Bumper Spacers with Light Bar?
Discussion in '2.5 Gen Tundras (2014-2021)' started by nasher75, Dec 13, 2024.
  1. Dec 13, 2024 at 5:41 PM
    nasher75
    nasher75 [OP] New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Anyone out there running Front Bumper Spacers with a front bumper opening mounted light bar? I'm running Diode Dynamics 42" Light Bar and using @memario1214 upgraded light bar bracket and it doesn't look like there is enough threads to do the full 1/2" spacer install. I purchased the Coachbuilder Spacers, so techincally it is (2) 1/4" stacked spacers, but I'm not confident just (1) 1/4" spacers is going to clear my tire interference.
    Any chance someone out there is running this same combo?
  2. Dec 13, 2024 at 5:45 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I used to run the same setup. I found some lower profile flange nuts that grabbed a little better, but it still wasn’t ideal. Have you looked at pushing the bumper plastics forward and ditching the shims, or dropping to one on each side? Unfortunately there aren’t a lot of options if you want both shims and the Better Bracket.
    nasher75[OP] likes this.
  3. Dec 13, 2024 at 5:50 PM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I ran into the same issue (link to post). I had 1/2" bumper spacers, swapped them to 3/8" thick spacers and it did the trick to allow both the light mount and bumper spacers fit. 3/8" still cleared my tires, but don't recall by how much.
    TRDFerguson likes this.
  4. Dec 13, 2024 at 5:53 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Cheater. :rofl:
  5. Dec 13, 2024 at 5:57 PM
    eccracer104
    San Diego, CA
    Haha what I do!
    Also thinking that changing the hardware to low profile nuts is a really good idea :fistbump:
    TRDFerguson[QUOTED] likes this.
  6. Dec 13, 2024 at 6:06 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You could always just use the better bracket as a shim + just 1 spacer. Theoretically it should jive!
  7. Dec 13, 2024 at 6:24 PM
    nasher75
    Erik
    Los Gatos, CA
    Interesting idea. I guess pushing the light bar 1/4" back in the opening wouln't be all that noticeable. Of course the better bracket is only one side of the bolts, but if my 1/4" spacers are the same thickness, I could just cut 2 of them up. I'll try just the 1/4" spacers 1st and see if I get lucky on tire clearance.
    eccracer104 likes this.
  8. Dec 13, 2024 at 6:25 PM
    nasher75
    Erik
    Los Gatos, CA
    @memario1214 Slightly different topic, but any update on the improved fog light mounting brackets you mentioned in the past. I think they were also for the Diode Dyn. fogs
  9. Dec 13, 2024 at 8:35 PM
    memario1214
    Colton
    Missoula, MT
    Still working at it! We’re close now though.
  10. Dec 14, 2024 at 2:40 PM
    nasher75
    Erik
    Los Gatos, CA
    Luckily, I was able to get away with 1/4" spacers and a little fender liner work. As others mentioned, using the full 1/2" was a no go if using the Better Light Bar Brackets.
    So if anyone else is looking to do this, I have the 2nd set of 1/4" spacers from Coachbuilder kit that I could sell.
