Building custom rear seat delete
Discussion in '2.5 Gen Tundras (2014-2021)' started by devdomski, Apr 8, 2020.
  1. Apr 11, 2020 at 12:54 PM
    devdomski
    devdomski [OP] New Member
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Haha I turn it down when they are in the truck so I don’t hurt their precious ears.
  2. Apr 11, 2020 at 12:55 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Good call :) nice work, looks great.
    devdomski[QUOTED][OP] likes this.
  3. Apr 16, 2020 at 7:38 AM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Updated
    jewsNbrews likes this.
  4. Apr 16, 2020 at 9:01 AM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    Nice updates, it turned out pretty well
    devdomski[OP] likes this.
  5. Jun 2, 2020 at 7:57 PM
    denali302
    denali302 Meh...
    Michael
    2017 Crew Max
    @devdomski did you have a smaller bolt coming up from the bottom? I have the larger bolts holding the seats down, but there appears to be a smaller bolt threaded up from the bottom.
  6. Jun 2, 2020 at 8:20 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Should just be 8 bolts total for the seats. Two each section. 7 bolts similar and on special threaded.
  7. Jun 2, 2020 at 8:29 PM
    denali302
    denali302 Meh...
    Michael
    2017 Crew Max
    Yeah - the 8 bolts yes. But there is also a smaller bolt coming up from the bottom... exposed threads
  8. Jun 3, 2020 at 3:21 AM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    I only used the four rear bolts. The material used is mdf and its heavy so the weight of the completed project holds it in place well. Using the four forward bolts would have been overkill. I don’t see what you’re talking about with the bolt from the bottom. If you could point out what you’re looking at, I can explain.
  9. Jun 3, 2020 at 5:12 AM
    denali302
    denali302 Meh...
    Michael
    2017 Crew Max
    @devdomski at time of removal.. did this come out?
  10. Jun 3, 2020 at 5:15 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Did similar thing in my 07 DC when I had it.
    I used it to slide the huge black bins with yellow lids from Home Depot and I could get like 10 of the large ones stacked easily in there or a combination of other sizes of them to keep tools inside instead of in the bed.
    Ended up getting rid of the truck and getting a RCLB anyway.
    devdomski[OP] and jewsNbrews like this.
  11. Jun 3, 2020 at 6:49 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    8 bolts. Lift and remove. That thing is nothing. It does nothing to hold the seat in. 15911920760343247334041770543051.jpg 15911921400136448076216287756287.jpg
  12. Jun 3, 2020 at 6:51 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Did the same so it was level for my dogs. 20200509_183943.jpg 20200510_105435.jpg
  13. Jun 3, 2020 at 7:12 AM
    denali302
    denali302 Meh...
    Michael
    2017 Crew Max
    Awesome. Thank you
  14. Jun 3, 2020 at 7:30 AM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Ah ok. Yes, like was said, this is part of the mount and comes out with the seat.
    denali302[QUOTED] likes this.
  15. Jan 17, 2021 at 4:52 AM
    Fortinberry7577
    Fortinberry7577 New Member
    What fasteners did you use to allow you to take it apart and paint them reassemble?
    awesome project!
  16. Feb 26, 2021 at 6:38 AM
    Tindraoverlander
    Tindraoverlander New Member
    How much weight do you recover from removing the rear seats in a 3rd gen DC? I'm thinking of doing this for a variety of reasons
  17. Feb 26, 2021 at 7:13 AM
    Elduder
    Elduder New Member
    I pulled mine out at one point, on the DC is probably 40-50lbs. Not a lot.
  18. Jan 9, 2022 at 10:07 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Anyone do a 40 only delete?
  19. Jan 9, 2022 at 10:37 AM
    #49
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I mad mine so it could be 40,60,100 deleted depending on needs.
    wexttxco[QUOTED] likes this.
  20. Feb 22, 2024 at 11:04 AM
    #50
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    Looks great! What type of wood did you use and how thick was it?
