Bump Stops
Discussion in 'Suspension' started by TundraRunner481, Mar 22, 2018.
  1. Mar 22, 2018 at 12:46 PM
    TundraRunner481
    TundraRunner481 [OP] Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    When do you need new bump stops? Is it only when doing long travel?
  2. Mar 22, 2018 at 1:59 PM
    Some lifts require bump stop mods.
    Like if you purchased the Bilstein 6112 and put them on the top setting, I do believe a bump stop modification is required.
    rons23, Black Wolf and 831Tun like this.
  3. Mar 22, 2018 at 2:05 PM
    Rica25
    Ricardo
    Tulare
    What about if you did 5100s on highest setting?
  4. Mar 22, 2018 at 2:05 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I have the Wheeler's front super bumpstops (as many others do on here) and will have the Icon hydro bump stops in the rear next week. I am not LT
    dcsleeper408, Black Wolf and 831Tun like this.
  5. Mar 22, 2018 at 2:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I installed Wheelers super bumps up front too and no LT.
    dcsleeper408, GodlessPro and boardude like this.
  6. Mar 22, 2018 at 2:26 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Same
    dcsleeper408 likes this.
  7. Mar 22, 2018 at 2:33 PM
    Rica25
    Ricardo
    Tulare
    Can you post pictures of the bump stops?
  8. Mar 22, 2018 at 2:39 PM
    Hi jack....you buried the Taco yet? Hi jack over. I am going to get a set of bump stops from Wheelers.
  9. Mar 22, 2018 at 2:40 PM
    Check out Wheelersoffroad.com
  10. Mar 22, 2018 at 2:47 PM
    ToyotaTundraMike
    2015 Tundra
    Top setting of 5100 requires some washers under the bump stops is all. Forget which size but dont need new ones.
    Black Wolf likes this.
  11. Mar 22, 2018 at 2:51 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
  12. Mar 22, 2018 at 2:52 PM
    No word yet.
  13. Mar 22, 2018 at 2:53 PM
    GodlessPro
    Matthew
    NorCal
    If you are lifted, Wheelers also sells spacers that you can add under the superbumps.
  14. Mar 22, 2018 at 2:54 PM
    Hope you are having a wake for it...
    Still getting Wheelers bump stops....
  15. Mar 22, 2018 at 3:21 PM
    Rica25
    Ricardo
    Tulare
    So anyone here have 5100s with new bio stops?
  16. Mar 22, 2018 at 3:26 PM
    TundraRunner481
    SB
    So. Oregon
    I planned on doing the boss coilovers, but I may set them at more like 2-2.5 inches. Wondering if it would be better to use the washers wheeler's sells, or do their superbumps? I always read about all these people doing lifts, but not many talk about if they run aftermarket bump stops or not.
  17. Mar 22, 2018 at 3:36 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
  18. Mar 22, 2018 at 3:43 PM
    Rica25
    Ricardo
    Tulare
    Just talked to Keith at Dirty deeds and said nothing is needed
  19. Mar 22, 2018 at 3:44 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  20. Mar 22, 2018 at 3:52 PM
    TundraRunner481
    SB
    So. Oregon
    Good info, it's funny how it is all over the place!
  21. Mar 22, 2018 at 3:54 PM
    15whtrd
    15whtrd Mr. Blonde
    Ordered some super bumps from wheelers for my stock height Tundra
    NewImprovedRon and 14burrito like this.
  22. Mar 22, 2018 at 5:57 PM
    TundraRunner481
    SB
    So. Oregon
    I talked with David at Toytec and he said the Boss kit includes bumpstop washers to extend them. Just FYI.
  23. Nov 23, 2019 at 9:40 PM
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    Big discussion. If you’re referring to longer bump stops, this is only needed if your setup might cause the coilover shaft to bottom out internally which could damage it. This is definitely the case if you use a spacer lift where the spacer bolts on top of the coilover top hat. In this case, you’ve moved the upper portion of the coilover down an inch or so. When the bottom comes up over a hard bump, it’s going to smash the internals and bend or break something. If you use some less expensive lifted coilovers, this could also be the case. But with King coilovers and many others, this isn’t an issue. However, you can improve your bottom out by switching to a better bump stop like the wheelers. Trust me, it will improve your ride by introducing some progressive damping at near bottom out, and a soft bottom out.
    NewImprovedRon, Flyinryank and Rica25 like this.
  24. Nov 24, 2019 at 3:39 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Great info.
    I run these on the front of my Tacoma rock crawler. https://www.summitracing.com/parts/EIB-EBS770060
    The shocks are LONG for maximum droop travel but because the leaf springs sit close to flat at ride height I only have about 4" of up travel in the shocks. Between the shock stops and the traditional bump stops on the front I get a pretty nice, soft, almost floating feeling. It's a great progressive bottom out for the front.
  25. Nov 24, 2019 at 7:04 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
  26. Dec 13, 2019 at 2:08 PM
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Which brand is this and you running 3”?
  27. Dec 13, 2019 at 2:44 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    looks like wheeler's . i run the same ones and i have a 3" lift. i also have a set in the rear.
    14burrito likes this.
  28. Dec 13, 2019 at 8:37 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Yep @Fish2eat88 I have the Wheeler’s Super Bumps. Much better than stock with washers.
  29. Dec 13, 2019 at 10:37 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Have Billy 6112’s set at 1.9”, would
    you recommend these bump stops for this application?
    Flyinryank and 14burrito like this.
  30. Dec 14, 2019 at 12:30 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    They help for all applications including stock setups.
    georgiey22[QUOTED] likes this.
