Bumper ends- removed and self sprayed with Herculiner
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ChristianEKR, Jul 29, 2018.
  1. Jul 29, 2018 at 11:07 AM
    ChristianEKR
    ChristianEKR [OP] New Member
    2017 Quicksand CrewMax SR5
    9484D0AD-CD3A-49B6-AC3F-603B254EA626.jpg 261767F3-6150-4EF9-8750-4486B008CE8F.jpg Gents-
    Removed, sanded, etch primed, and herculined (4 light coats sprayed at 8-10 inches) my bumper ends. TRD Pro grille next!
    I’m stoked with how it came out!
    Tony v, tinman10101, Sas and 8 others like this.
  2. Aug 7, 2018 at 8:27 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    Same color truck I have, so I like it! The caps look great, they look good with the center section. Nice job. :thumbsup:
    I just bought the QS grill surround, bulge and pro insert so I may be doing the exact same thing.
    ChristianEKR[OP] likes this.
  3. Aug 7, 2018 at 8:30 AM
    What finish is that? Can we see can and can of primer too please, also that a smooth finish?
    Brian0414 likes this.
  4. Aug 7, 2018 at 8:30 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Looking good! I also want to do this, was it pretty simple to remove the end caps?
  5. Aug 7, 2018 at 8:36 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Did you use the aerosol can or a gun to spray?
  6. Aug 7, 2018 at 8:40 AM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    X2
  7. Aug 7, 2018 at 8:41 AM
    saybng
    Gary
    Ventura CA
  8. Aug 7, 2018 at 8:44 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Tell me more!!! Difficulty level? Cost? Aerosol or spray gun? Durability ratings???
  9. Aug 7, 2018 at 3:07 PM
    ChristianEKR
    So the removal of bumper end was a MONUMENTAL pain in the ass. I watched this video to learn how to remove them. https://www.tundras.com/threads/how...per-caps-2017-and-reinstall.9858/#post-161159 Best tip was to use the ass-end of a screwdriver to put downward pressure on the pressure clips.
    To prep them, I scuffed them with a 3M pad to get some texture on the smooth surface so the primer would grab. Then I used Rust-oleum Self Etching Primer in Gray. https://www.homedepot.com/p/Rust-Ol...f-Etching-Primer-Spray-Paint-249322/202097278
    I did two coats of primer to assure even coverage and full grip for the Herculiner. I used Herculiner in the can as is. No spraygun, just patience and a steady hand! It took a can for the front and a can for the back to do 4 coats sprayed at 8-10”. https://www.jbtoolsales.com/herculi...MInJaM-_fb3AIVDIB-Ch3ofAzjEAQYASABEgJO-PD_BwE
    Total cost was around $75 and total time was around 4 hours, but I was quoted three hundred to have professionally sprayed. I feel like if you are brave, confident, and uninterested in removing your bumper you could spray right on the truck.
    The texture is light rough, like skateboard grip tape, probably equivalent of like a 200-250 grit sandpaper. The durability has been great. I’ve washed it three times since with no peeling! My truck is not garage kept and the sun hasn’t had an impact either. Great for the beach too because the salt water isn’t eating chrome anymore!
    Thanks for all the kind words guys! Glad you guys like it as much as I do!
    NewImprovedRon, saybng, Sas and 2 others like this.
  10. Aug 7, 2018 at 3:11 PM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    Well done Sir!! :cheers:
  11. Aug 7, 2018 at 3:20 PM
    Thanks for the update, I too used that same primer, almost a can for each bumper end front n rear, paint I used was a satin finish krylon paint for metal, believe I did this late summer fall '16 but I didn't do the scuffing of the chrome and now where bugs have hit of rocks hits I have chrome showing, so I need to redo all over again, and I used paint t for plastic for hood buldge and surrounding from bug hits chrome showing, that needs to be done also those were a satin finish
  12. Aug 7, 2018 at 8:24 PM
    ChristianEKR
    So from what I can gather, the texture of the bed liner makes it less prone to chipping/fractures as the molecular structure adheres to the surface AND to itself. We’ll see how it lasts! I’m hoping for good long term hold! Let me know how yours turns out!
  13. Aug 7, 2018 at 8:45 PM
    CCLJ03
    Craig
    Awesome. Thank you for the write up! Currently trying to decide what to do with my chrome bumpers...
    NewImprovedRon likes this.
