CAB AND DOOR SIZE
Discussion in '3rd Gen Tundras (2022+)' started by FO LO, Oct 5, 2021.
  1. Jan 24, 2022 at 10:21 AM
    #151
    PermaFrostTRD
    Northern NY
    Yikes!
  2. Jan 24, 2022 at 10:23 AM
    #152
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    About 1 foot. ;-)
  3. Jan 24, 2022 at 10:35 AM
    #153
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Door size definitely matters. The dc taco and the dc tundra have very similar legroom numbers, however the door on the tundra is smaller
  4. Jan 24, 2022 at 11:14 AM
    #154
    raylo
    Frederick, MD
    Sure bigger doors make it easier to get stuff in there. But I think we have a disconnect because Toyota names the cabs different from Tacoma to Tundra. The Tacoma Double Cab is a crew cab and the Tacoma Access Cab is just a small space with fold down jump seats while the Tundra Double Cab is a real bench seat just stuffed into a smaller space than the CrewMax. The Tundra DC space is bigger than a Tacoma Access Cab space for sure but the door opens the other way which might make it harder to slide stuff in there. I need to see one in person. Why Toyota calls a crew cab a CrewMax in Tundra and then call a crew cab in a Tacoma a Double Cab is beyond me.
  5. Jan 24, 2022 at 12:10 PM
    #155
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My guess is physical size/truck ratio is similar DC to DC
  6. Jan 26, 2022 at 1:32 PM
    #156
    ralston
    ralston New Member
    The DC back seat access is definitely tight, but it’s about the the same as in your AC Tacoma. So if you’re used to that, you’ll be fine. If you were hoping to gain access, the DC rear door is not for you.
  7. Jan 26, 2022 at 4:30 PM
    #157
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    My AC Tacoma door space is a lot bigger then my DC tundra. But the DC backseat room and quality is way bigger and better obviously.
    ralston[QUOTED] likes this.
  8. Jan 29, 2022 at 12:28 PM
    #158
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    It looks to me as though both model cabs are 2-3" shorter than the outgoing generation. I went for the gen 2.5 DC because it was the largest of the available DC's and closer to the big 3 crew cab. I found the Toyota Crew cab too big. This new generation seems more in line with the others. I'm not interested in the 22 Tundra, but if I was would only consider the Crew Max. The DC is way too small.
