Bully Dog GT tunes settings
Discussion in 'Performance and Tuning' started by stujaspermma, Mar 25, 2020.
  1. Mar 25, 2020 at 12:37 PM
    stujaspermma
    stujaspermma [OP] New Member
    California
    2011 TRD CRewMax Tundra
    Just bought a Bully Dog GT for my 2011 tundra and mainly wanna use for towing with my 27ft trailer that can weight up to 8500lbs. I Was curious what tune settings you guys run when towing that had the most success??
  2. Mar 25, 2020 at 12:38 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  3. Mar 25, 2020 at 2:36 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I run the premium tune regularly and the towing tune when towing. Play around with them. Once you DL the tunes then it only takes a few minutes to switch them.
    stujaspermma[OP] likes this.
  4. Mar 25, 2020 at 3:28 PM
    stujaspermma
    California
    Right on. Just got it today and hooking it up after work!! excited
    Tundyfundy[QUOTED] likes this.
  5. Mar 25, 2020 at 4:19 PM
    Tundyfundy
    Bay Area, CA
    Nice!! You can store up 2 3 times. I have premium, economy, and towing.
    They have trail and regular tunes as well. Once you have your three it’s pretty easy to toggle them. If you want a tune that’s not part of your three then you have to swap out 1 to fit it on the device.
    I also shut off my seatbelt chimes and speed limiter. I love it because I can monitor my trans temp while I tow as well. Enjoy!
    Don’t forget a beefy battery charger because if it dies during the tune it will brick your truck.
  6. Mar 25, 2020 at 4:25 PM
    stujaspermma
    California
    @Tundyfundy does premium, economy, and towing tunes come pre loaded on the tuner?
  7. Mar 25, 2020 at 4:31 PM
    Tundyfundy
    Bay Area, CA
    No you generally have to down load them first.
    Download the bully dog download program off their site and then follow the prompts. Put the micro SD in the usb and put it in the computer and DL to it. Then put back in your tuner and tune your truck.
  8. Mar 26, 2020 at 5:10 AM
    Tundyfundy
    Bay Area, CA
    How’s it go?
  9. Mar 31, 2020 at 8:22 AM
    stujaspermma
    California
    @Tundyfundy went well temp wired it to test then hard wired for final install. Love it though....but besides a tune of running all on premium with premium fuel, how do you run your tune set ups when towing and also regular driver(not stock)??? interested to hear, 1st time with a tuner so this is learning process hahah
  10. Mar 31, 2020 at 10:33 AM
    Tundyfundy
    Bay Area, CA
    Nice! I run premium always if it’s an option. I also keep transmission shifting stock so non-performance shifts. If I want to change the shift points I can hit “beast mode/tow haul”. You can also toggle your seat belt chimes, speed limiter, lighting and set alarms go temp ranges of various components!
  11. Apr 1, 2020 at 8:14 AM
    stujaspermma
    California
    @Tundyfundy how do u do the seat belt chimes ?
  12. Apr 1, 2020 at 11:28 AM
    Tundyfundy
    Bay Area, CA
    It’s under driver settings I think.
  13. May 25, 2020 at 4:55 PM
    Mnorris1206
    08 tundra
    You guys have any issues with the gt tuner ? I have one on the way. Also how is the tow tune do you find the truck staying in gear more or anything noticeable good or bad ?
    Tundyfundy likes this.
  14. May 25, 2020 at 9:38 PM
    Tundyfundy
    Bay Area, CA
    Tow tune increases torque over premium tune. Shift points can be altered and also left the same but you can choose when you set the tune. I have zero regrets on my bullydog gt
    Mnorris1206[QUOTED] likes this.
  15. May 25, 2020 at 9:38 PM
    Tundyfundy
    Bay Area, CA
  16. May 26, 2020 at 8:55 AM
    Mnorris1206
    08 tundra
  17. May 26, 2020 at 9:02 AM
    Mnorris1206
    08 tundra
    Are you running 93 for towing as well ? I figured I will just switch to 93 and stay with it won't hurt.
  18. May 26, 2020 at 9:44 AM
    Tundyfundy
    Bay Area, CA
    I’ve run both but use the 93 most. I’ve towed with it and the difference is minimal between the two. I agree it won’t hurt.
  19. May 26, 2020 at 2:24 PM
    Tundra_power
    Tundra_power New Member
    Nick
    Yes run 93 octane for tow and premium tune. The computer will adapt better, less ping/knock, more torque better mpg with 93.
  20. May 26, 2020 at 2:59 PM
    Mnorris1206
    08 tundra
    I do have one question what if I'm traveling somewhere that is out or doesn't have 93 octane would it be ok to get lower octane like a 1/4 tank then fill up with 93 when i find it ?
  21. May 26, 2020 at 3:50 PM
    Tundra_power
    Nick
    Yea that fine i see no issue their. You can even use 91 octane but if you have 93 available definitely get 93. I sometimes carry octane booster on long trips just in case..
  22. May 26, 2020 at 4:38 PM
    Tundyfundy
    Bay Area, CA
    91 is fine. I’m in Cali and can’t ever find 93. I verified this with bullydog. I thought it was actually called the “premium” tune. Not 93 tune.
    Tundra_power and Mnorris1206 like this.
  23. May 26, 2020 at 4:59 PM
    Mnorris1206
    08 tundra
    Got ya i am very new to this tuning thing. I have just heard that you should run high octane fuel after a tune is done. Not to say exactly what one im sure over 90 is good. Not to mention alot of guys around hear do full custom tunes as well. They definitely use 93 but I'm just learning. Thanks guys for the info.
  24. Jun 2, 2020 at 5:01 AM
    Mnorris1206
    08 tundra
    I got that info thanks! So the bully dog needs info from multiple truck before I get tunes from the web site ? This is a prosses it seems kinda crazy.
  25. Jun 2, 2020 at 9:21 AM
    Tundyfundy
    Bay Area, CA
    No it just needs to read what truck you have. It’s made for all different models so it needs to read what model you have. It’s actually very easy.
  26. Jun 2, 2020 at 9:32 AM
    Tundyfundy
    Bay Area, CA
    @Mnorris1206 if the person who sold you the tuner didn’t un-tune their truck the bullydog won’t work on your truck.
    Unless you pay to have it unlocked.
    Mnorris1206 likes this.
  27. Jun 2, 2020 at 9:56 AM
    Mnorris1206
    08 tundra
    Yep I check on all that it's not vin locked! I actually went in amd set the truck yr and make already into the tuner and under the setting it says its not registered
  28. Jun 2, 2020 at 10:06 AM
    Tundyfundy
    Bay Area, CA
    Awesome! You are getting there
  29. Jun 2, 2020 at 10:10 AM
    Mnorris1206
    08 tundra
    I'm just working all the time and the only computer I have to use is my wife's and she isn't comfortable with me using it because its for work. Smh so I'm going to have to go to a friend's home to do this lol
  30. Jun 13, 2020 at 2:47 PM
    bigheadjack
    bigheadjack New Member
    2016 DC SR5 5.7 FFV 4x4
    Bilstein 5100s BAMuffler Standard 10” BD Platinum GT AFE Pro Dry S Method 705 18" Toyo AT3 LT295/70R18
    alright, i'm feeling like a dummy. tried to run the update agent on a new BD platinum. the device told me that it was an old incompatible tune (code #011). FAQ on the website told me to delete all of the files except GTGIDF.GTG and run the update agent again. I did that, and now the device won't even read the SD card. I'm sure I've done something wrong here, but it's pretty frustrating.
