CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. May 22, 2019 at 9:13 PM
    #1831
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Awesome! Good to hear!
  2. May 23, 2019 at 6:51 AM
    #1832
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I saw this thread before I bought my Tundra in Feb. 2018. So far my Tundra has been great. At 10K miles, my engine has no sign of a leak.... Yet.
    After reading all the woes the F150s on the Ford forum were having, I decided to go with a Tundra. My old 99 F150 was running good, but it was costing me $$ with replacing the AC, leaky windshield, etc. I did not want to get stranded in the mountains here. There are areas of no cell coverage and tow trucks are not available in remote sites.
    phabej and equin like this.
  3. May 23, 2019 at 10:16 AM
    #1833
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Fortunately, a seeping or leaking cam tower shouldn't leave your Tundra stranded if that ever happens.
    WAtundra4x4[QUOTED] and TheBeast like this.
  4. May 24, 2019 at 10:59 PM
    #1834
    Bigbird57
    Bigbird57 New Member
    I used this info to purchase a 2016 Tundra SR5 4WD.
    The dealer repaired both sides as part of the deal. Mine has 79k on the clock. Their price would have been $3200.
    I inspected three used Tundras and two had the cam tower leak. This is a very helpful forum.
  5. May 27, 2019 at 5:09 PM
    #1835
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Is this it?
    Might be too much light on it for ya.
    Y2rW3qdT6ouKvCXvCa2J2slNixvDdAo5ctIuqhhF_f839a5cfcccb93f42281b5d6b10f7c3e21fbfb22.jpg
    Is it always towards the back of the block?
  6. May 27, 2019 at 5:22 PM
    #1836
    Bigbird57
    Yes
    Mine was there on the passenger side.
    It can occur on either. Have them do both sides. They use a black sealant rather than gray.
    Hold them accountable!
    Moon Puppy likes this.
  7. May 27, 2019 at 5:34 PM
    #1837
    ktmhauler
    ktmhauler New Member
    GA
    2019 SR5 Dbl 4wd 5.7
    So I got about 800mi on my 19' Tundra with the 5.7. I'm trying to keep up with this thread, but what should I be looking for to see if I have the problem?
  8. May 27, 2019 at 5:38 PM
    #1838
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    I looked in the wheel well from the front of the tire looking back into the engine bay, block. You'll see that woven mesh, think it's some heat shield. Should be the seam on the block right above that location.
  9. May 27, 2019 at 5:50 PM
    #1839
    ktmhauler
    GA
    Shouldn't it really be a gasket and not just a sealant?
  10. May 27, 2019 at 5:59 PM
    #1840
    ktmhauler
    GA
    Thanks I just went out for a quick peek and looks good so far from what I can see. Don't see any sealant squeezed out either like in the pic on the petition. Does this affect the Flex Fuel version of this engine as well?
  11. May 27, 2019 at 6:02 PM
    #1841
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    I've looked several times since I've had the truck, picked it up Labor day, 2018. Never saw a sign of it till this evening. Just rolled 19k on it. Can't answer about the Flex, don't think so but I'm sure someone will correct me.
  12. May 27, 2019 at 6:22 PM
    #1842
    Bigbird57
    Watch the rounded area of the cover towards the fire wall. Look just above the front tires and shine a good light all along the sealant line. It is not difficult to see.
  13. May 27, 2019 at 6:23 PM
    #1843
    Bigbird57
    Yes
    All versions can leak. Especially if your sealant is gray.
    TheBeast likes this.
  14. Jun 8, 2019 at 10:38 AM
    #1844
    grizz2402
    grizz2402 New Member
    Robert
    2013 Tundra TSS
    Nitto Grapler Wheels, Rims and running boards
    Did a search on the leak. Found this forum. Signed up, add me to the list. 2013 Tundra Crew TSS, just over 76K miles. Had oil changed 3 weeks ago at dealership. Few days later, oil spots in the garage floor - nothing major. Took it back in following weekend. Advised it was dip stick o-ring. $150 later (was not happy, save for another thread) was also advised of the “minor-not to worry” cam leak. Service manager said if it gets worse, gonna be pricey. Could run up to $8K because they have to pull the engine or lift the cab off to repair. Talked to the technician, he said not to worry and if he does it, doesn’t have to pull the engine. Not sure what to do other than try not to worry about it.
