Bulb Replacement & Truck DNA
Discussion in 'Lighting' started by Mootball, May 9, 2018.
  1. May 9, 2018 at 10:39 AM
    Mootball
    Mootball [OP] New Member
    ‘16 TRD Crew Max
    None yet but plenty to come.
    So all videos I have seen thus far to replace the bulbs on 3rd Gen models I need to remove the grille and the panel below the headlight. Is this 100% the case?
    I ask cause my Silverado I had some vendors told us to remove the bumper corners and I was able to do w/o that.
    Any luck?
    Also i just got the truck ('16 used) and there is a box in the glove box called Truck DNA....what is this?
  2. May 9, 2018 at 1:15 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    @Mootball if you’re going to replace the headlight bulbs you def have to remove the grille. Ask me how I know. If you’re just doing the turn signals and you have smaller hands you can probably change those out w/o removing the grille.
    I don’t know what DNA is. Sorry
  3. May 9, 2018 at 5:26 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    You can get at it via the mud liner, but it's a giant PIA compared to taking the grill off.
    NewImprovedRon likes this.
  4. May 9, 2018 at 5:30 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Taking off the grill is not as scary or difficult as it seems. The bulbs are a very easy job. Use ole Gunny Google and YouTube and it will put your mind at ease. :thumbsup::thumbsup:
    040Tundra likes this.
  5. May 9, 2018 at 5:33 PM
    Pic of this box in glove box u speak of
  6. May 9, 2018 at 5:55 PM
    Yeah jts not that hard to pull grille off to replace HL bulb or any bulb in the HL housing, the grille is 4 bolts and 2 plastic push align pins take out a simple pull up from top the slight up in out tug from grille then the two plastic pieces below HL ther are 2 plastic align push pins pull those covers from the align pins towards you and pull back 3 bolts holding HL housing (someone correct me if I'm wrong)
  7. May 10, 2018 at 7:46 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Close enough! It’s not hard at all. I’d recommend getting a few extra push clips in case you break a few.
