C4 Fabrications prototype Tundra bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jimes, Apr 18, 2019.
  1. Sep 28, 2021 at 8:54 AM
    #1141
    COTundra23
    COTundra23 New Member
  2. Sep 28, 2021 at 8:55 AM
    #1142
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    One more week and I'll be looking like that too :bananadance:
    COTundra23[QUOTED] likes this.
  3. Sep 28, 2021 at 8:57 AM
    #1143
    COTundra23
    Nice!! Worth the wait.
    TXMiamiFan[QUOTED] likes this.
  4. Oct 3, 2021 at 8:22 AM
    #1144
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Hopefully they have a Black Friday deal again this year!! Did anyone get one last year and remember the deal? Just so I have an idea of the price.
    Thanks in advance
    -Edsel
  5. Oct 4, 2021 at 1:25 PM
    #1145
    empenaflor
    empenaflor New Member
    2014 TUNDRA 4X4 LTD - Black
    If I remember correctly, it was 10% off. It essentially paid for the shipping and tax.
    Damie Street[QUOTED] likes this.
  6. Oct 6, 2021 at 4:03 AM
    #1146
    Damie Street
    Edsel
    South Carolina
    Awesome. Thank you.
  7. Oct 6, 2021 at 3:30 PM
    #1147
    TXMiamiFan
    Jose
    Finally got mine on! :bananadance:
    equin, TheBeast, Bigboitundra and 3 others like this.
  8. Oct 6, 2021 at 4:27 PM
    #1148
    TheBeast The Beach
    correct but since then prices went up 15 to 20% because of the rona..
  9. Oct 7, 2021 at 1:21 AM
    #1149
    Damie Street
    Edsel
    South Carolina
    They raised their price? Dang
  10. Oct 7, 2021 at 9:12 AM
    #1150
    TheBeast The Beach
    TBH everyone in the industry because of steel/ Aluminium prices and labor shortages
  11. Oct 7, 2021 at 9:24 PM
    #1151
    Damie Street
    Edsel
    South Carolina
    I can understand that. Plus inflation. Stuff is always cheaper a year or two ago from today.
    TheBeast[QUOTED] likes this.
  12. Oct 13, 2021 at 11:01 AM
    #1152
    Mrf1987
    Mrf1987 New Member
    2020 Trd sport tundra
    Hey Guys, has anyone with kings that installed a c4 bumper also changed out their springs on their coilovers to #700? im currently waiting on my hybrid bumper and i have a set of ext travel 2.5’s with 600lb springs. I purchased a set of #700lb springs also for them to install.
    ErikTRDTUNDRA likes this.
  13. Oct 13, 2021 at 12:46 PM
    #1153
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    I am running 650lbs springs with my C4 overland + winch and belly skids. Overall I am happy with the ride. I ran 700 lbs springs on my Tacoma with equivalent parts, and figured that would work well for the tundra also. But after to speaking with Filthy Motor Sports went with the 650lbs springs. After doing a bit more research decided that 700 lbs springs will work but you you should most likely be doing some valving changes also for the extra weight (very summarized description).
    edit: lots of guys running 700 lbs springs though and are very happy with it.
  14. Oct 13, 2021 at 1:54 PM
    #1154
    Mrf1987
    Mrf1987 New Member
    Thank you for your reply. I was thinking maybe trying the 600lbs that are currently on it but my end goal is to take some preload out of the coil over with the 700s to achieve a similar ride comfort speaking. I am also running a 1/4” spacer atop the coil over and want to get rid of that being that inalready have extended coilovers and my dropout is even further now. I only have 5k miles on the coilovers so i don’t want to pull apart for a revalue right now. 99% of the off-road i do is slower speed stuff no jumping or bombing down trails. I also have compression adjusters as well. Thanks
  15. Oct 13, 2021 at 3:44 PM
    #1155
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    How much total lift do you have and what do your CV angles look like? Are you wanting run a winch? If no winch or synthetic winch I would try the 600lbs springs first and go from there. I had about 1/4” change when I added my bumper/winch with the 650lbs springs but it actually brought the truck more to where I wanted at about 2 inches of lift. The heavier spring rate will definitely make it feel more harsh at slower speed on road and off for your described use.
  16. Oct 13, 2021 at 4:07 PM
    #1156
    Mrf1987
    Mrf1987 New Member
    I actually took some preload out of my kings recently. I’m not exactly sure how much preload i have now. I would say they are probably only a turn or 2 past what they came pre set at. Yes i plan on running a winch and i also just added an arb dual compressor and am waiting on a bigger battery. I also purchased Baja xl/squadron/s1 for both sides of the bumper along with an s8 and 2 lp6’s. My cv angle isn’t great but no issues with leaking cv’s or worn boots. My end goal is to not go for a big amount of lift.
