Bypass engine oil cooler
Discussion in '2nd Gen Tundras (2007-2013)' started by Miller_j94, Feb 17, 2020.
  1. Feb 17, 2020 at 8:27 PM
    Miller_j94
    Miller_j94 [OP] New Member
    Hi everyone. So I have a 07 5.7L tundra. I have suspicion the oil cooler is getting coolant in my oil so to test this theory I want to bypass the oil cooler then change the oil to see if it stays clean. Has anybody bypassed the engine oil cooler before or is this even possible? Suggestions or advice?
  2. Feb 17, 2020 at 9:34 PM
    Nick T
    Nick T New Member
    Nick
    Disconnect the inlet and outlet coolant lines to bypass.
    You would then need to connect the two lines to each other with a coolant tube connector.
    In order to have corroded the engine oil cooler, your radiator would have corroded and leaked first.
    Have you been running silicate free Asian spec coolant?
    Have you checked your headgasket?
    Is your oil milky? Or was the coolant reported in a used oil analyst report?
  3. Feb 18, 2020 at 4:18 AM
    Miller_j94
    I just bought the truck about three or four months ago. It didn’t have milky oil at first, then I did the oil change and it got milky, it doesn’t overheat. The only sign that anything is wrong is the coolant level going down and the milky oil. The radiator may have been replaced, it looks newish. The water pump definitely was replaced. It’s orange coolant, that says it’s for Toyota, I’ve only ever bought it that but no telling what they used before I bought it.
  4. Feb 18, 2020 at 4:24 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Not all trucks had them. So I imagine that you could get away with it for troubleshooting purposes.
