CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Mar 30, 2019 at 9:08 AM
    #1651
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I think this is the referenced thread.
    https://www.tundras.com/threads/cam-leak-fire.40688/#post-1035463
    Investigation saying cause was the oil leak looks suspect to me. Motor oil makes a good fuel for starting fires, but it is not exceptionally easy to light off. Motor oil is also not volatile enough to start a raging conflagration without a lot of highly flammable fuel being added quickly before it dies off and begins smoking. Not a lot of such fuel in an engine compartment; oil fire would have to last long enough to burn through a fuel line.
    equin, Finch[QUOTED] and Black Wolf like this.
  2. Mar 30, 2019 at 12:01 PM
    #1652
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    This cam tower do you smell it burning off the exhaust?
    And if It had a rear main leak does anybody think I would smell it up by the front of the truck like I do.
  3. Mar 30, 2019 at 12:11 PM
    #1653
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I would smell mine right in the wheel well after getting out. I don’t know if mine was off the exhaust or dripping down on the heat shield but it was very noticeable
    Vince[QUOTED] likes this.
  4. Mar 30, 2019 at 12:14 PM
    #1654
    Vince
    Vince New Member
    Vincent
  5. Mar 31, 2019 at 1:08 PM
    #1655
    Jobthegiant
    Jobthegiant Super extra premium member delux
    2012 Tundra 2WD basically stock
    TRD wheels, Fog lights, Bed Liner, Under seat storage, Lots of scratches and rub marks
    Sup dudes. Just learned about this issue yesterday. Went and checked my truck and saw some oil on the passenger side seal. Luckily my CPO warranty is good till August. I'll simple green the oil off and drive a few hundred miles to confirm, but I'm guessing I'll be at the dealer getting diagnosed next week. Any advice on how to deal with the dealer?IMG_20190331_105356.jpg
  6. Mar 31, 2019 at 1:09 PM
    #1656
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    My guess is that the dealer/Toyota will call that a "seep" and won't want to fix it, unfortunately.
    BTBAKER likes this.
  7. Mar 31, 2019 at 1:18 PM
    #1657
    Jobthegiant
    I pressure washed it yesterday, so I think only the residue is left. I suspect it will be an actual leak after some drive cycles. We'll see. Otherwise I'll have till August to call / pressure everyone at Toyota. Wish me luck.
  8. Mar 31, 2019 at 1:21 PM
    #1658
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Ah, gotcha. Yeah, I wouldn't touch it again and let it actually leak so they can approve the fix. If it's leaking there shouldn't be an issue getting it repaired, but you might have to pressure them to approve both sides of the other isn't leaking (and you want them to take care of both).
  9. Mar 31, 2019 at 1:53 PM
    #1659
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Your truck has a generous amount of the gray gasket maker and it is seeping. That is one of the better beads of sealant I’ve seen. This gasket maker is simply a poor choice for our application. Really wish they would have selected a stronger gasket maker. Sorry you are having to deal with this.
  10. Mar 31, 2019 at 2:01 PM
    #1660
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I think its the quality of the FIPG and the fact it is very inconsistently applied...some trucks have generous amounts while other do not.
    georgiey22[QUOTED] likes this.
  11. Mar 31, 2019 at 6:48 PM
    #1661
    Jobthegiant
    Curious if anyone in socal has had this work done, with a positive outcome, and could steer me in the direction of the dealer that did the work, or steer me clear of a problematic one. I do 90percent of my own maintenance, and go to a trusted independent shop when a job is too big for me.
  12. Apr 2, 2019 at 8:55 AM
    #1662
    vladimir1986ca
    vladimir1986ca New Member
    Helpful post. I am a Toyota lover and bought close to 10 vehicles from Toyota, not to mention that my family and friends-most drive Toyota and I always brag about its reliability. So, I have replaced tires yesterday on my 2010 LC with only 19k miles and been told by the dealership that I have cam tower leak on passenger side. I have called Toyota of America number before I join legal action and give them hell of a negative publicity-the bottom line is I won't be paying to replace something that is defective. Hope they can fix the issue before it escalates.
  13. Apr 2, 2019 at 12:08 PM
    #1663
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This is interesting as it's my understanding that all the LC 5.7Ls are assembled in Japan...
