Cab mount chop
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erichudgins, May 17, 2018.
  1. May 17, 2018 at 1:17 PM
    Erichudgins
    Erichudgins [OP] New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Is there a kit for this??
  2. May 17, 2018 at 1:18 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    joonbug likes this.
  3. May 17, 2018 at 1:55 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    dcsleeper408[QUOTED] likes this.
  4. May 17, 2018 at 1:57 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  5. May 17, 2018 at 3:56 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
  6. May 17, 2018 at 3:57 PM
    TheBeast The Beach
    relentless good to go.. got them on my truck, lot more clearance now
    Erichudgins[OP] likes this.
  7. May 17, 2018 at 4:40 PM
    blizz86
    blizz86 New Member
    most shops that will weld these on for you can cut them there for you to match their cut perfectly. I did mine yesterday for $120 (including cut, plate, and weld)
  8. May 18, 2018 at 5:34 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Relentless ordered!
  9. May 18, 2018 at 6:18 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    it is easy to cut them if you have a hand held grinder there is nothing to it, i did my tacoma and my tundra also. i never even had my tacoma re-welded, i just drove it like i stole it for 150,000 miles with holes there and sold it that way. i did order relentless's plate for my tundra, will try and get them on sometime this summer, i just soaked the spots with paint so they won't rust for now.
  10. May 18, 2018 at 10:05 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
  11. Aug 28, 2020 at 7:33 AM
    IrishRanger2020
    IrishRanger2020 New Member
    Tundra TRD
    Anyone here done a chop on a 2020 tundra theres a bigg as bolt in the way of where the BMC should usually be cut back to!
  12. Aug 28, 2020 at 11:57 AM
    treetreego
    treetreego New Member
    MS
    2020 Tundra Crewmax TSS 4x4
    295/65/20 Nitto Trail Grappler MT on Fuel Mavericks, Leveled
  13. Aug 28, 2020 at 1:10 PM
    IrishRanger2020
    Tundra TRD
    Thats the one, i dont really want to cutting into that lol how do i post a picture on this?
  14. Aug 28, 2020 at 1:15 PM
    treetreego
    MS
    there's a button towards the bottom right when you post a reply that says "Upload a File"
  15. Aug 28, 2020 at 4:54 PM
    IrishRanger2020
    Tundra TRD
    Thanks @treetreego il show you this hack job here now....
  16. Aug 28, 2020 at 5:12 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    I never understood why people weld a plate on it. There’s a 2” hole in the bottom! No way it adds more strength and it will hold dirt in more with the plate welded on it. Out of all the people running CMC’s and the millions of miles, never heard of the mount cracking after a CMC.
  17. Aug 28, 2020 at 5:24 PM
    Elduder
    Elduder New Member
    Body mount bushing will take a beating when the tires are feeding it dirt and gravel constantly. It is open, so they wear either way, but a daily sand blasting isnt great for it.
  18. Aug 28, 2020 at 5:32 PM
    KENNY
    KENNY New Member
    On my '20 with SDHQ plates. You dont cut into the head just right at it, and be careful how far down your grinder goes so you don't get into the threads. I liked how these plates were stamped towards the inside :thumbsup:
  19. Aug 28, 2020 at 6:19 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Have you ever heard of that one bushing failing prematurely/prior to any of the other bushings? I’ve been around modded Toyota trucks a long time and I haven’t.
  20. Aug 28, 2020 at 7:49 PM
    Elduder
    Elduder New Member
    Dont get me wrong, not saying either way is better or worse here. I have once, seen on a FJ where the body mount was pretty tore up after more than a couple years of it being exposed. The owner did replace them and enclose the area. Its not a fair comparison though, most people enclose the chop, so there will be a lower frequency of failure occurring with it exposed. It doesnt mean its less likely to happen, just that we wont see it often. I think this would be better answered by people like Relentless or SDHQ as they deal with these things much more than we do.
  21. Aug 28, 2020 at 9:08 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Interesting. Thanks for your input.
  22. Aug 28, 2020 at 10:37 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You cut up to that bolt, but mostly you’re cutting off that big bulge on the outer side of it.
  23. Aug 28, 2020 at 10:46 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    What Joon said..
    joonbug[QUOTED] likes this.
  24. Aug 28, 2020 at 11:21 PM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    You weld the plate on because after cutting out all of the vertical support on one side of the cab mount, it loses a lot of its strength. The hole in the bottom is irrelevant.
    Just look at the photo that @saybng posted compared to this. It’s the same reason you don’t side load an I beam. It has all of its strength in the same direction as the web.
