Bulletproof 6-8 Inch Lift
Discussion in 'Suspension' started by TruckyTruck, Nov 19, 2014.
  1. Nov 19, 2014 at 11:01 PM
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    Have you guys seen this new lift from bulletproof? Their site says completely bolt on, no welding... So unless I'm completely wrong about this, no cutting the crossmember. If you have a 4x4 and want a 6 inch lift, wouldn't this be the way to go? It just seems really ridiculous that if this is right, the only solution other companies could come up with was to cut the frame of your truck...! Although... This lift isn't cheap.
    http://bulletproofsuspension.net/browse-by-brand/toyota/toyota-tundra-6-8-lift-kit
  2. Nov 19, 2014 at 11:02 PM
    TruckyTruck
    Gary
    I think I might email them to make sure you don't have to cut the crossmember.
  3. Nov 20, 2014 at 3:25 AM
    ODSteve
    ODSteve New Member
    Steven
    2012 Thundra SR5 TRD CrewMax
    K&N Filter, Low Profile tool box.
    Oh wow!
  4. Nov 20, 2014 at 7:37 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    From what i see they build this "one piece cage" where the cross bars are low to avoid cutting the crossmember. You loose clearance from the others.
  5. Nov 20, 2014 at 7:43 AM
    ODSteve
    ODSteve New Member
    Steven
    Oh well that makes sense!
  6. Nov 21, 2014 at 12:00 PM
    Clint
    Clint New Member
    2010 Tundra 4wd 5.7L
    N-fab steps
    Bookmarked this for when I get my beast paid off next year. I've been looking for a good 6inch lift that didn't require cutting my truck up.