    TheBeast likes this.
  14. Apr 2, 2019 at 12:50 PM
    #1664
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  15. Apr 2, 2019 at 12:59 PM
    #1665
    woodcan
    woodcan New Member
    D
    TX
    Shopping for a Tundra
    Wow, that's some low mileage for a 2010
  16. Apr 2, 2019 at 1:01 PM
    #1666
    woodcan
    woodcan New Member
    D
    TX
    I'm curious, is this engine design and setup with the CAM tower vastly different than other manufacturers that is making this more susceptible or is the consensus just the sealant methodology used in manufacturing?
  17. Apr 2, 2019 at 1:23 PM
    #1667
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    @dcsleeper408 its covered under my Route 66 warranty holllerrrrrrrr
    dcsleeper408 likes this.
  18. Apr 2, 2019 at 1:34 PM
    #1668
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :thumbsup:
  19. Apr 2, 2019 at 2:24 PM
    #1669
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Some MFGs don't use overhead cam setups lmao
  20. Apr 2, 2019 at 2:48 PM
    #1670
    Trdwillie14
    Billy
    2014 trd off road
    @dcsleeper408 u know anyone who can do the work that’s good ?
  21. Apr 2, 2019 at 3:38 PM
    #1671
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Some have it where the cam cradle portion I is casted as part of the cylinder head.
    For our design I think it's just too much for fipg to keep that area sealed up. This won't be solved for good until Toyota revamps the 5.7 or we get another motor otherwise they would of fixed it by now.
    woodcan[QUOTED] likes this.
  22. Apr 2, 2019 at 5:23 PM
    #1672
    AZTundra
    Paul
    Phoenix, AZ
    Mine is "seeping" more than that and Toyota wouldn't approve mine at this point. Good luck, maybe your dealer is better to work with than mine. I was told they had to take pictures and send them into corporate for approval due to the cost. They said wasn't bad enough to get approval. Let us know how it turns out.
  23. Apr 2, 2019 at 6:11 PM
    #1673
    Lake.Life24
    Shawn
    Upstate, NY
    Just heard from the dealer today. The master mechanic wrote it up as a leak because he saw a bead of oil that was about to drip. He said to him that constitutes a leak. So, it goes in on the 17th and Toyota says it should take 13hrs. So I hope the mechanic doesn't feel rushed. We will see how it goes....
    woodcan likes this.
  24. Apr 2, 2019 at 7:02 PM
    #1674
    AZTundra
    Paul
    Phoenix, AZ
    Glad you didn't get the runaround. I'm going to have them take a look at it each oil change and maybe one of those visits it will be bad enough to get approved. I just want it taken care of before I hit the 60K mark and it's no longer covered under the powertrain warranty.
  25. Apr 2, 2019 at 8:08 PM
    #1675
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    So ..would this be a good time to throw that supercharger on?
    Sas, Lake.Life24[QUOTED] and AZTundra like this.
  26. Apr 2, 2019 at 8:11 PM
    #1676
    Lake.Life24
    Shawn
    Upstate, NY
    I was thinking that earlier today! I will get a quote might be the first major mod
  27. Apr 2, 2019 at 8:11 PM
    #1677
    AZTundra
    Paul
    Phoenix, AZ
    I was wondering the same, but doubt they'd give much discount on labor if any.
    Lake.Life24 likes this.
  28. Apr 3, 2019 at 5:53 AM
    #1678
    Trdwillie14
    Billy
    2014 trd off road
    Does anyone know after you fix this if it just comes back or if there is a aftermarket part that does a better job then the stock ?
  29. Apr 3, 2019 at 9:42 AM
    #1679
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Had Toyota look at my truck today and yes it does have a leak on the driver side. They gave the ok right away. Start working on it tomorrow. I'm Glad I didn't have to jump through any hoops.
  30. Apr 3, 2019 at 10:19 AM
    #1680
    Lake.Life24
    Shawn
    Upstate, NY
    The head mechanic told me that with all the seals he has fixed, toyota gives them a black sealant. Which from what I have read, this is what is used in Japan. For some reason they use gray when the make the cars in the US.
