BULLY DOG OR PEDAL COMMANDER?
Discussion in 'Performance and Tuning' started by so_melo149, Aug 30, 2021.
  1. Aug 30, 2021 at 7:35 AM
    so_melo149
    so_melo149 [OP] New Member
    Los Angeles, CA
    2017 Tundra Crew-Max TRD off-road
    1.75” Rough Country Leveling Kit 275/70/18 GoodYear DuraTrac AT Honey Comb Grill
    just installed the Carven Cat-Back exhaust kit on my ‘17 SR5 TRD Off-Road, and i’m loving the sound. perfect rumble, not too much noise in the cabin and just perfect so i won’t wake the neighbors in the AM. now it just feels like i make more noise than i move. looking for a recommendation... i’m in between the Bully Dog tuner or the Pedal Commander. or does anyone have another suggestion as to how to get more go? thank you beforehand
  2. Aug 30, 2021 at 7:49 AM
    RobertD
    Robert
    DFW, Texas
    2 very different products. What is your actual goal? If you are just wanting a throttle controller (pedal commander) do a search and you will see there are other devices for a lot less that do the same if not more.
    If you are wanting to retune your truck, I've heard good things about Bully Dog as well as D.A.P tuning.
    15whtrd likes this.
  3. Aug 30, 2021 at 7:57 AM
    so_melo149
    Los Angeles, CA
    excuse my ignorance, would you be able to explain the difference in outcome between the bully dog and pedal commander.
  4. Aug 30, 2021 at 8:09 AM
    RobertD
    Robert
    DFW, Texas
    So the pedal commander is just a throttle controller. It only changes your throttle responsiveness. I have a different throttle controller and it makes a significant difference and allows you to tailor the responsiveness of your pedal to your driving style and road conditions.
    The Bully Dog and other tuners actual retune your vehicle and can change shift points and do other things depending your route. Tuners can also actually increase hp while the throttle controller is only changing responsiveness.
    There is also normally a pretty significant difference between the 2. Throttle controllers are around 200-300 while tuning is 500 and up. Just depends what you are wanting for your end result.
    If you search iDrive or HikeIt, there are a few threads about both of those throttle controls. Both are smaller and cost less than the Pedal Commander but are recommended by members on here.
  5. Aug 30, 2021 at 8:26 AM
    so_melo149
    Los Angeles, CA
    yes, of course. makes sense that the tune would change shift points etc. have you personally tried any of these products? the bully dog or the other pedal controls? is the tune more risk as to damage or wear and tear to the truck?
    thanks again
  6. Aug 30, 2021 at 8:44 AM
    RobertD
    Robert
    DFW, Texas
    I have the iDrive and am very happy with it. For me, its doing exactly what I want and was very affordable. I do not believe a reputable company that performs tunes will adversely affect your truck but I cannot say for certain.
    It also depends what you plan to do with your truck. If you are planing a big lift to fit massive tires, a re-gear and tune would be more beneficial than a re-gear and throttle controller. My truck is stock suspension wise an I only plan to do a small lift in the future, so for me the throttle controller fits my needs now and in the future.
    Here's a decent thread on throttle controllers:
    https://www.tundras.com/threads/whos-using-a-throttle-controller-worth-it.87306/
    And here's the thread specific to the iDrive:
    https://www.tundras.com/threads/idrive-throttle-controller-discount-code.87631/
  7. Aug 30, 2021 at 9:01 AM
    so_melo149
    Los Angeles, CA
    i have a 1.75” Rough Country Leveling Kit and 275/70/18 GoodYear DuraTrac AT. as soon as i got the tires in i did feel like i’m not moving as fast and or my throttle response is less. that’s why i’m looking for something to get moving more. any recommendations?
    i’m thinking the tuner sounds good, although i did meet someone who is selling the Pedal Commander for $200
  8. Aug 30, 2021 at 9:07 AM
    RobertD
    Robert
    DFW, Texas
    Is that your end goal for lift? If so, a throttle control should get you back to being responsive. If your planning a 6" lift to run 35's, a tune would be better.
    You can always try that pedal commander and if you don't like the results. You can sell it again and probably make up most of your cost.
  9. Aug 30, 2021 at 9:08 AM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    Use the Tow/Haul button. It's free and helps the truck come back to life after larger tires. I personally don't think a re-gear would worth the cost for those size of tires but that's just my opinion.
  10. Aug 30, 2021 at 9:13 AM
    so_melo149
    Los Angeles, CA
    yes, that’s my end goal for lift
    any other mods would me for looks and or adding some speed. thanks for the help, yea i will try the PC27 and then if i want more i’ll go for the a bully dog. thanks for the help
    RobertD[QUOTED] likes this.
