BSM message after installing tow mirrors.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mr.lee, Jan 6, 2021.
  1. Jan 6, 2021 at 12:21 PM
    Mr.lee
    Mr.lee [OP] New Member
    2020 TRD Sport
    Just installed Boost auto GM style mirrors (driver side) with BSM option on my 2020 tundra but getting messages on the dash. Have not installed passenger side yet because of the error.
    BSM Malfunction, contact dearer.
    Has anyone gotten this message after installing tow mirrors or do I just need to drive around more to let it recalibrate?
    Thanks .
  2. Jan 6, 2021 at 12:39 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    BSM sensors are in the rear bumper. Do the new tow mirrors not have BSM indicators?
  3. Jan 6, 2021 at 12:44 PM
    Mr.lee
    2020 TRD Sport
    Yes the mirrors have the BSM indicators.
    I ordered them with BSM and it should be plug and play.
    Trying to contact Boost auto now.
    Thanks.
  4. Jan 6, 2021 at 2:18 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I had to swap two pins around for mine to work. Can't remember the pin numbers, but they were the pins closest to the front of the truck, had to swap the top and bottom pins around it works now. I chased this for awhile and read many threads before finding this info. Hope this helps!
  5. Mar 4, 2021 at 1:30 AM
    Td44
    Td44 New Member
    I just bought the ebay GM style mirrors and have the exact same problem. They do have BS indicators and are supposed to be plug and play too. Were you able to find a fix for it OP? Or could @Sumo91 elaborate more and which pin did you have to switch around? I try to switch the 1 pin that just to 1 side by itself to the lower position but that doesn't help. Thanks in advance.
  6. Mar 4, 2021 at 8:03 AM
    Mr.lee
    2020 TRD Sport
    TD44,
    Boots auto walked me through removing the mirrors/cover and we found a wire that was disconnected.
    After connecting the wire everything worked as plug and play.
    https://youtu.be/8iEwSH3E3Fk
  7. Mar 4, 2021 at 8:08 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Can you post pics and link and maybe your opinion on these? Been looking into some tow mirrors. Thanks in advance.
  8. Mar 4, 2021 at 8:22 AM
    Mr.lee
    2020 TRD Sport
    clarkritchie and tinman10101 like this.
  9. Mar 6, 2021 at 10:03 AM
    clarkritchie
    clarkritchie New Member
    Nice, glad you got that sorted. I have been hesitant to order these since I definitely do not want to lose either the BSM or the heat functionality.
    Question -- how much width do these add when in the compact/regular position? I am seeing about 13-3/4" on the OEM mirrors eyeballing it from the weather stripping to the very furthest edge of the mirror, e.g.
