CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Oct 20, 2018 at 11:52 AM
    #781
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I have heard of plenty in that time range that had the issue.
  2. Oct 20, 2018 at 1:39 PM
    #782
    helloo
    helloo New Member
    Aurora, CO
    2018 Black TRD CM Limited
    Add me to the list. 2018 with 5,300 miles. Not sure how long it has been leaking but this is completely unacceptable. I am the type that does my own maintenance and skip the free oil changes to do it myself. The thought of having the engine torn apart is unsettling. I regret this purchase.
  3. Oct 20, 2018 at 1:53 PM
    #783
    TheBeast The Beach
    damn that's like 3 or 4 2018s on the forum with very low miles and having the cam leak.
    equin likes this.
  4. Oct 20, 2018 at 3:49 PM
    #784
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    17 tundra grey. Dry
    18 sequoia grey, Dry
    I've never owned a vehicle that didn't seep somewhere at some point. If its not enough to smell of leave its mark, I'm not worrying about it.
    757TUNDRA likes this.
  5. Oct 20, 2018 at 5:20 PM
    #785
    Bagger16
    Bagger16 New Member
    My co-worker has a 2012 tundra 5.7 and we were discussing this issue and sure enough at 90,000 miles his passenger side after looking was soaking wet with oil and he was never even aware of it and the drivers side was bone dry.. That made his day
    TheBeast likes this.
  6. Oct 20, 2018 at 5:27 PM
    #786
    TheBeast The Beach
    seems like the dealership never tells you about it unless you ask and point it to them.
  7. Oct 20, 2018 at 6:00 PM
    #787
    helloo
    helloo New Member
    Aurora, CO
    To me that is unacceptable. $50,000 new truck should be sealed and dry. My 1997 Ford Escort and 2008 Honda Accord are bone dry with 300,000 miles combined.
  8. Oct 20, 2018 at 6:52 PM
    #788
    Jengel451
    The Bitterroot, MT
    Meh. Nothing is perfect. Show me one thing that is.
    Life is too short to get worked up about material shit.
    osidepunker likes this.
  9. Oct 21, 2018 at 10:14 AM
    #789
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Same exact spot mine was leaking, I'm just like you with doing my own maintenance and skipping the dealer oil changes. I was sick when I saw this and figured out how much the engine had to come apart.
  10. Oct 30, 2018 at 8:27 PM
    #790
    Rezzy805
    Rezzy805 New Member
    ‘14 limited pro build
    My extended warranty just covered the cam tower leak. ‍♂️
  11. Nov 6, 2018 at 7:33 AM
    #791
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Don't make me regret this purchase! LOL... perhaps it's time to go back to a GM if this occurs, there's no reason to buy a TOYOTA. This reminds me of the Subaru Foresters with the 2.5 liter that has head gasket problems and oil leak. Why o why!
    The good thing ( I think ) is that I have a limited lifetime warranty that came with the truck. Unlimited miles, unlimited years as long as I am the registered owner and do my maintenance as scheduled (per owners manual). I wonder if this is good enough to cover it, I should probably contact my dealership.
  12. Nov 6, 2018 at 7:36 AM
    #792
    Rezzy805
    Rezzy805 New Member
    GM? Heck no for me... both gm suvs i owned fell apart, burned oil, leaked oil. They just turned to garbage, I’d take a leak from Toyota that they will cover and fix any day.
    Danny14Tundra, TheBeast and jtwags like this.
  13. Nov 6, 2018 at 11:51 AM
    #793
    fdreano
    fdreano New Member
    2013 Tundra Double Cab
    Kenwood DNX694S Radio, step up bars, wheel flares, bug shield
    I only found out about the cam tower issue yesterday and scheduled my 2013 V-8 Tundra for dealer service to check it (I already did and yes there were leaks). Took it in this morning and I have 58,600 miles on the car but its 5 months past warranty. The service advisor at first said I wasn't covered but then called Toyota and they are going to cover the repair and two other leaks. The dealer said it was close to $5,000 in repairs and I'm only out the price of an oil change... I'm not gonna complain one bit as I plan to have this truck a LONG time.
