CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Sep 12, 2018 at 1:32 PM
    #721
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Unfortunately, what’s needs to happen is to have a lot of engine fires (oil on exhaust manifold) with bodily injuries, and then, maybe, NHTSA gets involved and forces a recall. Until then, Toyota is handling this issue as a case by case complaint. Mine has the leak, and the Toyota tech that I trust at the dealership says, “you don’t want to go there.” Why? Because of the extensive tear down etc. My theory on the leak is this: the factory sealant is applied in an automated engine assembly process, and how applications can it make before refills in the machine are necessary? When the machine operator refills the reservoir, or whatever, air is then pushed through and there ends up being a small gap in the sealant bead. That gap equals cam tower leak in someone’s new truck. Mine!
  2. Sep 12, 2018 at 5:13 PM
    #722
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    You would think they would have it programmed to push some out to get rid of this gap before starting to apply again if that's the case.
    If you have the leak you might want to have it fixed before you run out of warranty as its expensive if your not. If yours is just seeping that's not so bad, mine was physically dripping onto the exhaust manifold and burning off so I didn't have a choice in the matter.
    Blueline[QUOTED] and TheBeast like this.
  3. Sep 12, 2018 at 6:05 PM
    #723
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I agree. Just thought I’d mention, though, that the rotting frames were made under contract by Dana Corp.’s Tennessee plant, in the same facility where F150 frames were made. Rumor I read is that the rust was due to either a misapplication of rust inhibiting/preventive coating or a misunderstanding of Toyota’s specs for steel treatment and rust prevention of the frames. Who knows? But Toyota’s Japan-made Landcruisers, 4Runners, Prados and Hiluxes didn’t have that issue.
    As for the gasket issue concerning the cam shaft tower, it seems reminiscent of Toyota’s struggles with head gasket failures with past engines (i.e., 3.0 V6, 22RE and some Landcruiser 80 series engines). For whatever reason, Toyota seems to struggle with gasket reliability issues when it comes to mating dissimilar metals together.
    Ted4311 likes this.
  4. Sep 25, 2018 at 7:48 PM
    #724
    1mountain@atime
    1mountain@atime New Member
    2012 Smoke Grey 5.7 4X4 Max Cab
    Running Boards, Rhino Liner, Tonneau cover
    New on here. I have a 2012 Smoke Grey Tundra 5.7 MaxCab .. LOVE MY TRUCK!
    Brought it to the dealer for an oil change. They called to inform me of a Valve cover leak. Then called and said, "No, sorry it is bad news, it is a cam tower leak 2700.00. I took it to an Independent Toyota mechanic and he said," the valve cover is defiantly leaking, but it is dripping down over and onto the cam tower so how could Toyota tell which repair is it going to be?" He showed me, through the wheel well, the leaking areas, driver side rear=larger leak, the passenger side rear= much smaller.
    He then told me that in order to tell if the cam tower was leaking I would have to repair the valve cover and then put pressure load on the engine to see if the cam tower was leaking below. He didn't recommend this as the cost was too great.
    I do not want to ruin my engine .... Taking it up over Utah and Colorado I-70 in October .... How do I tell which is leaking?
  5. Sep 26, 2018 at 11:45 AM
    #725
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    This fucken blows. Decided to finally check and of course it’s leaking and I’m at 62000. Gonna see if the dealership will help me out. E22F5F4B-FFF7-4610-BD5D-C16F0C14DB61.jpg
  6. Sep 26, 2018 at 5:43 PM
    #726
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That's the same spot mine was leaking and dripping into the manifold. Good luck with the dealer.
  7. Sep 26, 2018 at 6:25 PM
    #727
    TheBeast The Beach
    https://www.tundras.com/threads/diy-leaks-detection.18151/
    Sas likes this.
  8. Sep 26, 2018 at 6:25 PM
    #728
    TheBeast The Beach
    do you have extended warranty ?
  9. Sep 26, 2018 at 6:26 PM
    #729
    TheBeast The Beach
    2 in a row....now, where is the guy that says it never happens ? :rolleyes:
    equin and Atomic City Tundra like this.
  10. Sep 26, 2018 at 6:42 PM
    #730
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Has this issue caused any damage to anyone's engine, or is it more of a nuisance wet spot?
    TheBeast likes this.
  11. Sep 26, 2018 at 6:44 PM
    #731
    TheBeast The Beach
    haven't heard of damage, more like a nuisance...I drove with the leak for over 15,000 miles without being aware of it....ymmv
    Watt maker likes this.
  12. Sep 26, 2018 at 7:23 PM
    #732
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I haven't heard of actual damage because of it. They are usually slow leaks. But, it is more than a nuisance when it starts dripping onto the exhaust and burning/smoking. Then it also stinks (that is how I discovered mine - I could smell it and see small puffs of smoke occasionally) and poses a possible fire hazard (although I haven't heard of anybody's rig catching fire).
    Right? I especially liked the post from the Toyota Master Tech that said he had repaired quite a few of them. But, they never happen. Or, as another poster said - you just need to be an "adult" and accept the risks and live with the consequences. :rolleyes:
    TheBeast[QUOTED] and Y0TA PR0 like this.
  13. Sep 26, 2018 at 7:42 PM
    #733
    Rex Kramer
    Georgia
    So looking under the hood, and wiping off any oil that has leaked out would probably make this a non-issue for most. Right?
    Scpringle and 757TUNDRA like this.
