C vs E rated tires.
Discussion in 'Wheels & Tires' started by euroshowoff, Feb 3, 2025.
  1. Feb 3, 2025 at 1:40 PM
    euroshowoff
    euroshowoff [OP] New Member
    Ronnie
    2024 Limited
    Will a heavier c rated tire ride better than a lighter rated e tire?
  2. Feb 3, 2025 at 2:16 PM
    BIGUGLY
    Paul
    2018 Limited
    It will allow more sidewall flex on a C vs E. E will hold more weight and needs the stiffer sidewall and construction to do so.
    The C should be more flexible and be better able to soak up some shock from the road better then the E.
    The extra weight will not help your MPG's though.
    If you need the extra weight capacity then a C or E is the way to go. If your closer to a P rated tire then maybe a XL load would work better as it's closer to a P rating but with a little extra capacity
  3. Feb 3, 2025 at 3:10 PM
    euroshowoff
    Ronnie
    2024 Limited
    appreciate the feedback. I’m hunting down 35s or 34s and I’ve been looking at the Falken at4w and the Toyo at3. Toyos are lighter, but only e. And falken has c but heavy. I won’t be towing, most I’ll see is fire roads to get to some of my fishing spots.
