Build: Takes a lot of money to look this cheap.
Discussion in '2.5 Gen Tundras (2014-2021)' started by MSU Tundra, Jul 27, 2022.
  1. Sep 16, 2022 at 9:56 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Sounds stock still. I cut mine at the exact same spot.
    MSU Tundra[OP] and mav7021234 like this.
  2. Sep 27, 2022 at 7:54 AM
    MSU Tundra
    MSU Tundra [OP] Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    Yeah it’s almost quieter (but lower sound) than stock.
  3. Sep 27, 2022 at 8:35 AM
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    Looks incredible, @MSU Tundra! And, on behalf of all of us who care about our fronts and windshields… THANK YOU FOR THE MUD FLAPS AND NOT BUILDING A ROCK CHUCKER!
    SAGE63 and LS3 like this.
  4. Sep 29, 2022 at 11:47 AM
    MSU Tundra
    Mississippi
    Thanks man!
    I ride on gravel way too much to forgo the mud flaps.
    LS3 likes this.
  5. Sep 29, 2022 at 11:55 AM
    tweetlessfeags
    tweetlessfeags New Member
    2016 Platinum Tundra
    OME Nitrocharger Dakar Leaf pack+Add a leaf RCI Engine/transmission/differential/gas skid Bash Fabrication Weld-On Sliders Method 703-17" 0 offset ARB Dual compressor Victory 4x4 Engine bay compressor mount Cooper STT PRO 315/70/r17 Decked Drawers Cali Raised Led Ditch Lights WeBoost Reach OTR w/ Rhino Rack Aerial Mount Piaa SuperWhite Headlight bulbs Meso Customs Interior Light Kit Dometic CFX3 55IM Dobinsons Snorkel SnorkelUpgrade Precleaner GFC V1 AluCab Shadow Awn All the Tint
    Platinum Gang!!! Awesome build sir!windrock flex_LI.jpg A0092F5A-FFDA-4D61-9F52-A849D9A46AA1.jpg
  6. Oct 7, 2022 at 12:03 AM
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    There’s no lift on that thing? It looks higher.
  7. Oct 7, 2022 at 4:57 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    Great build sir!
    You obviously know how to build out rigs and have a lot of experience modifying Toyotas.
    IF I may give one suggestion, you can push your front fender liner forward and reattach. It will give you about 1" to 1/2" more clearance and still super
    clean. (if you even need too)
    Cheers.
    O.S.T.
  8. Oct 8, 2022 at 9:11 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Sounds slightly the same. But looks much better.
  9. Oct 8, 2022 at 9:41 AM
    Parksareforever
    Parksareforever New Member
    2020 TRD DC 4x4
    I love how clean and simple it looks with the black steelies.
    MSU Tundra[OP] and AggiePhil like this.
  10. Oct 8, 2022 at 10:06 AM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    Awesome build, really like the steel wheels. Have you installed the add a leaf yet?
    Parksareforever likes this.
  11. Oct 8, 2022 at 3:37 PM
    Redline870
    Ian
    Central NY
    Guess I should have read a little further… After seeing the “pile of carnage” photo with the struts, shocks, leads, and UCA’s, it clearly was lifted. Which lift kit did you use? I didn’t see it specified in the original post.
  12. Oct 20, 2022 at 11:58 AM
    MSU Tundra
    Mississippi
    Thanks man!
    Yeah I haven’t had any rubbing under any circumstance with the bumper spaced out.
  13. Oct 20, 2022 at 12:20 PM
    MSU Tundra
    Mississippi
    Thank you sir..
    I actually did add the extra leafs a couple weeks ago. After going on a hunting trip where I pulled 2 four wheelers on a 14’ trailer, the rear end sagged ever so slightly. So before going on a hurricane relief effort trip to South Florida where I had to pull a 16’ enclosed trailer full of equipment, I decided to throw those extra leafs in, and I’m glad I did. I had my whole crew’s luggage and gear under the shell and towing roughly 5k lbs with the trailer. It sat perfectly level and rode like a dream. I averaged about 11mpg usually going a little over the speed limit keeping pace with traffic.
    I’ll try to post some photos with no trailer, but here’s a shot with. Without the trailer it sits about 2” higher in the rear (measuring ground to fender). Before it was 1” higher, but was exactly level when measuring the bedrail flatness.
