Bully Dog BDX
Discussion in 'Performance and Tuning' started by BayRunner, Mar 8, 2018.
  1. Apr 24, 2021 at 5:35 PM
    #61
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Reviving an old thread. Installed my Bullydog BDX I bought from @dirtydeeds this week. Updates took an hour or two but the install was just a few minutes. I am very happy with the tuner so far? Shift points and throttle response are much better. Almost like tow haul but controlled and not jerky. Feels great to get some zing back after putting on the cap and heavy ass tires!
  2. May 2, 2021 at 10:45 AM
    #62
    Aboltz
    Aboltz NFT/FCT
    2017 Crewmax 5.7L Limited 4x4
    I can’t even get mine to work
    Guess it’s a paper weight for now
  3. May 2, 2021 at 11:35 AM
    #63
    BayRunner
    BayRunner [OP] I’m here, except when I’m not
    2017 Tundra Platinum
    I would suggest performing an update on the unit itself via WiFi. I have a ‘17 and it works perfectly every time. When I initially got it I remember doing an update first
    15whtrd likes this.
  4. May 2, 2021 at 11:54 AM
    #64
    Aboltz
    Aboltz NFT/FCT
    I did all the updates via WiFi and using device updater. I’m on file version 1.093BDXST what are you currently running? Maybe I need downgrade the file version for it to work......
  5. May 2, 2021 at 12:01 PM
    #65
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Did you call bullydog support? I had them on the phone when I did mine and even though it went perfectly it was reassuring to have them there.
    Jeff_1974 likes this.
  6. May 2, 2021 at 12:07 PM
    #66
    Aboltz
    Aboltz NFT/FCT
    They are closed Sundays
    Monday - Friday 7Am - 4Pm
    I will try first thing in the morning, worst case I’ll just sell it and find something else.
  7. May 2, 2021 at 12:14 PM
    #67
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I purchased the bullydog GT and it essentially does the same thing but doubles as a monitor for different readings. If you can't get it to work but still want the tune try this one out.
  8. May 2, 2021 at 12:16 PM
    #68
    Aboltz
    Aboltz NFT/FCT
    awesome, thank you!
  9. May 3, 2021 at 7:55 AM
    #69
    Aboltz
    Aboltz NFT/FCT
    (Update) Was on the phone with SCT for 2 hrs till I had to go to work. Had team viewer running and was doing a lot of firmware stuff. No fix yet, he said he will call back in the morning.
    TucsonTundra1794 likes this.
  10. May 3, 2021 at 7:57 AM
    #70
    TucsonTundra1794
    Anthony
    Tucson, AZ
    And your truck isn't operable until it's fixed right?
  11. May 3, 2021 at 9:00 AM
    #71
    Aboltz
    Aboltz NFT/FCT
    It won’t even connect to the truck, that’s the whole problem lol
  12. Jul 9, 2021 at 4:37 AM
    #72
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Did you ever get the Bullydog to connect? This is where I'm at with mine. Gets to the check voltage part in the up load and shows 11.4. Even though the screen shows 13 plus while running and 12.4 while in the on position not running. Still waiting to hear back from Bullydog.
  13. Jul 9, 2021 at 6:16 AM
    #73
    Aboltz
    Aboltz NFT/FCT
    Last time I called was a month ago…. Seems to be on the back burner
    I’m still in the same situation…. They pretty much told me it’s on the back burner until more people have the same issue. Can’t believe out of all these tundras in the world people are not doing the ECU update…… For me after the update my MPG went from 16.8 to 18.5 on long trips.
  14. Jan 23, 2022 at 1:25 PM
    #74
    Miller29
    Miller29 New Member
    Wesley
    White 2014 limited crew TRD off road Tundra
    3" to 2" Leveling kit and small cosmetic mods. But want to do more. This is my first Tundra, actually my first full size truck. Love the power lol.
    Don't you have to be using premium gas to use the premium Tune? Or what would happen if you you use regular 87 gas , and use the premium option tune?
  15. Jan 23, 2022 at 3:56 PM
    #75
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Yes you need premium gas for the premium tune. If using regular gas you select the regular time, with performance shifting and throttle response.
  16. Feb 25, 2022 at 6:25 AM
    #76
    ronrich
    ronrich New Member
    I'm curious about this statement, "They (the truck) will adapt to your driving style over time". What exactly does this mean in terms of the ECM and how the stock truck drives and responses to gas pedal input? If you drive around conservatively (don't get into much i.e jack rabbit starts, etc.) or worst yet you drive around like a "granny", does that effect it's performance over time? How can this be corrected, do you have to unplug the battery so the truck has to re-learn? Or is all this just immaterial?
    Miller29 likes this.
  17. May 14, 2022 at 7:40 AM
    #77
    jh3spyder3
    jh3spyder3 New Member
    Christine
    08 Tundra 5.7 Trd
    I have a 2008 Toyota Tundra 5.7, It’s my daily driver and I tow my campers every weekend. I Use regular gas. What program should I be running? I currently have it installed with Regular/Performance/Performance. But should I run Tow/Perf/Perf?
