CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Feb 12, 2019 at 5:57 AM
    #1531
    2015Crewmax
    2015Crewmax New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
  2. Feb 12, 2019 at 6:15 AM
    #1532
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I'm in the same boat and I'm getting it fixed sooner rather than later.
  3. Feb 12, 2019 at 12:10 PM
    #1533
    Danbizzle2009
    Danbizzle2009 New Member
    MAINE
    2016 DC Tundra SR5
    Some may remember I was told by my local dealer that I had a seep, not a leak and they would not be replacing. It was recommended i take it to the dealer i purchased it from to get a second opinion. I did so and was told the following:
    "Sorry for the delay. The ruling is that a seep Is not considered a failure. There has to be a visible leak to qualify for warranty replacement. The dealer in your area is correct."
    Just an update.
    Y0TA PR0 likes this.
  4. Feb 12, 2019 at 1:50 PM
    #1534
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    If oil is getting to the outside of the engine them it's leaking somewhere. Wow. Did you sign up with the law firm staying the class action suit?
  5. Feb 12, 2019 at 2:56 PM
    #1535
    Danbizzle2009
    MAINE
    2016 DC Tundra SR5
    No I haven't yet. I don't have any legal experience with lawsuits and such and really don't know how. But, I'm with you and have been up and down the river on that; a seep IS a leak. If water is seeping in through the hull of a boat, then it's leaking and it likely gets worse. Same thing. So by the time my warranty goes to expire, I can guarantee there will be visible oil dripping down on the heatshield ;)
  6. Feb 12, 2019 at 3:04 PM
    #1536
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    All you have to do is go to http://www.classlawdc.com/2018/07/18/toyota-camshaft-tower-seal-leaking-class-action-investigation/ and fill out the little questionnaire and they’ll call you for more information. Takes about 5 minutes. After that it’s just that you’ll be compensated for the fix should the lawsuit go through. SO what do you have to lose? About 5 minutes, that’s all....
    equin and Y0TA PR0 like this.
  7. Feb 12, 2019 at 6:49 PM
    #1537
    ScarWars
    ScarWars New Member
    2019 Toyota Tundra TRD PRO Super White
    I just picked up a 2019 last weekend. I did smell a light burning smell today after I pulled in the garage.
    I stuck my head under the driver side fender and I could smell the burning smell.
    Just came across this thread and went out with a flashlight to check. It doesn’t look like anything is leaking. Everything looks dry.
    I hope it’s just the new burning off. 500 mi on the clock.
  8. Feb 12, 2019 at 6:55 PM
    #1538
    Danbizzle2009
    MAINE
    2016 DC Tundra SR5
    Yes, new motors will put out funny smells until its properly broken in. Just keep an eye out for this leak as you mileage climbs friend.
    ScarWars[QUOTED] likes this.
  9. Feb 12, 2019 at 7:58 PM
    #1539
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    The tech that did mine says he gets 1-2 per month, and he just works the afternoon shift.
  10. Feb 13, 2019 at 6:18 PM
    #1540
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    Pics of the black sealant so I know exactly where to look? Thanks.
  11. Feb 13, 2019 at 6:27 PM
    #1541
    ScarWars
    ScarWars New Member
    Just do a quick search on cam tower leaking and there are members with pics after dealer fixed. After the fix it’s black sealant. Factory sealant is gray.
  12. Feb 13, 2019 at 7:16 PM
    #1542
    Waterboy45661
    Waterboy45661 New Member
    Tommy
    07 Red SR5
    equin likes this.
  13. Feb 14, 2019 at 3:03 PM
    #1543
    Adam New Member
    Just got mine back from getting fixed. This is what they said on the ticket. Customer states there is an oil leak at the back of the motor on passenger side. SOP Parts. Checked and verified oil leak from the piss side cam cradle. Also noted an oil leak at the timing cover. Poor adhesion from the sealer used from factory is the cause. Disassembled and resealed pass cam cradle and timing cover. reassembled the engine(eep!) cleaned oil and residue from the compartment, test drove and no leaks or codes found.
    Jsena, 040Tundra and equin like this.
  14. Feb 14, 2019 at 3:03 PM
    #1544
    Adam New Member
    is the timing cover a normal part of this as well?
