Buying a new 3rd gen...
Discussion in '2.5 Gen Tundras (2014-2021)' started by joem1cha3l, May 1, 2017.
  1. May 1, 2017 at 6:08 PM
    joem1cha3l
    joem1cha3l [OP] New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I'm going to do something I wish I had done the first time. I'm going to make a thread about this so I don't make any other mistakes.
    Looking at a 2016 Inferno Crewmax with TRD Off-road Package. What are some things I should check to see if this truck has?
    Is power rear windshield standard?
    Is 5.7L standard?
    Is the 38 Gal tank standard?
    ^^ Those are all must haves for me.
    NewImprovedRon and T-Rex266 like this.
  2. May 1, 2017 at 6:10 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    The 38 gal tank was part of the SR5 upgrade package for my truck. It comes with the shifter in the center console, not on the column
  3. May 1, 2017 at 6:12 PM
    joem1cha3l
    Albany, NY
    Yeah.. I guess Im a bit confused then. My truck is the SR5 with the center console and I have the shitty gas tank....haha
  4. May 1, 2017 at 6:12 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Is there a picture of a specific truck you are looking at? The 5.7 badge would be a dead give away as well the column shifter to see if it has the bigger tank
  5. May 1, 2017 at 6:12 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    It only comes with the 5.7
  6. May 1, 2017 at 6:13 PM
    joem1cha3l
    Albany, NY
    Im hoping to swing by on Wednesday. They're holding it for me
  7. May 1, 2017 at 6:17 PM
    joem1cha3l
    Albany, NY
    Another question would be:
    Do they all come with a transmission cooler and tow package?
  8. May 1, 2017 at 6:19 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    My only regret is that the SR5 TRD off road package with the bench seat didn't have the 38 gal tank available. My only complaint w my truck.
  9. May 1, 2017 at 6:19 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Ill dig into that for you. However, from what I remember, ALL 5.7's (at least for 2016) came with the towing package which has the tranny cooler, bigger alternator and bigger ring gear
    Krezz and joem1cha3l[QUOTED][OP] like this.
  10. May 1, 2017 at 6:20 PM
    joem1cha3l
    Albany, NY
    Christ, this is sound like a whole different truck than what I have now. And I say that in a good way!
  11. May 1, 2017 at 6:20 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Mine had tow package standard. 17 TRD 4x4 off rd 5.7.
    Luckydwg and joem1cha3l[OP] like this.
  12. May 1, 2017 at 6:22 PM
    You're getting the TRD package so yes, tow package included.
    joem1cha3l[OP] likes this.
  13. May 1, 2017 at 6:24 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Here is the PDF for 2016
  14. May 1, 2017 at 6:27 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    I thought the sr was the only build where column shift. Bench seats, 25 gallon tank were standard..and no badges even on the 5.7l
  15. May 1, 2017 at 6:28 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Is it the TRD off road 4x4? And it needs to be the SR5 up grade package with the bucket seats for the 38 gallon tank sliding rear window and nav. If it is the 5.7 it should have the tow package
  16. May 1, 2017 at 6:30 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Just looked it up. All 5.7's get the tow package in 2016
  17. May 1, 2017 at 6:30 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    '16 TRD OR will come with power rear window standard.
  18. May 1, 2017 at 6:30 PM
    joem1cha3l
    Albany, NY
    Yep, TRD Off road 4x4
    blue16[QUOTED] likes this.
  19. May 1, 2017 at 6:30 PM
    joem1cha3l
    Albany, NY
    Yessssssss, sweet! I've always been so envious of you all with this option haha
    xj2202009 likes this.
  20. May 1, 2017 at 6:31 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    It was a must (and confusing when I bought mine as well) for me too!
  21. May 1, 2017 at 6:45 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Power rear window is standard on crewmax. The 38 gallon tank
    actually, the power rear window is standard on crewmax, regardless of trim or package
  22. May 6, 2017 at 7:42 AM
    joem1cha3l
    Albany, NY
    Ok guys
    2016 Inferno Crewmax 5.7L w TRD package
    24,000 miles
    Dealer is listing it at 36995
    Thoughts on pricing?
    040Tundra likes this.
  23. May 6, 2017 at 7:53 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  24. May 6, 2017 at 7:54 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Post failure ^^^^
    What trim level?
  25. May 6, 2017 at 7:56 AM
    Inferno16
    Inferno16 New Member
    I have exactly what you described. Everything was included. Not sure where you are but in Dallas, TX area, they also include sprayed bedliner and side step
    BEFORE
  26. May 6, 2017 at 7:57 AM
    joem1cha3l
    Albany, NY
    SR5 I do believe
    4WD too
  27. May 6, 2017 at 8:36 AM
    joem1cha3l
    Albany, NY
    What'd you pay?
  28. May 6, 2017 at 8:44 AM
    RatPatrol
    RatPatrol New Member
    When I was looking last month I found 2016 SR5's with nav etc that did not have the 38 gallon tank. It is like someone mention part of a package. A Toyota dealer should be able to verify off of the VIN if it has the 38 gal tank. I went to https://www.toyota.com and in the upper right is a tab called "owners", click on that and go to "Resources" then "vehicle specs" and click on that tab, then input the VIN. It told me if it came with the 38 gal tank. It also told me where it was sold and all the options that were installed and if they were factory or dealer installed.
  29. May 6, 2017 at 8:49 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    In 2016, the bigger tanks were available for the 5.7's with the SR5 upgrade package. The easiest way to tell if a truck has it is if it has bucket seats with the shifter in the center console.
    Bprose likes this.
  30. May 6, 2017 at 9:21 AM
    RatPatrol
    That is what I read on here but I did find 2016 SR5s that had the bucket seats with the shifter in the center console, nav etc but car dealer could not verify that is had the 38 gal tank. When you put the vin in to the Toyota site it tells you if it has the 38 gal tank. All of the Limiteds and up have the 38 so the SR5 is the only one that you need to check. It maybe that it specifically has to say "SR5 upgrade package" these didn't . They were loaded so I thought that they would have the 38.