    BTBAKER, classiccat, JoshuaA and 4 others like this.
  14. Nov 6, 2018 at 2:50 PM
    #794
    Jengel451
    The Bitterroot, MT
    And that is why I'm staying with Toyota, I've had the big three and they NEVER will do the "Right thing" unless they are backed into a corner. Case in point, my last two Cummins both had rear main seal weep, nothing that would drop onto my driveway, but it was there. One of them finally dripped enough to hit the driveway, anyone that knows how oil from a Diesel likes to stain, knows you gotta nip that in the bud. Even though they knew of the weep, and had it documented, they pushed back hard. Eventually it was fixed, but it was by a Cummins shop, not a Ram shop.
    BTW, I have 2 yota's with the gray sealant, dry as a bone.
  15. Nov 7, 2018 at 6:52 PM
    #795
    CapeCod26
    CapeCod26 New Member
    Hey guys thanks for the great forum and all the info..
    I just went to my local dealer to look at a used 14 CM 80k highway miles and one owner that traded it in from new. Its dealer maintained and has all service records, it has a 12m/12k warranty and is fully serviced. Its been on the lot for a bit and I stopped by and gave it a look a month earlier, dealer was closed. I went in today not knowing about the issue of cam towers started it up stepped out and walked around giving it a good look. I stuck my head in the wheel wells to give a good listen to the manifolds, valve train and bearings. Everything sounded good but I noticed right away the smell of burning oil on drivers side and was thinking valve cover. Climbed under it and saw oil on the exhaust manifold cover. Salesman had nothing to say about it. Told him I would think about it and get back to them.
    After getting home I researched it and came to this with 28 pages of nightmares from good people that work hard to enjoy their trucks. I'm a bit stumped a Toyota dealer selling a dealer serviced truck off their lot with this problem and not even acknowledging it or fixing it and trying to pass the buck to someone else.
    I am really liking the truck but after this read I don't know. I don't even know where too start with the dealership, should I just walk away?
    Sorry for the first post banter. I just hope others don't end up with a 3k fix on a truck that should run 200k miles.
    Thanks
    2018TundraLimited likes this.
  16. Nov 7, 2018 at 7:22 PM
    #796
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
  17. Nov 7, 2018 at 7:32 PM
    #797
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Just walk away from that one unless you can get them to fix it.
  18. Nov 7, 2018 at 8:58 PM
    #798
    TheBeast The Beach
    have them fix it and give you a discount on it :)
  19. Nov 9, 2018 at 1:00 PM
    #799
    CapeCod26
    Thanks guys!
    The dealer called back 2 days later and I talked to the manager. He claims no problems with the truck.. Said he had not heard of this problem. Said they do excessive check's on used trucks to ensure a good reliable vehicle.
    I asked them if I came up to the invoice price would they take care of cam towers. He said no, nothing wrong and was pretty rude about it. Then told me maybe I need to look at a different brand of truck. Ugg... Whats up with these dealerships. I was being nice.. I can't imagine trying to get them to warranty this issue if I purchased it. I guess I'll walk from this one. Leaves me pretty unsure about keeping up the search.
    I hope you guys all get them fixed.
    All the best
    BTBAKER likes this.
  20. Nov 9, 2018 at 1:48 PM
    #800
    Jengel451
    The Bitterroot, MT
    Talk to the service manager, the sales side only cares about a sale, that's it. Most dealerships the sales and service folks won't even talk to each other. I always say, sales is a one night stand, service you live with.
    ldale likes this.
