Buzzing/Rattle Driver Side Dash?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rocko9999, Feb 16, 2022.
  1. Feb 16, 2022 at 2:31 PM
    Rocko9999
    Rocko9999 [OP] New Member
    Anyone else have a rattle that sounds more like a buzz akin to bee in a tin can that sounds like it's coming from behind the instrument cluster or around that area? Only happens at certain rpms 30-60mph. It's maddening.
  2. Feb 16, 2022 at 2:36 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Dude! I have the exact same issue. At lower speeds, on bumpy roads, I also get this plastic/metal tapping noise. Driving me insane.
    I think I am going to try to pop off the dash portion below the steering wheel and take a look. Can't see shit when looking upward from where the pedals are.
  3. Feb 16, 2022 at 2:37 PM
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    Yes and it's driving me to drinking!!!!!
    Except mine is in dash at passenger side. Couple good ol hard slams on that side of the dash seems to temporarily help. I'm still under warranty and of course never able to reproduce when at the stealership...
  4. Feb 16, 2022 at 2:40 PM
    Rocko9999
    If it's on the passenger side footwell it may be the ECU/ECM. https://www.tundras.com/threads/buzzing-ecm-solutions.36116/#post-922114
  5. Feb 16, 2022 at 2:42 PM
    Rocko9999
    I tried banging around the dash when it was happening-nothing. I swear it's coming from directly behind the RPM gauge or thereabouts.
  6. Feb 16, 2022 at 2:42 PM
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
  7. Feb 16, 2022 at 2:44 PM
    Rocko9999
    Ok, try this-wad something like paper towel and wedge it between dash and glass in that area and see if it helps.
  8. Feb 16, 2022 at 2:44 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    Same but I feel like mine is in the lower portion behind the cluster. I could see a metal tunnel that runs up there. Leads me to believe that a wire loom is rattling/tapping on the metal tunnel
  9. Feb 16, 2022 at 3:17 PM
    Randy F
    Randy F New Member
    2021 Voodoo blue tundra sport premium
    I had a very similar rattle. Turns out the way the block heater cord was run it had some slack and was rubbing on the heat shield by the steering column on the fire wall.
  10. Aug 5, 2022 at 11:02 AM
    MLC
    MLC New Member
    2022 Tundra Limited TRD Pak
    Same buzzing / rattle. I just went over 2k miles when it started. So far the sound is clearly heard:
    first time I drive it in the morning even though it’s summer
    Somewhere behind the dash center or 14 in display, or center front speaker
    Seems to be right around 1700 - 1800 RPM at any road speed or gear
    This is strange but for example if something like a large dump truck with a loud exhaust is near, the buzzing gets worse?
    Also strange, I use Car Play which normally works great but during the buzzing/ rattling sound it’s like Siri doesn’t hear me?
    It’s almost seems like some sort of mic / sound system feed back issue or (JBL piped in engine sound)?
    So far this is only forum I’ve read about the problem, but at least I know I’m not the only one with the problem.
  11. Aug 5, 2022 at 11:09 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    My rattle ended up being the driver side hood hinge. Drove me nuts for two months and tore the dash apart 10 times. Ended up stuffing some foam in the hinge area and its been gone for 3 months.....
  12. Jan 13, 2023 at 8:41 AM
    I have a noise that sounds like it's near the speaker or A-pillar area.
  13. Jan 13, 2023 at 9:41 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    For me, the grille on the driver's dash speaker was making a little noise. Probably 'cause a broke a tab on it when removing
  14. Jan 13, 2023 at 10:33 AM
    Rocko9999
    I would pull the speaker cover and put some felt tape on the clips and a few of the plastic to plastic mating surfaces.
  15. Jan 13, 2023 at 11:01 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    at certain temps I get a creak from the drivers side grip handle that I installed, when going over bumps.
    I have tried felt underneath and torquing the grip handle bolts tighter and looser but it still happens.
    I think the trick to not letting these things bother you is to leave some stuff in the truck that rattles louder and you know what it is.
    You just say I need to move that stuff. But you never do..... 8^0
    831Tun likes this.
  16. Jan 13, 2023 at 11:17 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Louder sound system fixes all sorts of undesirable noises.
    borla123[QUOTED] likes this.
  17. Jan 13, 2023 at 11:26 AM
    borla123
    borla123 The Pits
    Ontario
    LOL
    I am an audiophile but in my truck and my car i listen to the exhaust sounds for therapy.
    Tundra234 and 831Tun[QUOTED] like this.
  18. Jan 13, 2023 at 11:30 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    What? I can't hear you over my straight piped V8. LOL
  19. Jan 14, 2023 at 6:14 AM
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    I know it sounds crazy, but make sure your engine firewall (in the engine bay) is tight. I had dash rattles, tightened that and it went away
  20. Jan 15, 2023 at 1:57 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    Thought mine was in that same area. Tore apart the a-pillar and speaker multiple times. Was the good hinge….
  21. Apr 10, 2023 at 9:15 AM
    bentliver
    bentliver New Member
    2022 Tundra 1794 Edition
    2022 Tundra 1794 Edition - started getting what I would call a harmonic vibraiton creating a buzzing sound. Around 30-35mph and around 1800 rpm. Also if a loud truck went by it could also be heard. A freind of mine that works for Toyota and I tracked it down. The plastic cover that sits behind the rearview mirror was the culprit. We pushed on the cover and it "cliped" back into place - have not had an issue since. Hope this helps others.
