Cali raised ditch lights take 2. Still not straight?
Discussion in 'General Tundra Discussion' started by andy9743, Apr 3, 2017.
  1. Apr 3, 2017 at 7:14 AM
    andy9743
    andy9743 [OP] New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Take 2 on the install for these. I still don't think the drivers side looks right? First set had a manufacturer defect and cali raised replaced.
    Sober install. Not sure what I could have done wrong or different? Feedback?
  2. Apr 3, 2017 at 7:14 AM
    andy9743
    andrew
    nw ohio
  3. Apr 3, 2017 at 7:15 AM
    andy9743
    andrew
    nw ohio
  4. Apr 3, 2017 at 7:15 AM
    andy9743
    andrew
    nw ohio
  5. Apr 3, 2017 at 7:16 AM
    andy9743
    andrew
    nw ohio
  6. Apr 3, 2017 at 7:17 AM
    andy9743
    andrew
    nw ohio
  7. Apr 3, 2017 at 8:12 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    You forgot the beer on the driver side...
    AnonVet likes this.
  8. Apr 3, 2017 at 8:12 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Andrew, it looks to me as though the one on the right is bent a little higher on the outside than the one on the left, no biggie. You should be able to "bend" it back into position if you didn't want to wait for delivery of a new one or while you wait for your delivery.
  9. Apr 3, 2017 at 8:25 AM
    andy9743
    andrew
    nw ohio
  10. Apr 26, 2017 at 12:17 PM
    Caliraisedled
    Caliraisedled New Member
    Jake
    From our old batch, they were not bent correctly, but with our new batch they are all perfect. I would check something your hood and bolts, because with our new ones we have sold hundreds and still no angle problems
  11. Apr 26, 2017 at 12:28 PM
    andy9743
    andrew
    nw ohio
    @Caliraisedled
    Jake
    thanks for the reply. i've messed around with the hood bolts and the through bolts. replaced the through bolts, added a second set of through bolts and no luck. seems the drivers side just is not correct. upon install of the new brackets i held the replacement set up next to the old set and visually they looked the same. there's a few bends in them so i figured maybe the tweak was minor and it would show through upon install. no dice.
    Typically i do not complain, but the bracket experience has been sub par. add to the mix that i've glued and reglued the amber covers 3 times now (tried some different glue then the harbor freight stuff that came with them) and the damn things still don't stick. 2 of the 4 blew off.
    also noticed that on 2 of my 4 lights the center screw holding the lens in has loosened up. i've not even wired them up yet, kind of disappointed at this point with a product and company that seems to have gotten a lot of love from the Tacoma guys. idk maybe i'm doing it wrong or out of line here.
    AnonVet likes this.
