CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Jan 26, 2019 at 6:00 AM
    #1261
    I had no intention of keeping my Tundra, so for me it wasn’t an issue. If oil hit the concrete, then it would be fixed.
    I came from Dodges with Cummins motors. I was well aware and used to leaks....expensive AF ones.
  2. Jan 26, 2019 at 6:01 AM
    #1262
    Vizsla
    Vizsla pretend2send
    It’s an oil leak. What kind of failure do you expect to come from that?
    I don’t understand posting in this thread if you don’t have a cam tower leak to add how the posters that have/do should feel or act about it.
    TTund16, OR18TRD, Johnjay06 and 3 others like this.
  3. Jan 26, 2019 at 6:03 AM
    #1263
    He was probably wondering if oil leaking was bad enough to seize a block or ruin bearings.
  4. Jan 26, 2019 at 6:31 AM
    #1264
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    It's one thing if your vehicle starts leaking oil at 150,000 miles. But, lets say you drive a lot. You rack up 60,000 miles in 2 or 3 years and are out of the powertrain warranty, and then at 65,000 miles, you start leaking oil. It shouldn't be leaking that early. If that happened to me (which it kind of did - although I lucked out and they gave me an extended warranty), I would be really pissed that I was going to have to spend the weekend tearing into my engine to fix it. Sure, I could leave it and let it leak - but, like I said, that doesn't sit well with me. I like my stuff to be working properly.
    seanyy11, TTund16, 040Tundra and 3 others like this.
  5. Jan 26, 2019 at 6:33 AM
    #1265
    Atomic City Tundra
    Devin
    New Mexico
    Just out of curiosity, how many miles did your Cummins engines have on them when they started leaking? (Not trying to be an argumentative dick - I really would like to know).
  6. Jan 26, 2019 at 6:51 AM
    #1266
    Atomic City Tundra
    Devin
    New Mexico
    Several have said just go get if fixed under warranty. I live 45 minutes away from the closest dealer. They always make you do the stupid "oil dye" test, so it requires two trips down to the dealer for diagnosis, then repair. Then, another trip to go pick it up. That is 4.5 hours of my time wasted. It is a pretty big hassle.
    Mitral, 040Tundra and Vizsla like this.
  7. Jan 26, 2019 at 7:19 AM
    #1267
    Vizsla
    Vizsla pretend2send
    Well I guess the answer is maybe?, certainly could have drove my 16 till it starved enough to damage the engine. But it was fairly obvious.:notsure: While certainly at the extreme end of the cam tower leak spectrum, only know one other, but nonetheless a cam tower leak. Not referring to the member I quoted, still can’t wrap my head around coming into the cam tower leaking thread, stating mine doesn’t leak so it is not an issue, and only a very small(not verified either way) leak. It’s an inconvenience at the least dealing with the repair, having a thread for those that have to vent should be fine?
  8. Jan 26, 2019 at 7:20 AM
    #1268
    wyone
    wyone New Member
    2018 Tundra DC
    dashcam... more to come
    I need to look for this on my 2018 with 6500 miles.. but honestly.. I have tried to read and look at exactly the best angle to see this.. Your pic is great.. but what would help me it a picture from the same angle but not as close... so I can get some reference points you know.. :)
    OR18TRD[QUOTED] likes this.
  9. Jan 26, 2019 at 8:18 AM
    #1269
    60k on my Common Rail. Wasn’t bad though. I kept watching and it was just the oil pan gasket bolts coming loose.
    Now on my 24V, that MF never stopped leaking. This is what I changed:
    Crankcase breather bottle. Did the relocate and better system. The newer trucks have a filter you need to change out every 30K miles.
    Crankshaft cover seal. This wasn’t horrible to do, and I was happy my crankshaft wasn’t gouged. There’s a kit to repair this issue.
    I had the oil pan gasket leak as well. Got lucky x2.
    Vacuum pump/power steering assembly. This goes into the timing gear case. I thought I was fucked and was going to pull the camshaft. I’ll cover that next. I pulled the assembly (single shaft & paired) and put a new gasket and some “right stuff” on that bitch.
    Now this is where I recieved the golden award. So lucky. The timing gear crankcase cover started leaking. I removed the cover, loosened up the bolts on the inside timing gear crankcase, used “the right stuff” and caked that around the outside and tightened the bolts back down. If the inside gasket starts leaking between the block and timing gear crankcase, you are screwed. Pull radiator, grill assembly, remove the valve train, push tubes (in v8s we call them pushrods). Then you have to hold up the tappets away from the camshaft. Then pull camshaft. At this point you can pull all the timing gears and then the crankcase to change a 14.00 gasket. If one of the tappets drop, it goes down to the oil pan. Fishing time, or pulling the oil pan (huge job on the Cummins). Then you need to decide if a new camshaft is in the budget. A good custom ground one is 800.00, and kicks ass. This is on top of the 1600.00 you just spent on replacing that 14.00 gasket.
    I had this truck up to 188k miles and finally said “f it”. This truck was paid in cash and still cost me over an average of 44 months, 619.00 per month in repairs. That’s when I purchased my Tundra and was Completely happy with that decision.
    That’s about it for the motor leaks.
    drapex, driverdog, TTund16 and 3 others like this.
  10. Jan 26, 2019 at 10:02 AM
    #1270
    Atomic City Tundra
    Devin
    New Mexico
    Agreed. And if you don't even own a Tundra....or never have owned one. No real experience with the situation.
  11. Jan 26, 2019 at 12:51 PM
    #1271
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    2018 with 6,890 miles joining the club.
    One drop showing on the drivers side, passenger is dry for now.
    I'll keep an eye on it and if/when both sides leak I'll see about getting it repaired before my powertrain warranty is out. If all it makes is one drop every 7k miles I would have a hard time rolling the dice on the repair.
