Buying advice (rust)
Discussion in '1st Gen Tundras (2000-2006)' started by goodboymiso, Jan 22, 2021.
  1. Jan 22, 2021 at 12:01 PM
    goodboymiso
    goodboymiso [OP] New Member
    Looking at this 2001 with 70k miles. Is this level of rust something i should be concerned about?
  2. Jan 22, 2021 at 12:06 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Looks like some surface rust, but from what the pictures show, it doesn't look too bad. Southern truck?
  3. Jan 22, 2021 at 12:09 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Being in the Northeast that looks super clean. I wouldn't worry about that at all
    FlyingWolfe and MEWaters like this.
  4. Jan 22, 2021 at 12:13 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    First and last pic looks like a huge rusted out area on the frame. Some better pics with some light would be better if you could.
  5. Jan 22, 2021 at 12:16 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    run th vin through my toyota and check for new frame vs inspection
    the frame is cleaner than rest of that undercarriage. Make sure they didn't make it look prett - some decent bubbling on that last pic. Almost looks like they have sprayed parts of the frame black
    as others will say, drop the spare and check there
    cross members
    JimboSlice413 likes this.
  6. Jan 22, 2021 at 12:17 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome and do it!! Congrats
  7. Jan 22, 2021 at 12:48 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I'd bet a dollar that's just surface rust around the area where the 2 box sections are welded together. More common than you'd think. Should be easy to clean up if needed.
  8. Jan 22, 2021 at 12:57 PM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    I second the "look closer" comments. That frame looks "blacker" than I would expect... curious if some quick spray paint was put on.
    Jack McCarthy likes this.
  9. Jan 22, 2021 at 2:03 PM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Definitely received a recent coat of black spray... just look at the rear diff... overspray is visible on the rear brake line and the E-brake cables... Get under there with a light weight ball peen and tap...tap...tap away!
  10. Jan 22, 2021 at 2:24 PM
    Bubbadog
    Bubbadog New Member
    The undercarriage has been sprayed. What are they trying to hide? These types of trucks always make me leary about purchasing. I don't think you can go by photos alone. You really need an in purchase inspection of the undercarriage by someone knowledgeable.
    shawn474 likes this.
  11. Jan 22, 2021 at 2:33 PM
    goodboymiso
    I just ran the VIN through Toyota site and this is the service history, does this mean the frame was replaced?
  12. Jan 22, 2021 at 2:38 PM
    goodboymiso
    dug deeper - looks like the dealer is the one who sprayed it black
  13. Jan 22, 2021 at 2:40 PM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Bring a creeper and ball peen hammer with you and just say your going to take a quick look underneath. :rofl:
    Definitely check the rear axle to see how bad it really is there.
  14. Jan 22, 2021 at 5:47 PM
    TILLY
    Massachusetts
    Judging by the work order and the parts they used it doesn't look like they replaced the frame, only applied the preventive coating. Another clue is the line where they stated they found no rust perforation.
  15. Jan 22, 2021 at 6:10 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I'd dig around under the truck and be rapping the frame with a small hammer before purchasing. As others have said, my used 2006 had the recall corrosion goop applied and the dealer did not goop the axle housing or diff cover. So that's a previous owner paint to prevent rust or paint to hide jobber. Where does the VIN search tell you the truck lived most of its life? If NY, PA, OH, I'd be real thorough in your inspection, they use steel eating acid on the winter roads up there for sure.
  16. Jan 22, 2021 at 6:46 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I would run away from that truck; the history shows there was enough of a frame issue to service it. Doesn’t look like it was replaced. Unless you can get a really close inspection and make sure no rust has perforated the frame I wouldn’t even consider purchasing
  17. Jan 22, 2021 at 9:17 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    vegas4x4 likes this.
  18. Jan 22, 2021 at 9:29 PM
    TILLY
    Massachusetts
    No input on the original question, just a lame meme....congrats.
  19. Jan 22, 2021 at 9:32 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Wanna see more? I have more!
  20. Jan 23, 2021 at 3:16 AM
    shawn474
    MoCo, Maryland
    your opinion differs? Let’s discuss - two documented frame issues on a 20 year old truck with evidence that they sprayed the frame to potentially hide a known issue of frame rust.......additionally if the truck has 70k miles now, that means there have been a grand total of 11,000 miles on the truck in the last 8+ years. That alone would give me pause....add the frame / rust and it seems like a risky investment. OP asked for advice - give your opinion.
  21. Jan 23, 2021 at 3:37 AM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    These frames had a recall. If a stealership replaced and undercoated the frame, it was clearly a recall situation. My money’s on the guys with the memes. :hattip:
  22. Jan 23, 2021 at 3:42 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    That coating is hard coating, if dealer put it on. I would stay away. If I were to thinking about buying that truck. I don't buy any vehicle with that coating on.
  23. Jan 23, 2021 at 4:10 AM
    shawn474
    MoCo, Maryland
    Not every frame was replaced - not even close. There are hundreds of documented complaints where dealerships initially coated the frame and years later trucks failed inspection, frames broke, etc because the cheap fix led to big problems down the road. I don’t think anyone is saying not to buy the truck.......we are simply saying make extra sure that you get under there and investigate the actual issue before you spend the money on it. It’s very hard to tell from the pictures. If there is ANY evidence that the rust is infiltrating the frame, I would not consider buying it. Just my .02
  24. Jan 23, 2021 at 4:31 AM
    MEWaters
    MEWaters New Member
    Maine
    The issue with the dealer coat is it acts just like rubberized undercoating and it eats away behind the facade. For that reason, I would stay away. Because they probably want 7k+ for the truck with that mileage. The driveshaft is a dead giveaway that it’s not organic. if things seem too good to be true, they usually are.
    Can’t we all just get along lolol
  25. Jan 23, 2021 at 7:07 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Check the frame around the gas tank. The bad ones I looked at all had holes or cracks there around the overlap.
  26. Jan 23, 2021 at 7:31 AM
    goodboymiso
    Thanks everyone for the replies. It's an out of state truck so i don't have the opportunity to go inspect further. Purchase price would be $12k and it's otherwise super clean. I guess i'll keep looking.
  27. Jan 23, 2021 at 7:35 AM
    Professional Hand Model
    Hand Protectors
  28. Jan 23, 2021 at 9:19 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    There's a chance that the rust is minor and not an issue. If you live out of the rust belt, you could remedy what little surface corrosion there is and get a long service life out of the truck. A thorough inspection is needed to determine if that's true. The rear brake backing plates aren't all eaten up. The visible hardware doesn't appear to be eaten up either. Signs point to this not being what we all fear. Bottom line though, $12k is big money for a 2001 model truck. The low miles helps the case, but I wouldn't pay close to that for one, even with only 70k on it. I would rather find one in the 150k range that's rust free and well cared for for half that price.
    shawn474 and remington351 like this.
  29. Jan 23, 2021 at 10:08 AM
    remington351
    2006 SR5 DoubleCab
  30. Jan 23, 2021 at 10:35 AM
    goodboymiso
    The market seems pretty high right now, and 12k seems to be what it’s going to cost for anything under 200k miles that’s not rusted out. Even the high mileage trucks are listed above 7k.
