Calling 2020+ GM 25/3500 6.6 Gas Owners
Discussion in 'Towing & Hauling' started by Chilkat, Sep 7, 2023.
  1. Sep 11, 2023 at 9:16 AM
    #61
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    This was my experience with two GMC vehicles, both with the 5.3L v8. I would consistently burn a couple quarts between 5k oil changes. All so half of my engine could shut down to earn me 0.1 more MPG while cruising.
    The people who demand (and approve) these kinds of measures out of auto manufacturers are not serious people.
  2. Sep 11, 2023 at 9:51 AM
    #62
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    What do you need a truck for, then?
    Lake.Life24 likes this.
  3. Sep 11, 2023 at 9:51 AM
    #63
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I don't "need" a truck.
    I "want" a truck.
  4. Sep 11, 2023 at 9:52 AM
    #64
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I've got two oil changes (11k miles on the clock today) and haven't experienced any oil consumption. Definitely something I'll keep an eye on.
  5. Sep 11, 2023 at 9:54 AM
    #65
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll add:
    every God fearin', grown ass man should have a truck in the stable.
    a supercharged truck earns you bonus points.
  6. Sep 11, 2023 at 9:55 AM
    #66
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If I didn't need the truck capability, I'd rather drive a SC Tundra than a SC 3500. :mudding:
  7. Sep 11, 2023 at 10:03 AM
    #67
    If you use the exhaust brake a lot on long grades towing heavy you may experience a little oil loss. When I was hauling boulders out of the mountains west of Denver, in 10k miles I used 1 qt of oil. So I was about a half quart low per oil change.
  8. Sep 11, 2023 at 10:09 AM
    #68
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    One of my coworkers has a 2021 Ram 2500 Cummins Limited Megacab with only 1700lb of payload. Says it's good for pulling his 8,000 pound camper at 85 mph.
    Cpl_Punishment likes this.
  9. Sep 11, 2023 at 10:13 AM
    #69
    Wow. That's super low capacity for a 3/4 ton. Never seen one that low.
    My Tundra would pull 8k at that speed if I wanted it to. Just not smart or efficient.
  10. Sep 11, 2023 at 10:28 AM
    #70
    nobodyintexas
    nobodyintexas What?
    South of Houston
    did/does the 6.6L suffer the same lifter malady as the 6.2L?
    or is it a complexly different design?
    Cpl_Punishment and ColoradoTJ like this.
  11. Sep 11, 2023 at 10:38 AM
    #71
    Is the oil consumption seen in these high stress motors being recycled into the intake via PCV and could be captured in a catch can? Or is this legit burned oil from ring blowby (I would not suspect this?)
  12. Sep 11, 2023 at 11:02 AM
    #72
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I too would take a Supercharged 6.6 L8T over the diesel for my particular use case, even for the same cost. I’d rather have 600+hp and 700+ ft lbs than 445hp and 910 ft lbs. That’s also assuming a less than ideal out of the box cookie cutter tune from the blower manufacturer. This is easily a reliable 800+hp gas engine with a blower, smaller pulley and proper tuning. I know Harrop has them running over 1000hp with their TVS2650. All it would likely require is feeding it a lot of gas, which never bothered me! I’d rather that than DEF and costly out of warranty emissions equipment failures.
    Huge torque is of course important for hauling, but slightly less huge torque combined with huge horsepower is even better IMO. If I was using the truck as a hotshot driver hauling campers across the country or pulling a skid loader on a daily basis, I’d have the diesel though most likely.
  13. Sep 11, 2023 at 11:20 AM
    #73
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    I don't believe so, mainly because they don't have the d.o.d. mess. . Atleast the people I know that have the 6.6. dont
  14. Sep 11, 2023 at 11:46 AM
    #74
    PCV. Mine is routed to atmosphere now though and oddly enough I haven't been using much oil since.
  15. Sep 11, 2023 at 11:57 AM
    #75
    Totally different design. I know Ram has cylinder shutdown in thier HD lineup, but GM does not. Pretty sure Ford doesn't either.
  16. Sep 11, 2023 at 12:11 PM
    #76
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The 6.6 doesn't have the AFM/DFM/DOD system that the 6.2 and 5.3. do. But, that being said, I'm not sure if that was the root cause of the issues or not.
    ETA: I see this has been answered already.
  17. Sep 11, 2023 at 2:00 PM
    #77
    AircareTundra
    AircareTundra New Member
    JT
    FWIW.....I had a 2015 Silverado 1500 with the 5.3 that had AFM. This was where only 4 of the 8 cylinders would drop offline to appease the epa. And yes.....from having dealt with a collapsed lifter at 87K miles or so and doing a lot of research on the Silverado/Sierra forums, it appears that the engines with the AFM or even worse now the DFM where any of the 8 cylinders could drop offline......seem to be the ones with the lifter issues.
    I was all set to keep that truck and have a shop do a complete AFM delete kit and throw long tube headers and a tune on it but I started having unresolved electric issues at 96k or so which forced my hand and helped get me into the Tundra.
    I am glad I made the switch to the Tundra!
  18. Sep 11, 2023 at 2:13 PM
    #78
    nobodyintexas
    nobodyintexas What?
    South of Houston
    My understanding is the heads that were put on those motors had poor geometry with the push rod. They simply didn’t align right and gm went ahead and used them
  19. Sep 11, 2023 at 7:25 PM
    #79
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I have the reroute to a catch can and have not seen oil consumption to a material level. I don’t measure after oil changes but I’m usually always putting back 8qts so I assume minimal oil burning.
    ColoradoTJ likes this.
  20. Sep 11, 2023 at 8:04 PM
    #80
    I like your setup Shawn. Reasonably priced too.