  17. Oct 13, 2021 at 5:40 PM
    #1157
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    Sounds like a good set up. I would put it on and then see if you need extra spring. The other thing would be to remove the top spacer on those Kings and adjust your preload to your desired height. If you are running aftermarket UCAs you can go up to 3” of lift. Keep in mind that is max and they operate better in the 2-2.5 inch range. Also keep in mind the spacer is nothing more than height and with the extended travel coil overs you can over droop the capability of the CV axle and UCA (sorry if you are already aware of all of this, but I would try what you have before changing your springs on a very capable OEM replacement setup.)
    Mrf1987 likes this.
  18. Nov 6, 2021 at 1:41 AM
    #1158
    Damie Street
    Edsel
    South Carolina
    Waiting for their Black Friday deal! Pulling the trigger this year!!
    3jet3 and YotaBro like this.
  19. Nov 9, 2021 at 7:27 AM
    #1159
    3jet3
    3jet3 New Member
    FL
    2021 Tundra TRD
    ----Suspension---- 6112 Bilstein Front 5160 Bilstein Back 3 CB .5" Shims(2 driver side, 1 passenger) CB 3+ Shackles Differential Drop kit Carrier Drop kit ----Wheels---- Tires - Falken WildPeak A/T- 295 70 18 Wheels - Raceline Gauge 18" ----Accessories---- GoRhino RB20 Running Boards
    Will be getting this if deal arises !
  20. Nov 9, 2021 at 9:22 AM
    #1160
    Deepsea121284
    Deepsea121284 New Member
    Emailed them and they said no Black Friday deals this year as they are trying to catch up on their backlog.
  21. Nov 9, 2021 at 9:26 AM
    #1161
    Damie Street
    Edsel
    South Carolina
    That’s not what I wanted to hear
  22. Nov 9, 2021 at 9:32 AM
    #1162
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Where's the 'dislike' button? That sucks, I was hoping for a sale.
    Edit: thanks for checking with them & letting us know.
    Damie Street likes this.
  23. Nov 9, 2021 at 9:37 AM
    #1163
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    I save 5% off on my Front Overland Bumper using "Recover5" pulled the trigger on it like last week.Can't wait!
    Hopefully it works for others in here that's looking to pull the trigger on it
  24. Nov 9, 2021 at 9:53 AM
    #1164
    Damie Street
    Edsel
    South Carolina
    Thank you
    Thank you. The code works!
    Legend33[QUOTED] likes this.
  25. Nov 9, 2021 at 9:58 AM
    #1165
    Damie Street
    Edsel
    South Carolina
    Is anyone using a Factor 55 Hawse Fairlead and their Prohook?? If so, can you post pics please and thank you.
    -Edsel
  26. Nov 10, 2021 at 5:12 AM
    #1166
    Damie Street
    Edsel
    South Carolina
    Placed my order! Ending up getting 10% off. So I went ahead and pulled the trigger. According to their website the lead time is 14 weeks. Getting it shipped to the shop that will be installing the bumper, wench, lights, and aux battery in the bed of the truck.
    Next up, putting a 50% down payment of the AT Overland Summit. Then will have to start a build thread.
    YotaBro, COTundra23 and pandapro like this.
  27. Nov 10, 2021 at 5:54 AM
    #1167
    Uhhhh....
    Dave
    7” BDS, 37s
    How'd you get 10%?
  28. Nov 10, 2021 at 5:59 AM
    #1168
    Damie Street
    Edsel
    South Carolina
    Joined their “club” and received an email with their website link. Saved $160ish. Paid for taxes and a little of the shipping charge.
    Went ahead and ordered because they aren’t running a Black Friday sale so any discount helps. The BD lights are going to cost double the amount of the bumper.
    Uhhhh....[QUOTED] likes this.
  29. Nov 10, 2021 at 6:11 AM
    #1169
    Uhhhh....
    Dave
    7” BDS, 37s
    Thanks. Yeah the BD lights will cost a fortune. Thankfully I already have a 30" BD bar with my current bumper. But just 2 LP9's will be like 1200 bucks. It's werf it if you have the money to blow - that 30" BD bar I have throws a crazy amount of light.
  30. Nov 10, 2021 at 6:11 AM
    #1170
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Hit up @memario1214 for your lights.
    Dawoofles, YotaBro and SAGE63 like this.