  21. Nov 9, 2018 at 2:03 PM
    #801
    CapeCod26
    That's who I talked to SM. He said they could check it again but I'm leary. Claimed the oil change could of made the smell. I smile cause the oil has not been changed. It has the window sticker claiming it needs to be changed in 4k miles. It has I think the 0/20 synthetic in it 10k change interval.. I'm sure they just checked it and put her out on the lot. Its a big Toyota dealer here where I'm at. It does have a 12k/12m warranty but they claim no issue and the warranty is thru the dealer not Toyota USA. I'm not in the mood to hassle after the fact. I was going to pay up front for the truck.
    Thanks for the help.
  22. Nov 9, 2018 at 2:05 PM
    #802
    TheBeast The Beach
    yep look for another one.
    BuckWallace and Jengel451 like this.
  23. Nov 9, 2018 at 2:05 PM
    #803
    Jengel451
    The Bitterroot, MT
    damn, yeah, not a dealer you want to have in a relationship. I don't care what make/model you have, if you don't have confidence in the service/warranty side of things, you won't be happy. Post warranty, all bets are off i you have someone you trust.
  24. Nov 9, 2018 at 5:12 PM
    #804
    Griff
    Griff New Member
    2018 Barcelona Red DC
    Topper, bedslide and more to come
    It's disappointing Toyota has not corrected this. Kudos to them when they stand behind their product.
    For what it is worth, I ran a 2010 with a cam tower leak for about 150,000 miles. The leak never made a spot on my garage floor. The service department at the dealership wanted to fix it, I wouldn't let them. The only repair on that truck was a water pump, 220,000 miles. Traded it for a 2018 and looking forward to another 200,000 miles. No cam tower leak yet.
    jtwags, TheBeast, sbxx312 and 2 others like this.
  25. Nov 16, 2018 at 10:12 AM
    #805
    tundras00
    tundras00 New Member
    Did you not trust them (lol, I had to laugh at myself for that), or did you think that the leak was insignificant to do a repair that would take awhile?
  26. Nov 16, 2018 at 10:34 AM
    #806
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Mine has the beginnings of a leak (seepage), and dealer says no on reseal because it’s not an actual drip, even though I get an occasional burnt oil smell off of drivers side bank.
  27. Nov 16, 2018 at 10:41 AM
    #807
    Atomic City Tundra
    Devin
    New Mexico
    Take it to a different dealer. Unless you are one of those that doesn't mind a new truck leaking oil.
  28. Nov 16, 2018 at 11:07 AM
    #808
    tundras00
    I can see that. When I got a new Transit, I saw seepage and was kinda worried. Wiped it and never came back.
  29. Nov 16, 2018 at 11:23 AM
    #809
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    There are so many Tundras around here. I didn't know about the cam tower leak until I joined this forum. Now I want to go up to everyone's Tundra with a flashlight and see if they're leaking.
    It makes me wonder what I would find if I did. Would a lot of them be leaking or kinda leaking? Does it matter if they are? I own a 2018 and understand the frustration. But, does it makes sense to bust open your truck if you're not leaking much? I think I'm now of the opinion, like you, that it doesn't.
    I also had a Land Rover Discovery and that thing leaked constantly. Maybe I'm jaded. After reading this entire thread, I think if it happens to my 2018 and it's not leaking on the garage floor, I'll wait until I'm almost out of warranty to "notice" it.
    15whtrd and 757TUNDRA like this.
  30. Nov 22, 2018 at 3:00 PM
    #810
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Looks like I have cam tower leak on my 2018 with 4k miles (passenger side), not even to first oil change. Bummed as these types of issues are why I passed on F150 to give Toyota the benefit of the doubt as the drama free ownership option since it has been in production so long. Crazy they have not changed the process, like a grooved oring or one piece cast for the towers. Frustrating and from what I have read in this thread Toyota is starting restrict coverage to just the side that is leaking and not adding additional warranty to those that have new engine opened up (unless you harrass Toyota for it). I guess we shall see how my case is handled by the dealer I purchased from when I go in for first oil change. Any words of wisdom from those that have had this handled recently?
    seanyy11, equin and Y0TA PR0 like this.
