C4 Fabrications prototype Tundra bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jimes, Apr 18, 2019.
  1. Mar 20, 2022 at 11:29 AM
    #1471
    sandboxjoe
    sandboxjoe New Member
    Joe
    Chandler, AZ
    2018 Cement Crewmax
    A little bit of this... A little bit of that.....
    Hybrid bumper, standard width, lightbar cutout plus Lp6's and 30" s8 bar. 20220311_074329.jpg
  2. Mar 21, 2022 at 4:33 AM
    #1472
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    Did anyone put some security hardware on the LP9s? If so, do you know the size of the hardware?
    Baja Designs likes this.
  3. Mar 21, 2022 at 4:51 AM
    #1473
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Theres four 1/4”-20 (3/4” long) bolts that bolt the light to the mounting bracket (two on each side of the light).
    Two 1/4”-20 (1” long), and one 3/8”-16 (1” long) bolts that bolt the mounting bracket to bumper.
    You don’t need 7 security fasteners though. Unless you really wanted to I suppose. One on each side of the light (1/4”-20; 1” long), and one for the bracket-to-bumper is enough (3/8-16; 1” long).
    Baja Designs and Legend33 like this.
  4. Mar 21, 2022 at 5:11 AM
    #1474
    Legend33
    Legend33 New Member
    Thanks! I'm just going to switch out the four bolts that mounted to the bracket.
  5. Mar 21, 2022 at 6:53 AM
    #1475
    Uhhhh....
    Dave
    7” BDS, 37s
    Cool. You might reconsider the bracket-to-bumper bolts. Those bolt heads are easily accessible.
    Also, I mistyped above. Here's what I should have written (change bold/underlined):
    You don’t need 7 security fasteners though. Unless you really wanted to I suppose. One on each side of the light (1/4”-20; 3/4” long), and one for the bracket-to-bumper is enough (3/8-16; 1” long).
  6. Mar 21, 2022 at 7:16 AM
    #1476
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    That sucks. Hope it works out.
  7. Mar 28, 2022 at 11:32 AM
    #1477
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Wow, truck looks great, love the color with the wheel accents!!
    texasrho83 likes this.
  8. Apr 18, 2022 at 2:48 PM
    #1478
    pdiddy
    pdiddy New Member
    2017 platinum
    Icon 17 rebounds, total chaos UCA's, general grapplers 35's, corsa exhaust chopped, fox 2.5 DSC coilovers, DAP, white knuckle sliders, voodoo bed rack, baja lights everywhere, VLEDS, bedslide, C4 front bumper, warn winch, victory high hitch with dual swing out rear bumper
    Dropped off for powdercoat today, this bumper is a work of art. Craftmanship and welds are amazing and delivery was one month early.
    Degausser, COTundra23 and Uhhhh.... like this.
  9. Apr 18, 2022 at 2:55 PM
    #1479
    Uhhhh....
    Dave
    7” BDS, 37s
    The welds really are amazing.
    Degausser and pdiddy[QUOTED] like this.
  10. Apr 18, 2022 at 7:30 PM
    #1480
    Legend33
    Legend33 New Member
    Finally able to get the C4 overland bumper on. This bumper looks killer. Can't stop looking at it when walking away. Always turn back and stare at her.
  11. Apr 20, 2022 at 1:01 PM
    #1481
    pdiddy
    pdiddy New Member
    2017 platinum
    Truck looks great. Is there enough clearance to add the LP9's after the bumper is installed? I have all the other lights and winch just need to save scratch for the LP9 later down the road
  12. Apr 20, 2022 at 1:22 PM
    #1482
    Baja Designs
    Bill
    San Marcos, CA
    Hello Pdiddy,
    On page two of the link I included at the bottom of this post; has the size and dimensions if you want to reference that. The Lp6's are roughly 6.5hight/6.5width/3.2depth the lp9s are 8.81hight/8.5width/3.25depth.
    From what I can tell you should be fine fitting the LP9s, on C4's website they do have LP9s on a tundra in the same location as @Legend33.
    Here is the link for more indepth specs to the LP9s:
    https://www.bajadesigns.com/wp-content/uploads/2021/07/LP9-Sport-Data-Sheet.pdf
    Best,
    Brock Brunkhorst
    pdiddy[QUOTED] likes this.
  13. Apr 20, 2022 at 1:45 PM
    #1483
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    I believe he was asking if he'd be able to install them with the bumper already on or if he'd have to remove it from his truck first.
