CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Feb 12, 2018 at 5:39 PM
    #151
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome! Did mine almost 30,000km (18,600miles) ago and runs like new still!! Love it, pulled my trailer and everything.
  2. Feb 12, 2018 at 7:05 PM
    #152
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Mine has just started to seep in that same area, passenger side in the rear near the tab. I to am hoping maybe a little weeping and nothing else. I know members have had it repaired and all is well, but this is going to highly depend on who's working on the truck. Just not going to be the same once it's cracked open and put back together.
  3. Feb 13, 2018 at 12:46 PM
    #153
    fishman1
    fishman1 New Member
    2017 TundraTrd off-road crewmax
    thought I would share a photo of what I am seeing.. I still say it’s a leak...AE313E81-3D81-4DEE-939F-7ED7B543C395.jpgAE313E81-3D81-4DEE-939F-7ED7B543C395.jpg 6C9F5862-B3EF-4DFD-807A-B35852BCBF10.jpg
    Wynnded and TheBeast like this.
  4. Feb 13, 2018 at 1:00 PM
    #154
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Hit it with some simple green and spray it off. Clean it up and then monitor it.
    My 2010 was fairly dirty around the wheel wells, fender skirts, and sides of the motor when I bought it. Initially I was convinced I had a cam tower seal leak since the area was so dirty and grimey. I soaked it all with engine degreaser, washed it, then simple green, washed again. Over 3k since I cleaned it up and not a drop of anything that looks like oil.
  5. Feb 13, 2018 at 3:19 PM
    #155
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That's what mine looks like as well and in the same spot. What's crazy is it looks like there's a good bead FIPG there already. I'm wondering if this ow20 oil is part of the issue, I wonder if the early 5.7 Tundra's ran 5w30.
  6. Feb 13, 2018 at 3:54 PM
    #156
    fishman1
    fishman1 New Member
    I spoke with another local dealer this afternoon and will be taking in in Thursday for a second opinion. The service manager at that dealership knew exactly what I was talking about and informed me they have done dozens mostly 2013-14 and one 2017 so far and said that is what it sounds like. He also said it can be a hastle getting reimbursed by Toyota for this warranty work so some dealers kinda ignore it until it becomes a major fire hazard and they have to deal with it. He also said the cause can be related to the fact that the machined surfaces weren’t cleaned properly, still having residual oil on them upon assembly at the factory therefore leading to a not so good seal. If this is in fact the problem which I will find out on Thursday he did say they haven’t had any come back and customers have been pleased.... We will see and I will post the diagnosis, maybe it’s just a defective valve cover seal..staying positive...
    TheBeast likes this.
  7. Feb 13, 2018 at 6:32 PM
    #157
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, looks wet to my eyes. I even sounds like the dealer you're talking with might be trustworthy...the service manager anyway.
    TheBeast and darkknight2014 like this.
  8. Feb 14, 2018 at 11:25 AM
    #158
    Gonehiking74
    Gonehiking74 New Member
    Olympia, WA
    2014 SR5 4.6L Crewmax
    In my research it appears that this problem only plagues the 5.7L. I haven't found anything on the 4.6L however folks are mostly only posting the year and mileage of their Tundras. Anyone having the problem with the 4.6's?
  9. Feb 14, 2018 at 12:02 PM
    #159
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    2015 DC w/ 4.6L no signs of any leak but curious if it's an issue with the 4.6L ?
  10. Feb 14, 2018 at 2:29 PM
    #160
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Not raining today so I was able to crawl under my truck today and assess, I'm gonna have to make an appt And get mine to the dealer. It's leaking pretty good, crossmember is covered with oil and grime and it's dripping down the manifold heat shields.
    BTBAKER likes this.
  11. Feb 14, 2018 at 2:39 PM
    #161
    TheBeast The Beach
    yep. that's it
    good pictures too. That oil burns there too so you might smell something
  12. Feb 14, 2018 at 2:52 PM
    #162
    blizz86
    blizz86 New Member
    which dealership ended up taking care of you?
    fishman1 likes this.
  13. Feb 14, 2018 at 2:52 PM
    #163
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Anyone have a pic showing exactly where we should be looking?
    Eclipsed & Floating likes this.
  14. Feb 14, 2018 at 2:55 PM
    #164
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Look at the picture above your post, see where the black sealant is? That's the area you need to focus on.
  15. Feb 14, 2018 at 3:25 PM
    #165
    fishman1
    fishman1 New Member
    I will find out tomorrow on mine but was wondering what mileage you all are at when you had yours fixed or are seeing the leak? I am only at 8400 miles!! Has anyone been successful getting an extended warranty due to this obvious defect?? I will update tomorrow once I have the second dealer look at it...
