Cali Raised Led 32" Stealth Light Bar
Discussion in 'Lighting' started by Kevfran99, Oct 27, 2020.
  1. Oct 27, 2020 at 7:26 AM
    Kevfran99
    Kevfran99 [OP] New Member
    Kevin
    Lilburn, GA
    '19 TRD PRO
    TRD Rear Sway Bar - Front tint - Caliraised LED Fogs & Light Bar-Bed LEDs-Bed Cover-Wireless Charger
    Just installed this yesterday. Although the install instructions weren't the best I'm very pleased with how it turned out. The dash button looks factory and it's bright as hell! I'm just waiting on the LED fogs to come in now since one of my factories crapped out.
    MrYOTA, WFD473, ManoTundra and 4 others like this.
  2. Oct 27, 2020 at 8:01 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Did you purchase new fogs or did you send the factory back to Rigid? Guess you could go through Toyota too if you’re within warranty. Rigid lights carry a lifetime warranty
  3. Oct 27, 2020 at 8:04 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    I did not know this. I'm just out of warranty so dealer wont cover them. I'll have to contact Rigid and see what they say. Thanks
    Mater[QUOTED] likes this.
  4. Oct 27, 2020 at 8:16 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    :thumbsup:Light bar looks good. Been thinking of getting one myself
    Kevfran99[OP] likes this.
  5. Oct 27, 2020 at 8:20 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Thanks. I would recommend it. I really like the hidden look. If you need any install help just hmu
    Sean492 and Mater[QUOTED] like this.
  6. Oct 27, 2020 at 8:21 AM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    Where did you buy your kit from? Looks great
  7. Oct 27, 2020 at 8:22 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    So I just got off the phone with Rigid. They will not cover them. Warranty has to go though Toyota and I'm just over on miles. Oh well. Cali Raised were already ordered yesterday so I'm looking forward to them showing up and getting this problem fixed.
  8. Oct 27, 2020 at 8:23 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I have the same bar. Really like it so far.
    Kevfran99[OP] and aussieaarons like this.
  9. Oct 27, 2020 at 8:24 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    I bought it straight from Cali Raised. use promo code TRAILYETIPROMO for a discount. Capital one shopping app gave me the code gotta love it saved $22
    aussieaarons[QUOTED] likes this.
  10. Oct 27, 2020 at 9:21 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    My ‘17 limited needs that bar! I love where you put the switch, but mine already has a switch in that place (Trailer Brake type). No switch locations have blanks... and don’t really want something that looks hacked in.
  11. Oct 27, 2020 at 9:43 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    How about on the other side of the steering wheel? It does come with another push button switch you could mount hidden. Let me see if I can still find it.
  12. Oct 27, 2020 at 10:41 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    What lights did you order for fogs? Their pods aren't rated for on-road use, so that something to keep in mind if you typically use them as driving lights. They're all spot beam with no cutoff.
  13. Oct 27, 2020 at 11:28 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    the 3X2 led pods. I'm not overly concerned with them being rated off road use. I'll be fine.
  14. Oct 27, 2020 at 11:30 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
  15. Oct 27, 2020 at 11:45 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    https://caliraisedled.com/apps/help-center#hc-are-your-lights-street-legal
    You'll blind the shit out of someone since they don't have a cutoff.
  16. Oct 27, 2020 at 11:48 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
  17. Oct 27, 2020 at 11:56 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  18. Oct 27, 2020 at 12:00 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  19. Oct 27, 2020 at 12:07 PM
    HammockYota
    HammockYota New Member
    2015 Tundra TRD OR
    Did you go with the “spot beam” or “combo beam”? Any idea on difference? Looks great!
  20. Oct 27, 2020 at 12:08 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Im interested in how you ran the wiring to the switch. Was it really intrusive? I have a light bar and plan on mounting another one in my go rhino front bumper.
  21. Oct 27, 2020 at 12:10 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, the factory Rigid Pro fogs still use the normal H11 connector, not the DT that most aftermarket pods use.
  22. Oct 27, 2020 at 12:18 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    I went with the spot beam. I'll try to get a night pic soon.
    HammockYota[QUOTED] likes this.
  23. Oct 27, 2020 at 12:20 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    nah. Ran the wire from the light to the battery. along the fender well and then cut a small hole in the steering column rubber boot. fed the wire through and then put silicone around the wire and boot. dropped the front of the dash down to get to the button location. I had a blank spot so I removed it and wired in the button. Pretty easy actually. The whole install was 2 hours or less.
    AnonVet[QUOTED] likes this.
  24. Oct 27, 2020 at 12:21 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    The combo looks like it comes with the wiring harnesses.
  25. Oct 27, 2020 at 12:25 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    How was the dash drop? I've done a lot of interior stuff but that just scares me.
  26. Oct 27, 2020 at 12:30 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Real easy. One 10mm on the bottom right side. 1 10mm on the left side but you have to pull back the kick panel to get to it. Then I carefully pulled it away from the dash. Popped out pretty easily. I didn't take it clear out as from here I could access the other buttons. Pulled on them and they came right out. The wiring was actually a lot easier than the light bar install.
  27. Oct 27, 2020 at 12:37 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Nice!! Thanks for the run-down. When it isn't 30 degrees out im going to give this a shot.
  28. Oct 27, 2020 at 1:59 PM
    mountainpete
  29. Oct 27, 2020 at 2:01 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    LOL yea the light bar is extremely bright. I saw my neighbor's wife naked through shut plantation shutters and the end of my street....lmao
  30. Oct 27, 2020 at 2:33 PM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    Great looking light bar, and great installation.
    Kevfran99[QUOTED][OP] likes this.