    Every manufacturer has defects but what is most troubling to me is Toyota knows they have an assembly/manufacturing/design defect and continues to push the trucks out of the door with no changes. If the black sealant is the "fix" why not use it in the first place? It doesn't say a lot for the brands reputation of building a quality product.
    I didn't have a ton of great things to say about my new Toyota truck in the owners survey other than the power, braking, and comfy seats (which are great). The ride is terrible compared to my 1998 F150 Supercab 8' box I replaced it with. I think it's a symptom of the payload wars between manufacturers. To get a light duty DCLB the only choices were Ford and Toyota. Even with the leak I guess it was the best choice long term.
    Oh I guess I have the rattling ECU under the dash also based on another thread and my symptoms. I'll definitely be bringing the truck in for that sooner rather than later.
    BuckWallace and OR18TRD like this.
  12. Jan 26, 2019 at 1:28 PM
    #1272
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Lol, at least you didnt end up with a 53 block.
    Jengel451 and ColoradoTJ[QUOTED] like this.
  13. Jan 26, 2019 at 1:42 PM
    #1273
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    That's me! :mad:
  14. Jan 26, 2019 at 1:44 PM
    #1274
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Do these help?
  15. Jan 26, 2019 at 2:30 PM
    #1275
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Welcome to the club. After what I went through following the repair I agree with your decision to just keep an eye on it throughout your powertrain warranty. Good luck!
    jtwags, ColoradoTJ and OR18TRD like this.
  16. Jan 26, 2019 at 3:28 PM
    #1276
    This is exactly what I looked for before purchase (can’t remember if 02’ HO trucks even had 53 blocks). Some people never had issues, others had a 4500.00 paperweight.
  17. Jan 26, 2019 at 5:19 PM
    #1277
    wyone
    wyone New Member
    2018 Tundra DC
    yes.. thank you. :)
  18. Jan 26, 2019 at 6:18 PM
    #1278
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I probably should have said this is the passenger side...
    OR18TRD likes this.
  19. Jan 28, 2019 at 7:22 AM
    #1279
    AZTundra
    Paul
    Phoenix, AZ
    IMAG3738_BURST001.jpg I guess I'm joining this club now. I've been keeping an eye on mine every few weeks and yesterday noticed my drivers side has some oily residue built up where the metal piece sticks out a bit with the hole that goes thru it. 2017 Crew Max at 35,926 miles as of this morning. I'll try to attach a pic - I took a couple last night, but they didn't come out to good due to it getting dark outside and the lines blocking the view. Anyone have this fix done in the Phoenix area?...I've been using Camelback Toyota since I purchased the truck there, but with a job this big I'd like to know if others had a good experience and know where they went. Also, anyone disagree and believe this doesn't appear to be leaking?
  20. Jan 28, 2019 at 7:28 AM
    #1280
    Atomic City Tundra
    Devin
    New Mexico
    Can't tell from that picture.
  21. Jan 28, 2019 at 7:30 AM
    #1281
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    It's hard to tell from that picture, but my guess is they'll call that a "seep" and won't want to fix it yet. If you get down on the ground right behind your driver side wheel and look up at the cam tower from there, you can get a better look at that spot and see if it's actually leaking.
  22. Jan 28, 2019 at 7:45 AM
    #1282
    AZTundra
    Paul
    Phoenix, AZ
    Thanks. I'll take a look at it from that angle and see what I can find.
  23. Jan 28, 2019 at 7:49 AM
    #1283
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Good luck.... if you don’t already have an extended warranty maybe now would be a good time to consider one.
  24. Jan 28, 2019 at 7:51 AM
    #1284
    AZTundra
    Paul
    Phoenix, AZ
    I've got the extended warranty until 100K and also did the pre-paid maintenance to 75K, so I'm good on that end. :yes:
    TheBeast and 15whtrd like this.
  25. Jan 28, 2019 at 7:54 AM
    #1285
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    That’s good. If you can post better pics of the leak so we could give you our opinions that might help you make your decision. If mine was just “seeping” I wouldn’t have them tear my engine apart for that. Mine however has big drops of oil hanging off of parts of the engine though. 16 CM w/ 545xx miles on it. I’m glad I too have the extended warranty but mine is still covered under the Powertrain factory Warranty. I have an appointment today at 11 am here at a dealership. I’ll update when I find something out.
  26. Jan 28, 2019 at 8:02 AM
    #1286
    AZTundra
    Paul
    Phoenix, AZ
    Good luck at the dealership, keep us posted.
    040Tundra[QUOTED] likes this.
  27. Jan 28, 2019 at 9:42 AM
    #1287
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Just as an FYI, 2018 5.7 here with 24,000 miles and zero cam tower leak on either side, perfectly clean.
  28. Jan 28, 2019 at 1:49 PM
    #1288
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    Glad to hear it... My pops has a 2018 that is dry as well after 14K... Don't assume you're in the clear, keep an eye on it. I plan on getting mine done after winter, but I cringe the thought of cracking open a factory engine. It's a leak not a knock lol.
    040Tundra likes this.
  29. Jan 28, 2019 at 3:07 PM
    #1289
    Bergmen
    Bergmen New Member
    Ukiah, California
    In my case it would have to be an unbearable leak for me to consider a disassembly to fix it. And even then, if I had to do it, I would do it myself (I do not trust any dealer with this level of engine work).
    I wonder if a super cleaning of the area and a solid coat of JB Weld (or something similar) would externally seal this leak?
  30. Jan 28, 2019 at 3:46 PM
    #1290
    Capt J-Rod
    Ohio
    Did you report it stolen with the cops? Tell them to follow the oil drips and track it's location.