  15. Jun 8, 2019 at 11:02 AM
    #1845
    P-Factor
    P-Factor New Member
    NEW!! CAM SHAFT TOWER SEAL LEAKING DETECTION KIT!
    Rex Kramer, TheBeast and RLHULK like this.
  16. Jun 8, 2019 at 11:10 AM
    #1846
    P-Factor
    P-Factor New Member
    For me... I would never let any shop touch my 5.7 for some of the pictures shown on this thread. The repair is very invasive and opens opportunities for other leaks and unrelated problems. Unless it is truly a fire risk, I'd keep an eye on it and just clean it periodically if not threatening.
  17. Jun 8, 2019 at 12:09 PM
    #1847
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    After reading 13 pages on this topic, I do not see one 2019 with this issue. Odd thing is there are several 2018s that had a leak very early in life.
    Calling all 2019 owners, does anyone have a cam tower leak to report?
  18. Jun 8, 2019 at 12:13 PM
    #1848
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Yeah I get you, but some of us just don't want to tolerate leaking oil from a brand new truck. Unfortunately my 2018 did develop another issue as a result of the repair and the dealer ended up buying it back. It's just very frustrating and embarrassing that a company like Toyota hasn't resolved this issue after 12 years.
    Boosted4runner likes this.
  19. Jun 8, 2019 at 12:37 PM
    #1849
    P-Factor
    P-Factor New Member
    I hear you and I understand as a 2018 owner as well and will do the same if it ever becomes a potential liability issue or I see/smell it progressing.
  20. Jun 8, 2019 at 6:27 PM
    #1850
    TheBeast The Beach
    yep we have some 2019 with very low miles too...
  21. Jun 8, 2019 at 6:28 PM
    #1851
    TheBeast The Beach
    I would say all years have it except maybe 2007-2009
  22. Jun 8, 2019 at 7:23 PM
    #1852
    georgiey22
    Thanks for the note @TheBeast. Do you work for Toyota?
  23. Jun 8, 2019 at 7:29 PM
    #1853
    TheBeast The Beach
    I do not. "we" as tundras.com members. ;)
    georgiey22[QUOTED] likes this.
  24. Jun 9, 2019 at 8:10 PM
    #1854
    georgiey22
    Did you end up completing the repair?
  25. Jun 11, 2019 at 7:17 AM
    #1855
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    I know the guy who fixed mine, he’s a competent tech. It’s not that big of a deal. 23k miles later and no leaks and no issues related to the repair.
    georgiey22 and Y0TA PR0 like this.
  26. Jun 11, 2019 at 10:16 AM
    #1856
    Bigbird57
    My dealer needed a week to make the repair. I did not pester them and I hope it gives a good result. I do realise it is very involved, that is why it was billed at $3200. This was covered on my behalf.
    georgiey22 and Waterboy45661 like this.
  27. Jun 11, 2019 at 5:54 PM
    #1857
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Hi Everyone, well it happened to me. I just checked and I have oil leakage on the passenger side. I have a 2013 Crewmax with 56k. Not sure what to do next. Any advice would be greatly appreciated. I have the grey gasket seal.
    georgiey22 likes this.
  28. Jun 11, 2019 at 5:55 PM
    #1858
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Go to the dealer—they/Toyota may be able to help you out since you're probably not too far out of your powertrain warranty and are still under 60k miles. Sorry and good luck!
  29. Jun 11, 2019 at 7:01 PM
    #1859
    mtndds98
    mtndds98 New Member
    Any good toyota dealerships in SoCal that have experience in doing this type of work? Please let me know. Thanks again.
  30. Jun 11, 2019 at 7:42 PM
    #1860
    mtndds98
    mtndds98 New Member
    BTW guys please sign the petition for a Toyota recall. If you have a Tundra its not if but when you will have an oil leak. Pissed as hell.
    JRider600RR and WrigglingWilly like this.