  15. Feb 14, 2019 at 3:05 PM
    #1545
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Not usually. I think early on when this issue first started appearing they took off the timing cover, but I think as techs got better at the repair they could do it without removing the timing cover. Mine was not removed. However, it's good they took care of yours since they found it leaking.
    TheBeast likes this.
  16. Feb 14, 2019 at 3:24 PM
    #1546
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    It looks like the timing cover needs to come off to get to the cam chains.
    NjPro likes this.
  17. Feb 14, 2019 at 5:26 PM
    #1547
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    They have enough room to pull the chains forward, mine was done w/o removing the timing cover as well.
  18. Feb 14, 2019 at 5:28 PM
    #1548
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Looked 3 times no problem
    040Tundra and TheBeast like this.
  19. Feb 14, 2019 at 9:06 PM
    #1549
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    My ‘19 also had the same smell in the first 1K miles. At 1600 now and the smell is gone. With all new trucks, I always do the first oil change at 2K miles. Will go to factory recommendation afterwards. Long and short, the smell is normal when new.
  20. Feb 15, 2019 at 10:27 PM
    #1550
    Hvactech24
    Hvactech24 MGM
    Kentucky
    2013 Rock warrior double cab
    2-1/2” front leveling kit, spider trex wheel spacers, line-x bed liner, change all lights over to led bulbs interior, exterior, and headlights. All bulbs are from headlight revolutions, RCI skid plates. RCI running boards
    Update everyone just got mine back tonight took them 8 days. Was at the Toyota dealership for 8 days to fix the dam cam tower leak they did both sides and had to pay them $2200.00 going to fax all the paperwork over to the attorneys on Monday so hopefully sooner than later I’ll get this lawsuit going and maybe I’ll recover some of this money I posted some pictures a while back and you can see where they had my whole engine tore apart I stopped in there this past Wednesday to check on it and they were having trouble getting the timing set back right. But it seems to be running good tonight.
    Jsena, WAtundra4x4, Luckydog and 4 others like this.
  21. Feb 16, 2019 at 2:57 AM
    #1551
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Here's to hoping you get ALL your money back :thumbsup:
  22. Feb 17, 2019 at 6:37 AM
    #1552
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    The service department billed nine hours to do mine (3 days). Looking at my invoice, they removed the time chain since I see the timing chain gasket listed.
    040Tundra likes this.
  23. Feb 17, 2019 at 10:54 AM
    #1553
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    This may be a dumb question, but are FFV and non FFV engines made on the same assembly line? Is there any correlation between FFV and or non FFV with the leaking cam shaft tower issue?
    gjcarving and Ronin73 like this.
  24. Feb 17, 2019 at 10:57 AM
    #1554
    Yzed608
    Yzed608 New Member
    Wisconsin
    Do they even offer non-FFV engines anymore? I didn't have an option when I bought mine, FFV engine and has never seen E85, and never will.
  25. Feb 17, 2019 at 11:07 AM
    #1555
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Yep. I don't think I've ever seen a FFV for sale here in Oregon.
  26. Feb 17, 2019 at 11:07 AM
    #1556
    ATHiker
    ATHiker New Member
    Tom
    My 2015 is a non FFV and I think they are still sold in some states. I live in TN and found my non FFV in WV.
  27. Feb 17, 2019 at 11:07 AM
    #1557
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I would like to know the answer to this as well.
  28. Feb 17, 2019 at 12:12 PM
    #1558
    gjcarving
    gjcarving New Member
    SMART question! I have been thinking the same thing as mine is FFV. Purchased in Santa Fe, NM.
  29. Feb 17, 2019 at 12:34 PM
    #1559
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Mine is FFV purchased in Albuquerque NM
  30. Feb 17, 2019 at 1:20 PM
    #1560
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Mine is a ‘16 CA non-FFV, and it has the cam tower leak. Someone mentioned a timing problem after the cam tower repair, and that’s a risk when doing this job because the timing chain is removed from the cams. If the tech doesn’t clearly mark the chain with the sprockets, and doesn’t hold tension on the chain, one tooth off is going to cause performance issues. Really sucks that new trucks have to get a tear down like this. The tech at my dealership said, “don’t go there.”