    Here’s where the extra leaf went…
    5C8C1D65-5731-4844-879D-96EF878780EF.jpg 16EA7E7B-003F-4C61-9EE9-2F478FAFEB62.jpg
    bulldog93, CaptRussia253, DZ_ and 3 others like this.
  14. Oct 20, 2022 at 12:24 PM
    MSU Tundra
    Mississippi
    I posted in the op, but I guess it was buried in the wall of text…
    Dobinsons Twin Tube kit with HD leaf pack.
  15. Oct 20, 2022 at 12:41 PM
    COTundra23
    COTundra23 New Member
    Stance is looking good! I am interested in seeing some pics without the trailer hooked up
    MSU Tundra[OP] likes this.
  16. Oct 20, 2022 at 2:24 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I am considering a similar setup. What would you estimate your standard cargo weight to be? Would you mind posting your front and rear wheel center to fender dimensions?
  17. Oct 20, 2022 at 5:46 PM
    MSU Tundra
    Mississippi
    Here you go. Top without extra leaf, bottom with.
  18. Oct 20, 2022 at 5:56 PM
    MSU Tundra
    Mississippi
    Probably around 500lbs
    Front = 24”
    Rear = 25.75”
    DZ_[QUOTED] likes this.
  19. Oct 20, 2022 at 6:24 PM
    #49
    biebs96
    PA
    ever consider cutting the tabs off? It does not look like the tire is against the frame firmly.
  20. Oct 20, 2022 at 6:26 PM
    #50
    MSU Tundra
    Mississippi
    Didn’t need to. Can’t tell in the photos but the sidewall is touching up top so it’s nice and snug.
    biebs96[QUOTED] likes this.
  21. Oct 20, 2022 at 6:27 PM
    #51
    biebs96
    PA
    Just looking out. Those tabs are sharp and do not want to see them pierce a sidewall.
  22. Oct 20, 2022 at 6:39 PM
    #52
    MSU Tundra
    Mississippi
    I appreciate it. I’ll keep an eye on it.
  23. Oct 21, 2022 at 8:00 AM
    #53
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I've added a charging controller into Leer's fuse box and a small lead-acid battery, mounted on a DIY steel cage, with an extra diode preventing battery discharge to the main line when the lights are off. The battery charges when the lights are on, the camper light is powered either from the main line, when it has something, or from the battery.
    The battery can be Li-Po as well, but lead-acid holds the heat and frost better, and does not burst in flames when overheated or damaged.
    LS3, Yzed608 and GSil like this.
  24. Oct 21, 2022 at 12:29 PM
    #54
    MSU Tundra
    Mississippi
    Great idea! I may copy it.
    COTundra23 likes this.
  25. Oct 21, 2022 at 6:38 PM
    #55
    jwicks82
    jwicks82 New Member
    2017 Toyota Tundra
    looks dooooope. where did you pick up the TRD Pro Grille
  26. Oct 22, 2022 at 10:34 AM
    #56
    Ceezurin
    Ceezurin New Member
    Franco
    El Paso, Texas
    2019 Cavalry Blue Limited Crewmax
    Bilstien 5100 all 4 corners, Toytec shackles, mbrp full exhaust single exit, husky liners, diode dynamics interior and exterior lighting
    Are the steel wheels difficult to balance? I hear conflicting things about them but it’s always from people that don’t even have them haha anyways they look badass
  27. Oct 22, 2022 at 7:30 PM
    #57
    MSU Tundra
    Mississippi
    Thanks man. I got it from a dealership in Alabama when they were running the big online sale earlier this year.
    jwicks82[QUOTED] likes this.
  28. Oct 22, 2022 at 7:32 PM
    #58
    MSU Tundra
    Mississippi
    Not at all. I’d say maybe even easier since you can clamp on traditional weights instead of the stick ons.
    AggiePhil and Ceezurin[QUOTED] like this.
  29. Oct 23, 2022 at 6:18 PM
    #59
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Neither of those pics show a trailer attached.
  30. Oct 23, 2022 at 7:42 PM
    #60
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    And I thought I was alone noticing that.
    AggiePhil[QUOTED] likes this.
