Only one side was leaking but I was able to talk to the service manager into doing both sides under warranty. My truck had very low miles, maybe 8,000 or less.
    georgiey22 and BobaChris[QUOTED] like this.
  29. Jan 23, 2020 at 3:08 PM
    #2159
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    My 2013 Tundra CM with 60k has a very slow leak on the passenger side. Every 20k I just wipe it off and I am good to go another 20k. No smell in the cab yet, thank goodness. Driver side is dry as a bone.
    jtwags likes this.
  30. Jan 23, 2020 at 3:35 PM
    #2160
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    Put some old oil in a squirt bottle and give it a few pumps along the seal area then bring it to another dealer in 2 thousand miles. I would try anything to get it covered