  16. Feb 14, 2018 at 3:34 PM
    #166
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I did my last oil change at 15k in August and the leak wasn't there, I'm at 21k now and the leak is there. I noticed it this weekend while rotating my tires, so my leak came on pretty quickly. I have been wanting some 2018 headlights maybe I will just trade the truck in, let someone else deal with it.
  17. Feb 14, 2018 at 3:36 PM
    #167
    TheBeast The Beach
    @Vizsla ..I believed his was at 3,000 miles...on a new truck
  18. Feb 14, 2018 at 4:16 PM
    #168
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    :(This damn leak is like a virus or some shit... Confirmed today at the dealer for service and mine is leaking ...just a smidge barely even noticeable but starting none the less. We are monitoring it for now. I am at 21700 miles.
  19. Feb 14, 2018 at 4:18 PM
    #169
    TheBeast The Beach
    at least we all know the symptoms now and what to do. Good amount of knowledge here.
  20. Feb 14, 2018 at 8:44 PM
    #170
    stolentricycle
    stolentricycle New Member
    Orange County, CA
    2013 4x4 Tundra
    AutoNation Toyota of Irvine.
  21. Feb 15, 2018 at 5:19 AM
    #171
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I have an appt. booked for mine on Tuesday, see how it all goes.
  22. Feb 15, 2018 at 5:30 AM
    #172
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    has anyone had a supercharger and had this problem develop? Was there any pushback from the dealer?
  23. Feb 15, 2018 at 5:48 AM
    #173
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    30 years of working on Jap cars......if that seal is leaking, especially at low miles, then there is something wrong to the point it should be a recall. Not common on Jap engines. So make sure your valve cover gasket isn't leaking. This so commonly mistaken for a cam seal leak. When I worked out at Phoenix engines, in order to keep your engine warrantied, you had to come back to the shop for the first several oil changes, and part of the service was to torque all oil pans, that meaning valve covers.
    TTund16 and 757TUNDRA like this.
  24. Feb 15, 2018 at 9:00 AM
    #174
    TheBeast The Beach
    at this point I think Toyota is aware of it and keeping it low profile. A recall would be way too expensive for them. I think they are waiting on the trucks affected to roll in at the dealership and they fix them under warranty to keep owners happy. I don't think I read anyone had to pay on its own pocket. This is definitely something that shows up before the 5 years/60,000 miles warranty is over. My 0.02
  25. Feb 15, 2018 at 11:46 AM
    #175
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    I have an appointment to get mine looked at on Sat (2015 with 49k on it). I've been smelling a little bit of a burnt oil smell on the driver side especially if my truck sits for a couple days. Want to definitely get it taken care of before the powertrain warranty is up. Hopefully they don't try and give me the run around.
    Y0TA PR0 and TheBeast like this.
  26. Feb 15, 2018 at 1:23 PM
    #176
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I agree, I also think is at this point it has not been solved at the production level that it must be a design flaw. Pretty sad that this is still going on and owners have to deal with it. Yes its usually covered under warranty but having your engine tore down like this doesn't leave you with the best feeling, there's a lot of room for error or contamination into the engine. I love this truck and its been great so far but I will take the little things breaking like on my previous truck (Silverado) vs major engine work..cmon Toyota.
    BuckWallace and TheBeast[QUOTED] like this.
  27. Feb 15, 2018 at 1:26 PM
    #177
    Murph28
    Murph28 New Member
    2010 Blue Streak Metallic Double Cab
    I had to pay some out of pocket. They did lower the price but it was not free. I have a 2010 with 67000 miles on it.
    TheBeast[QUOTED] likes this.
  28. Feb 15, 2018 at 1:33 PM
    #178
    TheBeast The Beach
    yes that sucks. Make sure to keep the receipts in case they issue a recall or extend warranty later on.
  29. Feb 15, 2018 at 1:36 PM
    #179
    Murph28
    Murph28 New Member
    I have the receipts and the ones for the bed rust just in case they do a recall or extend on that also.
  30. Feb 15, 2018 at 4:04 PM
    #180
    Vizsla
    Vizsla 2 = 2.5
    Yep. It leaked from new, and was not driveable at 3k. Started seeping again at 9k, so had to go. My 09 seeped, but never enough to repair, it is not considered abnormal to seep oil(rare for Toyota though, usually tight). My 2018 is leaking from the rear main now...
    My take, I have looked under every Tundra I could over the past few years, probably 150+. Half had seepage or leaks. Everything about using that type of seal there has to be perfect, clean, flat, placement and size of FIPG, even has a time limit between sealant application and tower install. It is worth examining thoroughly before warranty expiration, it’s $$$.
