CAB AND DOOR SIZE
Discussion in '3rd Gen Tundras (2022+)' started by FO LO, Oct 5, 2021.
  1. Oct 6, 2021 at 6:37 AM
    #61
    nuclear
    nuclear New Member
    Depends, do your kids have legs?
    FO LO[OP], Kung and Melikeymy beer like this.
  2. Oct 6, 2021 at 6:39 AM
    #62
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    At 930 lbs PL, after adding 2 passengers at 350 lbs you would have only 580 lbs left to tow. My little 22' RV has a hitch weight of 650. I just never realized how much weight that extra bed length adds. NBD for me cause I couldn't deal with driving a truck that long anyway and it wouldn't fit in the garage.
  3. Oct 6, 2021 at 6:49 AM
    #63
    Melikeymy beer
    Muscogee Nation
    @FO LO where did you find the pictures? I haven't seen shit about the 2022 DC. Like, 2 unofficial pictures.
  4. Oct 6, 2021 at 6:53 AM
    #64
    FO LO
    FO LO [OP] New Member
    17 CM w/ 5.7 and 4.30s
    Good ole youtube.
    SR5 DC.
    SR5 Sport DC
  5. Oct 6, 2021 at 7:12 AM
    #65
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Camera guys breathing is creeping me out....
  6. Oct 6, 2021 at 7:26 AM
    #66
    =JSG=
    =JSG= New Member
    2006, 2017, 2021 Tacoma. Soon 2022 Tundra :)
    Paint matched grille surround looks so much better.
  7. Oct 6, 2021 at 8:00 AM
    #67
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Cause the new tundra got nothing but grill, headlights and bumper…
  8. Oct 6, 2021 at 1:56 PM
    #68
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Steel bed is heavy. I think people will appreciate the composite bed for its light weight. There isn't much downside with composite, gets possible payload up, better handling. Combined with rear coilsprings there's a lot of versatility for rear suspension combos.
    I'm sure Toyota's stock rear springs will be soft, they have been on every Toyota I've owned. But it's easy to swap in stouter aftermarket rear coils to increase payload, get better handling.
  9. Oct 6, 2021 at 2:00 PM
    #69
    JuicyJ
    JuicyJ New Member
    You may think you're increasing the payload of your truck by modifying it, but ain't no one gonna sign off on it.
    Cpl_Punishment and GODZILLA like this.
  10. Oct 6, 2021 at 2:10 PM
    #70
    Acedude
    Acedude New Member
    Colorado Plateau
    I should have said "cargo management ability". As soon as one mentions "increased payload" that triggers somebody.
    Let's say stouter rear springs, something that stiffens the rear is a good thing. Is that agreeable?
    Kevmo likes this.
  11. Oct 6, 2021 at 2:32 PM
    #71
    JuicyJ
    JuicyJ New Member
    I'm not "triggered", just pointing out that everyone's so hyper-focused on payload recently, if we're going to adhere to how an OEM arrives at their ratings, I think everyone can agree that in that mindset, we can't technically, officially, increase capacity.
    I'm not so big on the ratings anyway as I often exceed them.
    Terndrerrr likes this.
  12. Oct 6, 2021 at 2:34 PM
    #72
    Being provided a correction that aligns with the actual facts should not qualify as "triggering". It's just somebody making sure that a newbie doesn't come in here and get the wrong idea about payload and how it works.
  13. Oct 6, 2021 at 2:41 PM
    #73
    Acedude
    Acedude New Member
    Colorado Plateau
    Thanks for posting. Ugh, that chin . . . . .
  14. Oct 6, 2021 at 4:35 PM
    #74
    FO LO
    Can you do this with the DC?
  15. Oct 6, 2021 at 4:40 PM
    #75
    FO LO
    Yep here is the 4th gen. 3rd gen wasn't aerodynamic enough
    FlyingWolfe likes this.
  16. Oct 6, 2021 at 4:47 PM
    #76
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    I would do anything to have this truck in my driveway.
  17. Oct 6, 2021 at 5:43 PM
    #77
    Melikeymy beer
    Muscogee Nation
    They're pretty easy to find. Just lay down the $$$.
    =JSG= and Cpl_Punishment like this.
  18. Oct 6, 2021 at 7:58 PM
    #78
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Have to be at work, don't have the software on my personal computer. Has there been a good side on shot for the DC? The ones I remember have been oblique which throws the measurements way off.
    GODZILLA likes this.
  19. Oct 7, 2021 at 9:08 AM
    #79
    belanger9
    Edmonton, AB
    A bunch
    Angles are messed up on the 2.5 gen so had to calibrate to the front door assuming it is the same between CM and DC. 3rd gen is calibrated to 20" rims
    Tundra'25, JuicyJ, FO LO[OP] and 2 others like this.
  20. Oct 7, 2021 at 9:11 AM
    #80
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    This is great!
    Winning8 likes this.
  21. Oct 7, 2021 at 9:20 AM
    #81
    The one you did previously (which is awesome) has smaller front doors on the 3rd Gen CM. Would it be better to calibrate off the CM doors instead of the rims, just to keep the scale correct?
  22. Oct 7, 2021 at 9:32 AM
    #82
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    So the front door is a little longer and the back door is the same. Thank goodness everyone was panicking about it...
    Melikeymy beer, Tundra'25 and stecky like this.
  23. Oct 7, 2021 at 10:16 AM
    #83
    belanger9
    Edmonton, AB
    A bunch
    They're a 1/4" different, put that down to me not picking the exact same pixel between them. And not like these are exact either, but just enough to show there's not huge differences in the 3rd gen.
    There's some crazy optics that's for sure. I was expecting to see them be smaller, not equal or larger (scale and pixel picking issues means don't take these and make your own Tundra at home on these measurements :rofl:)
  24. Oct 7, 2021 at 10:52 AM
    #84
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Close enough for government work.
    Tundra'25, TexAggie and GODZILLA like this.
  25. Oct 7, 2021 at 10:59 AM
    #85
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    Just fudge it...
  26. Oct 7, 2021 at 12:25 PM
    #86
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Just measured my 19 D/C in the same location you have pictured, about an inch above the body crease I get 34 1/8 inches. :)
  27. Oct 7, 2021 at 12:57 PM
    #87
    pnw_rcutv
    pnw_rcutv New Member
    Matter of opinion honestly but I think the Gen3 looks better in just about every facet except for one. Why oh why did Toyota insist on these gawdy complicated odd shaped bumpers??? Seems like somebody from Lexus snuck over here and was like hey guys add some sharp cuts and weird geometry here here and oh here too, people will love it! I understand the aero aspect but they look disproportionate and because how they integrated the fender/flare/quarter panels aftermarket bumper options are likely to involve significant cutting. I'm sure with the forum confirmed $75k base price that is not something most will want to do...
  28. Oct 7, 2021 at 1:06 PM
    #88
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    There’s no fender flares, I don’t like the cut line above the fender lips
  29. Oct 7, 2021 at 1:14 PM
    #89
    pnw_rcutv
    Well your right on that one, I was more referring to the TRD Pro (I probably should have stated that)
  30. Oct 7, 2021 at 1:17 PM
    #90
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The side profile is pretty nice. I initially thought the grill was hideous, but the front bumper might be worse
