CAI
Discussion in 'Performance and Tuning' started by TundraTss, Dec 18, 2017.
  1. Dec 18, 2017 at 11:50 AM
    TundraTss
    TundraTss [OP] The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    TRD CAI on a ‘15 flex-fuel 5.7.
    Who’s got one?
    Pros and cons, if you please.
    I’ve been looking at one but my dude, who’s a tuner for a local race team, keeps telling me that they cause problems when it comes to the ecu ajutsting or knowing what’s going on under the hood.
    Gracias, vatos.
  2. Dec 18, 2017 at 11:53 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Some folks here have CAI. Little HP/MPG gains with one from what I've read. I have not seen anyone post issues with ECU after installing CAI. I would imagine engine picks it up just fine since you have to disconnect battery before you install it. Those that have it will chime in soon.
    TundraTss[OP] likes this.
  3. Dec 18, 2017 at 11:56 AM
    TundraTss
    Brandon
    2019 TRD SR5
  4. Dec 18, 2017 at 11:58 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    AFE Pro Dry S is like $50 to $75 and has proven gains. Save the rest of the $$ for other mods. IMHO
    Factory is CAI already, draws from fender well.
    As well, IIRC, the tube diameter on most aftermarket CAIs is larger which equals slower air movement, but more volume.
    Traditionally smaller diameter/longer runners produce more torque while large diameter/shorter runners produce more HP.
    How do you drive everyday? I'm assuming not red line all day long, which makes me want to stay with a better torque curve than HP.
  5. Dec 18, 2017 at 12:01 PM
    TundraTss
    Brandon
    2019 TRD SR5
    What’s the difference between an AFE and a K&N?
    And I already have all the exterior/suspension mods that I want. It’s performance time, and I ain’t got 7 g’s for a supercharger.
    What other perf. mods would you recommend?
    I mean, I’m not trying to turn it into a racecar, but everyone likes a little more power..
  6. Dec 18, 2017 at 12:02 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I dont think K&N makes a dry filter.
  7. Dec 18, 2017 at 1:34 PM
    TundraTss
    Brandon
    2019 TRD SR5
    What’s the difference between dry and not dry? Is it referencing that oil that you spray on a k&n?
  8. Dec 18, 2017 at 6:57 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Dry has orifices thru the filter that are very tiny. Dirt is supposed to not fit thru.
    Oiled has bigger openings and oil sails thru the openings to grab dirt as it tries to enter. And dirt collects on the outside of filter and clots up further filtering the incoming air.
  9. Dec 18, 2017 at 7:56 PM
    TundraTss
    Brandon
    2019 TRD SR5
    Makes sense.
    Thanks for the info. I’ll look into the AFE then.
  10. Dec 18, 2017 at 8:01 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Tuner. I'm not saying it'll give better performance but it will change shift points and feel peppier. It's kinda like driving in tow/ haul mode all the time.
    TundraTss[QUOTED][OP] likes this.