    Baja Designs[QUOTED] and pdiddy like this.
  14. Apr 20, 2022 at 1:48 PM
    #1484
    pdiddy
    pdiddy New Member
    2017 platinum
    thanks
  15. Apr 20, 2022 at 1:51 PM
    #1485
    pdiddy
    pdiddy New Member
    2017 platinum
    Yes that is correct from what I can see seems I can install the LP9's after bumper is installed. Planning to have installed on Tuesday with the warn winch, fogs and light bar. Hopefully add the LP9's later. Any C4 owners out there with LP9's if you can please let me know, thanks.
  16. Apr 20, 2022 at 2:13 PM
    #1486
    Baja Designs
    Bill
    San Marcos, CA
    Okay thanks for the clarification, I apologize, I just reached out to C4 hopefully they will contact me and let us know.
    Best,
    Brock Brunkhorst
    pdiddy likes this.
  17. Apr 20, 2022 at 3:20 PM
    #1487
    Baja Designs
    Bill
    San Marcos, CA
    Hey Pdiddy I got an answer from C4,
    "He should be able to install them after the bumper is on however, if he has a light bar installed into the bumper as well thats going to make it very difficult to get the hardware installed for the LP9's. There is only about an inch of space between the top of the light bar and the bottom edge of the top of the bumper where the LP9 bolts go through so its going to be a struggle to get the nuts and bolts in place. I would definitely recommend installing the LP9's with the bumper off the truck or at least loosen all of the bumper mounting hardware quite a bit so that the bumper can tip forward from the grille. That may give him enough room to reach in and install the hardware a bit easier.
    Let us know if we can help with anything else, thanks"
    I hope this helps
    Best,
    Brock Brunkhorst
    equin, Degausser and pdiddy[QUOTED] like this.
  18. Apr 20, 2022 at 4:12 PM
    #1488
    pdiddy
    pdiddy New Member
    2017 platinum
    thanks Brock can I PM a question thnaks
  19. Apr 20, 2022 at 4:34 PM
    #1489
    Baja Designs
    Bill
    San Marcos, CA
    Absolutely or shoot me an email brockb@bajadesigns.com
    texasrho83 and pdiddy[QUOTED] like this.
  20. Apr 20, 2022 at 4:35 PM
    #1490
    pdiddy
    pdiddy New Member
    2017 platinum
    Baja Designs[QUOTED] likes this.
  21. Apr 20, 2022 at 8:03 PM
    #1491
    Legend33
    Legend33 New Member
    Thank! Yes, the LP9s should fit just fine. It will be a tight squeeze getting your hands to tighten the mounting bottom bolts, but its do-able. If you planning to add the LP9s later.
    Baja Designs and pdiddy[QUOTED] like this.
  22. Apr 21, 2022 at 8:36 AM
    #1492
    pdiddy
    pdiddy New Member
    2017 platinum
    Sounds good thanks for the help
  23. Apr 25, 2022 at 4:00 PM
    #1493
    pdiddy
    pdiddy New Member
    2017 platinum
    Anyone running security bolts on their LP9's? What size are they, I assume 4 bolts from light housing to LP9 light is needed? And which site is the best place to buy. Just ordered my LP9's with Brock, he's been a great help. Looking like 10 weeks out on the lights.
  24. Apr 26, 2022 at 11:31 AM
    #1494
    Legend33
    Legend33 New Member
    Scroll up to post #1475. Answered is on that post thanks to @Uhhhh....
  25. May 5, 2022 at 2:27 PM
    #1495
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Love mine with all the BD lights...two outstanding companies with a great partnership. Anyone know what skid plates work on this bumper? Don't want the flimsy stuff...
  26. May 5, 2022 at 4:52 PM
    #1496
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Looking good. I have RCI skids (aluminum) with no issues
  27. May 23, 2022 at 1:55 PM
    #1497
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    It’s about to go down!
  28. May 23, 2022 at 6:24 PM
    #1498
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    I had finally broke ordering one this week.
    Booney likes this.
  29. May 23, 2022 at 9:05 PM
    #1499
    Booney
    Booney New Member
    I ordered an Overlander on March 8. They told me that the lead time would be around 11 to 12 weeks but on their site it said 14 weeks. I am right at 11 weeks now and no joy yet.
  30. May 24, 2022 at 6:58 AM
    #1500
    Part_time
    Oregon
    Dam it will be fall before I get mine.