  11. Aug 30, 2021 at 9:13 AM
    so_melo149
    Los Angeles, CA
    thanks
  12. Aug 30, 2021 at 9:19 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    You want more gooo then get a super charger. If not just push tow haul button save your money
  13. Aug 30, 2021 at 9:19 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I've got both running on my truck currently. I first installed the bullydog gt tuner, it is set to performance tune with the sport shift setting. It did make a difference in the overall drive of the truck. It didn't make a huge difference in the acceleration at take off but it definitely firmed up my shift points and you sail all the way through the gears much smoother then stock. Just recently installed the pedal commander and got the acceleration at take off that was missing from the bullydog. Set to max which is sport+ with adjuster set to +4 this truck gets scary fast. I'm not even comfortable hitting the gas when making a turn because I'm afraid the truck will slide the back end out. I've found my perfect setting to be sport mode with adjuster set at zero which is the middle adjustment on each setting. If this sounds confusing PM me and I can shoot you my number and maybe explain it better over the phone. Both devices tuned it my truck feels like a track car and when my DD exhaust comes in, it'll sound like one too.
    saybng and so_melo149[OP] like this.
  14. Aug 30, 2021 at 9:21 AM
    so_melo149
    Los Angeles, CA
    lolololololol
    thanks
  15. Aug 30, 2021 at 9:53 AM
    so_melo149
    Los Angeles, CA
    SWEEEET SET UP
    i will most likely go with that stack.
    i’m picking up the Pedal Commander this weekend, and will get the BullyDog GT a little later, in a couple of months or so...will definitely shoot ya a message. thank you
  16. Aug 30, 2021 at 10:11 AM
    BayRunner
    2017 Tundra Platinum
    I have the Bully Dog BDX, the portable one where you tune it and then leave the tuner at the house. I like it very much and think it makes a big difference in performance. I'm running 295/70R18 ATIII tires and have plenty of get go. Got mine from Keith @dirtydeeds
    so_melo149[OP] likes this.
  17. Aug 30, 2021 at 10:15 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Same here. If you get the bullydog, get it from @dirtydeeds they have great customer service and Keith will recommend the best setup for your use.
  18. Aug 30, 2021 at 12:38 PM
    so_melo149
    Los Angeles, CA
    what’s the difference between the BDX and the GT?
  19. Aug 30, 2021 at 12:45 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    BDX you plug in to tune then disconnect and store until you need it again. The GT works the exact same way but can also function as a monitor to display readings it's getting from the OBD, very similar to a scan gauge. If you look at my picture above you can see the readings it's putting out while driving.
    bulldog93 and so_melo149[OP] like this.
  20. Aug 31, 2021 at 6:06 AM
    so_melo149
    Los Angeles, CA
    :thumbsup: thank you all for the help
  21. Aug 31, 2021 at 5:51 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    I would run both. The Bullydog tubes power. Responsiveness. Transmission. Throttle pedal. But the definition of tuning of gas pedal is very low compared to pedal commander.
    pedal commander has al let endless options for how your gas pedal feels.
    put Bullydog on full kill or ‘premium’ and pedal commander on full kill. Your truck gets gnarly.
    then turn it all back down for your Monday commute.
  22. Aug 31, 2021 at 6:20 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Exactly what I do.
  23. Nov 9, 2021 at 7:15 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    I’m debating running this same setup, already have the pedal commander just trying to see if the bullydog tuner is worth the cost and if anyone has one installed on a 2018
  24. Nov 9, 2021 at 7:19 PM
    I think Bullydog is only compatible up to the 2017 models.
    TucsonTundra1794 likes this.
  25. Nov 9, 2021 at 7:21 PM
    ErikTRDTUNDRA
    Erik
    I have read that as well, not sure what changed between 2017 model and the 2018 or if it just hasn’t been tested for there warranty to support it. I’m sure someone on here has tried one on a 2018 or newer
    Tundra234 likes this.
  26. Nov 9, 2021 at 7:23 PM
    @dirtydeeds, any info on the BD for 2018 and newer?
    ErikTRDTUNDRA[QUOTED] likes this.
  27. Nov 9, 2021 at 7:23 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Why not get the bully dog tune and the bully dog pedal thing? They have a smarter design for their pedal thing than pedal commander does.
  28. Nov 9, 2021 at 7:25 PM
    ErikTRDTUNDRA
    Erik
    I’m waiting for Keith from DD exhaust systems to chime in. Guy is a tundra wizard. I picked up my 10in standard system from him, dude knows his stuff.
    dirtydeeds likes this.
  29. Nov 9, 2021 at 7:25 PM
    ErikTRDTUNDRA
    Erik
    Beat me to it , nice
  30. Nov 9, 2021 at 8:27 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I believe you're talking about the banks one. It's similar but I prefer the pedal commander because I keep it tucked away. The banks is meant to be installed visible and i didn't want another gauge on my truck that I'll never look at.
    Darkness[QUOTED] likes this.