  14. Sep 26, 2018 at 8:14 PM
    #734
    TheBeast The Beach
    if it leaks very slowly, most of the people never know about it and they get their oil change every 5K anyways.
    Rex Kramer likes this.
  15. Sep 26, 2018 at 8:14 PM
    #735
    Mattlikesbikes
    Mattlikesbikes New Member
    Yeah, so I spray a little car wash soapy water then rinse, all low pressure. Since I started doing that the puff of blue white smoke from the wheel wells is gone. My actual oil volume loss at 7500 mile changes is basically unmeasurable, so I'm not losing sleep.
    I am still pissed that I bought the truck used from a toyota dealer and noticed it about 4500 miles later only to be told to pound sand by the dealer.
    757TUNDRA and TheBeast like this.
  16. Sep 26, 2018 at 8:58 PM
    #736
    Atomic City Tundra
    Devin
    New Mexico
    I guess it depends on your tolerance level. If you don't mind having a leaking vehicle - then I suppose it would be a "non-issue". I couldn't do that - it would drive me nuts. I've had a few of vehicles that sprung leaks after many miles - and I fixed every one of them (or had it fixed in the case of the Tundra since it was under warranty). But the real issue is that this happens on fairly new Tundras. That is just not acceptable.
  17. Sep 26, 2018 at 9:51 PM
    #737
    Jimes
    Jimes New Member
    I took a closer look at what I believe is a heat shield or whatever is right under that spot and it’s been leaking for hella long now cause that drop created an inch to inch and a half wide shit stain that runs all the way down. Lol. Plus it looks old as hell. I’ll take a pic tomorrow and you can be the judge. Anyway. Spoke to Toyota dealership that I always go to and since I service with them they are going to do a goodwill ticket and see what Toyota has to say. My service advisor seemed very confident that they will take care of it cause I’m so close to the warranty and looks old. We’ll see, I’ll give update when I go in on Monday. Shit happens. That’s life and my fault for not checking earlier. Hopefully it works out. Good times.
    Watt maker and TheBeast like this.
  18. Sep 27, 2018 at 4:23 AM
    #738
    Rex Kramer
    Georgia
    I'm not going to complain if it's not dripping on the driveway or causing any unnecessary wear & tear on the engine, and if I can keep up with it by wiping the area with a rag every now and then. I try and keep the engine bay relatively clean, but it's no show truck so it will never be spotless. Besides, I have more important things to concern myself with.
    757TUNDRA likes this.
  19. Sep 27, 2018 at 5:03 AM
    #739
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    The second time mine started leaking it was smoking like a mthrfckr
    Toyota gave me an extended warranty because of it. But initially corporate said no. I had to elevate above the donkey that told me no before they would give me anything
    TheBeast and Atomic City Tundra like this.
  20. Sep 27, 2018 at 8:09 AM
    #740
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Did you mean one that is VISIBLY leaking? Because IIRC there is only 1 sealed system on our vehicles, therefore...ya' know, physics and all that...;-)>
    B
  21. Sep 27, 2018 at 10:34 AM
    #741
    Jimes
    Jimes New Member
    Does anyone know how long this takes to fix? Or an estimated time of how long they will keep my truck?
  22. Sep 27, 2018 at 11:19 AM
    #742
    TheBeast The Beach
    3 days max.
  23. Sep 27, 2018 at 2:14 PM
    #743
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    My truck was In there for the repair for 2 days, they also had to schedule it around the master tech for when he was able to work on it for 2days straight.
  24. Sep 27, 2018 at 3:57 PM
    #744
    Jimes
    Jimes New Member
    Awesome. Thank you.
  25. Oct 9, 2018 at 8:53 PM
    #745
    kamper
    kamper New Member
    I have been looking at tundras the last couple of weeks after mine was totaled. So far I have found 4 that have the oil leak all with the 5.7
    2012 with 50k
    2015 with 120k
    2013 with 115k
    2011 with 140k
    I even had a dealership tell me it would be hard to find one that doesn’t have the leak. Guess I will keep looking for now.
  26. Oct 10, 2018 at 9:09 AM
    #746
    TheBeast The Beach
    it is annoying but it won't grenade your engine. like you mentioned, 2011 with 140K. probably had the leak its whole life.
  27. Oct 10, 2018 at 9:13 AM
    #747
    equin
    Ed
    DFW, TX
    I guess if it’s a slow leak, I’d rather live with it than pay a few thousand to get it fixed. I suppose if I were shopping for one, I’d negotiate having it fixed right first as part of the deal or have it discounted correspondingly to pay for it yourself or live with it if it’s a small slow leak.
  28. Oct 10, 2018 at 5:45 PM
    #748
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Its a bad design, your asking a lot of the sealant in that area to keep it sealed up. What's even more frustrating is Toyota really hasn't put any emphasis on a fix and just handle them as they leak. If the black sealant they use for the repair is much superior then the gray they use at the factory then they should be coming to us from the factory that way. Tired of manufacturers pushing there error's off on the consumer so they can pinch a few pennies. Heck if Toyota would of said "Hey your trucks gonna cost $50 more for better sealant" I would have gladly paid it to keep from having my engine torn down at 21k.
    Watt maker, equin and TheBeast like this.
  29. Oct 10, 2018 at 6:34 PM
    #749
    equin
    Ed
    DFW, TX
    Agree
  30. Oct 13, 2018 at 1:53 PM
    #750
    fishman1
    fishman1 New Member
    2017 TundraTrd off-road crewmax
