Cabin air filter flow direction
Discussion in 'General Tundra Discussion' started by joonbug, Jul 1, 2018.
  1. Jul 2, 2018 at 3:18 PM
    geno0506 likes this.
  2. Jul 2, 2018 at 6:33 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'm with ya Joon. I replaced my filter last week and it had arrows for "air flow direction" not a "this side up" arrow. I made the assumption that the air flows down from the cowl, plus the top of the filter is what gets nasty. But that was just an assumption and I could be wrong.
  3. Jul 2, 2018 at 6:38 PM
    geno0506
    geno0506 New Member
    Michael
    That was my thinking as well before!
    831Tun and Pudge[QUOTED] like this.
  4. Jul 2, 2018 at 7:02 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Iv been using these..https://www.amazon.com/CF10285-Fresh-Breeze-Filter-Hammer/dp/B001CEG90I
    This post made me go check plus its been about a year since i changed the filter. I pulled the old one out and opened a brand new filter...get this.. The sides are different colored on the Fram filters.. one arrow goes one way on one and th other way on the other one..:der: Also one filter has more pleats than the other.. Im done with Fram after this. This is the only application where i ever used fram as i think they are not good otherwise.
    joonbug[OP] and NewImprovedRon like this.
  5. Jul 2, 2018 at 7:11 PM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Just did mine today . Mine said air flow goes down.
    coldcanuk, Black Wolf and Pudge like this.
  6. Jul 2, 2018 at 7:26 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Air flows from top to bottom
    TheBeast, coldcanuk, Dougr6 and 4 others like this.
  7. Jul 2, 2018 at 7:27 PM
    [​IMG] That makes so much sense too!
  8. Jul 2, 2018 at 7:46 PM
    Tacogrande
    Jeremy
    Yep so the debris doesnt fall out when you remove the filter...problem is some filters have air flow direction with air flow, some only have arrow and oem has arrow up but the air flows opposite the arrow on the oem. On my Frams, one had air flow with arrow..the other had only arrow. lol
    joonbug[OP] and 831Tun like this.
  9. Jul 5, 2018 at 7:47 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    One time I pulled out a K&N cabin filter ... cracked me up thinking K&N pro ably charges 100 bucks for the damn thing. Then I looked at it closer, the damn genius that owns the car sprayed it with K&N air filter oil. Smart people
    Pudge, 831Tun and landphil like this.
  10. Jul 25, 2018 at 10:11 AM
    Bringing this thread back, as I just changed mine out, the label on the old CF was printed on correctly as the arrow label on plastic cover, I just bought a new one same brand Frame and the printed label on the side was upside down!?!?! WTF?!?! I called Fram, spoke with the tech, he said point arrow in direction of airflow which is down
    geno0506 and JoshuaA like this.
  11. Jul 25, 2018 at 10:21 AM
    Bueller?! Bueller??
  12. Jul 25, 2018 at 10:34 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    exactly, dealers have to love cabin filters. Just a few minutes to change out and easy to convince the naïve that they need one. Dealer said I needed one last oil change. Pulled it out 2 days ago and knocked and blew some debris out of it and it is fine. I found it interesting that on the side of the filter it says "Non serviceable". Loose particles are not a problem. It is accumulating dust that kills them. Mine had none.
    joonbug[QUOTED][OP] likes this.
  13. Jul 25, 2018 at 10:37 AM
    Tacogrande
    Jeremy
    That's what I was saying earlier! look at these pics.. on the fram there is a dark side and a light side. Newest filter on the left is opposite of the used one. Also notice the difference in pleats. So is the dark side supposed to be inflow or outflow?
  14. Jul 25, 2018 at 10:52 AM
    15whtrd
    15whtrd Mr. Blonde
    I would say if it says up, put that side up. If it says airflow this direction. Point it down. I think typically the filters are flowing down because that’s where all the debris is going to build up. It wouldn’t make sense for it to flow up.
    joonbug[OP] likes this.
  15. Jul 25, 2018 at 10:52 AM
    The Frame tech said go with airflow direction in truck which is down, he told me stick a piece of paper hold onto turn A/C airflow was goin down, the old Fram CF had one side white and a dark side with the printed label facing up as the plastic cover indicated, now the new same brand filter was white on both sides and arrow or label pointing down, Fram tech said point down
  16. Jul 25, 2018 at 10:54 AM
    Take your filter out turn your A/C on, my AF was going down
  17. Jul 25, 2018 at 10:57 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Have a smoker blow through it both ways and see which is better. Then put it in the direction of flow.
    TXMiamiFan likes this.
  18. Jul 25, 2018 at 10:59 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s what I’m saying. My filter gets dirty on top. That means the air is flowing down. So if the filter says this side up just put that side up. Most likely that filter was meant for your car so they’re making it easy. But at the same time confusing people with the difference of this side up, or airflow this direction LOL.
    Pudge likes this.
  19. Jul 25, 2018 at 11:00 AM
    #49
    So the printed label IS UPSIDE DOWN?
    15whtrd[QUOTED] likes this.
  20. Jul 25, 2018 at 11:01 AM
    #50
    Call Fram see what they tell you
  21. Jul 25, 2018 at 11:02 AM
    #51
    Tacogrande
    Jeremy
    The frams have a dark side and a light side...My old one i had in opposite to how i now have the new one in. lol So the new one (pic on the left) i installed with the dark side up. Fram screwed up on the old ones im guessing. Just compared the OEM filter to the Fram and the Fram is more substantial.
  22. Jul 25, 2018 at 11:05 AM
    #52
    15whtrd
    15whtrd Mr. Blonde
    I bet it doesn’t make that much of a difference. Probably not that high-tech LOL
    Beep88 and NewImprovedRon like this.
  23. Jul 25, 2018 at 12:00 PM
    #53
    Pudge
    CT
    My guess is that it really doesn't matter as long as if you take it out to clean you put it back in the same way
  24. Jul 25, 2018 at 12:18 PM
    #54
    o_O
    2018TundraLimited likes this.
  25. Jul 25, 2018 at 12:29 PM
    #55
    Tacogrande
    Jeremy
    It it
    Maybe but I am big on air filtration.
  26. Jul 25, 2018 at 12:32 PM
    #56
    15whtrd
    15whtrd Mr. Blonde
    I would assume that the dark side is Carbon? If that’s the case I would think you would want the carbon side towards the outlet. Similar to a water filter. Carbon being the final filtration stage.
  27. Jul 25, 2018 at 1:35 PM
    #57
    Tacogrande
    Jeremy
    Hmm..I will call them tomorrow. No time today.
  28. Jul 25, 2018 at 2:48 PM
    #58
    Ericsopa
    Ericsopa Old man and the sea
    Hot damn!! 59 posts on "which way is up!?!"
    toyofan87, joonbug[OP] and 15whtrd like this.
  29. Jul 27, 2018 at 9:05 AM
    #59
    Tacogrande
    Jeremy
    That number is not in service. :eek:
  30. Jul 27, 2018 at 9:30 AM
    #60
    Tacogrande
    Jeremy
    Fram says the arrows don't matter. The dark side is impregnated charcoal and the light side is baking soda. He said they are doing away with the arrows in the future. Lol
    NewImprovedRon and 15whtrd like this.
