C4 Fabrications prototype Tundra bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jimes, Apr 18, 2019.
  1. Feb 9, 2021 at 3:24 PM
    #661
    Zero One Actual
    I have it and to me it’s the cheapest way to the warn warranty and customer service. It is made overseas, so be aware if that. I don’t use mine daily and I live in the south east, so it will do everything I will ever need it to do.
    YotaBro[QUOTED] likes this.
  2. Feb 9, 2021 at 4:17 PM
    #662
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Yeah, that's what I'm thinking too. Where did you buy yours from?
    You didn't have to relocate your control box, right?
  3. Feb 9, 2021 at 5:13 PM
    #663
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I just got my shipping notice from C4 on my bumper....original date was 2/28 when I bought it on Black Friday. Pretty darn good. By the way I got my gen 3 smittybilt thru 4 wheel hardware...
    gabex35, YotaBro and Skey44 like this.
  4. Feb 9, 2021 at 5:18 PM
    #664
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Umm I have to say something... tss issues with that stinger? What size tires @GreatBasinTundra? Just 35’s lol? Looks good!
  5. Feb 9, 2021 at 9:58 PM
    #665
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    You will most likely have issues if you don’t have the Pro grill. Yep just 35’s. Already wishing they were 37s but now I have some more work to do.
  6. Feb 10, 2021 at 2:18 AM
    #666
    Zero One Actual
    I purchased mine through a large wholesaler off of eBay in CA.
    I did not have to relocate the control box but be aware you can not access the plug for your controller so wireless is your only option. If that stops working you are SOL. @El Two showed me this accessory which I will be getting and running from the control box to an access point yet to be determined.
  7. Feb 10, 2021 at 5:24 AM
    #667
    YotaBro
    Calvin
    FL
    Thanks!!
  8. Feb 10, 2021 at 9:20 AM
    #668
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    Good to know. I bought it on black friday and had same completion date.
  9. Feb 10, 2021 at 9:27 AM
    #669
    gabex35
    San Diego
    Is it absolutely not possible or would a smaller or forced hand work to get it hooked up?
  10. Feb 10, 2021 at 10:04 AM
    #670
    java230
    java230 New Member
    Relocate the plug, not hard. Its 6 conductor, I had 8 conductor wire.
    Yes I was impatient and the paint wasn't hard :D its right in front of the washer bottle now.
  11. Feb 10, 2021 at 6:03 PM
    #671
    Zero One Actual
    Let me do some research on that before I answer definitively.
  12. Feb 10, 2021 at 11:36 PM
    #672
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    I am able to plug mine in. It’s not the easiest thing to do but does work. An extension like @java230 did would be the way to go if you are planning on frequent use.
    gabex35[QUOTED] likes this.
  13. Feb 12, 2021 at 10:49 AM
    #673
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    How are you guys mounting the extra lights on these, are you drilling the holes for mounting before or after powder coating? If it's after are you just painting the area you drilled out for the mounts?
    Or does this thing have mounting points all over for all these extra lights I see
  14. Feb 12, 2021 at 11:07 AM
    #674
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    There are only mounts for the light bar and fog lights. You would need to drill any other hole to mount the light you want, preferably before powder coat.
  15. Feb 12, 2021 at 11:13 AM
    #675
    TheBeast The Beach
    need more pics on some gen 2 tundras :)
  16. Feb 12, 2021 at 1:07 PM
    #676
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    I drilled holes prior to mounting the bumper. This ultimately was not ideal. The back of the lights hit the grill once the bumper was installed and significant modification to the light mounting brackets was required. I did not want to drill additional holes in new PC.
  17. Feb 12, 2021 at 1:26 PM
    #677
    eick
    eick New Member
    So mount the bumper raw, mount lights/drill holes, then take off to get powder coated? Sounds like a plan
  18. Feb 12, 2021 at 1:36 PM
    #678
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    that's what I would do, if it did it over. The stock stuff comes of easy enough and you don't have to have the C4 bumper exactly in place. The other option is to go with a narrower light, like the LP9 or something of similar dimensions. I went with a slightly deeper light and contacted the grill by about 1/2" due to wider bracket and light. It's also not the end of the world to drill a few holes through PC. Just make sure to paint the exposed metal.
  19. Feb 12, 2021 at 1:48 PM
    #679
    YotaBro
    Calvin
    FL
    If you haven't received your bumper yet, you could ask C4 to make the holes for whatever light that you plan on running.
    Zero One Actual likes this.
  20. Feb 12, 2021 at 2:06 PM
    #680
    CallsignReaper3509
    CallsignReaper3509 New Member
    tony
    Grey SR5 crewmax V8
    king full sus lift method mr7s falcon wildpeaks,onto diamond back cover next and full overland
    Love the concept fell inlove when I first saw them they have two models with different height bull bars or with out pricey as is, and don’t get all the light options you’ll rack up to thousands just get it blank n do it yourself still waiting for mine to come through
  21. Feb 14, 2021 at 7:26 AM
    #681
    eick
    eick New Member
    I ordered literally two minutes before reading this post! I am going to contact them, thanks!
  22. Feb 14, 2021 at 7:46 AM
    #682
    Zero One Actual
    They pre drilled mine for my LP9’s.
    eick[QUOTED] likes this.
  23. Feb 14, 2021 at 7:56 AM
    #683
    YotaBro
    Calvin
    FL
    They also pre-drilled my LP9's on request, I would just provide the dimensions of your light and I wouldn't see any issue with that.
  24. Feb 14, 2021 at 8:25 AM
    #684
    eick
    eick New Member
    Yea now that I think about it I may just wait on the pre-drilling. You guys with those LP9's! Those are gonna cost more than the bumper did so I may look for other options (not Amazon though)
  25. Feb 14, 2021 at 9:04 AM
    #685
    dkrou
    dkrou New Member
    dan
    2019 tundra
    You know this really pisses me off...they don't even ask if you want holes pre- drilled just if you want those lights. Of course I have the bumper drop shipped to the PC so now I can't really drill holes in advance...what a cluster.
  26. Feb 14, 2021 at 9:06 AM
    #686
    YotaBro
    Calvin
    FL
    I got the sports, you save quite a bit especially if you work with a 3rd party vendor.
  27. Feb 14, 2021 at 9:09 AM
    #687
    YotaBro
    Calvin
    FL
    If they haven't shipped it yet, it may be worth asking them. I had to request the light holes as well as the light bar opening. They prob do it because not everyone wants to run LP9s. Guessing on this though.
  28. Feb 14, 2021 at 9:11 AM
    #688
    eick
    eick New Member
    Wait it doesn’t come with a light bar opening if you don’t order the light bar with it?
  29. Feb 14, 2021 at 9:13 AM
    #689
    YotaBro
    Calvin
    FL
    I've seen some bumpers without it, if you just ordered it they haven't worked on it yet. Just give them a call/ email with your order number and let them know what all you want.
    I may be wrong on it and the guy without the lightbar cutout might've special requested that.
  30. Feb 14, 2021 at 9:17 AM
    #690
    eick
    eick New Member
    Ah ok, I'm assuming it comes with the fog light and light bar openings (i ordered the overland bumper not the hybrid) but I will email them to verify. It's too expensive of a purchase to not get right
