Bully dog 40415 install
Discussion in 'Performance and Tuning' started by MakMurph, Jun 29, 2017.
  1. Jun 29, 2017 at 7:46 PM
    MakMurph
    MakMurph [OP] I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    so after hours on the computer finally called them and they emailed me instructions to install on a 16 tundra non flex I've been in my truck waiting and it's been trying "determining vehicle type" for 10 minutes now says not to unplug anyone know how long this is supposed to take? Thanks
  2. Jun 29, 2017 at 7:50 PM
  3. Jun 29, 2017 at 8:03 PM
    MakMurph
    Well waited a half an hour nothing changed switched it off and started the truck it started have to call them tomorrow hopefully the truck will drive so I can go to work hope I didn't f%#k it up
  4. Jun 29, 2017 at 11:28 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Did you have a charger on your truck?
  5. Jun 30, 2017 at 12:34 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    It should not take that long, a minute or two at most. As long you didn't past the screen with the yellow (I believe) background. It will tell you not to cycle the key unless you are told to. If your truck started and nothing is flashing on the dash you should be fine.
  6. Jun 30, 2017 at 5:34 AM
    MakMurph
    No charger on the truck last night started it at 10:30 waited til 11 nothing on the screened changed so I turned it off a little after 11 thanks for the replies
  7. Jun 30, 2017 at 6:37 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    I meant while you were trying to install. It sucks a lot of juice doing the install and if your charging system drops below 11.8 V ( I think that's what it was ) it won't take the tune. They say to shut off all electronics radio's, lights, pull phone chargers, turn off heat/a.c. etc... Then hook a battery charger to your truck while you are doing the install so there's no way you'll drop low on volts. If you already did this sorry. I'll shut up
  8. Jun 30, 2017 at 8:15 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Always have Bullydog on the phone with you when doing the install. Just in case....
  9. Jun 30, 2017 at 8:32 AM
    MakMurph
    Just talked to them apparently the 40415 won't support toyota I need a 40417 damn thanks for the help guess I gotta sell this one and save up some coin for a newer model
