BSM and OEM Tow Mirror Mod
Discussion in '2.5 Gen Tundras (2014-2021)' started by dumbassdave, Jan 30, 2019.
  1. May 20, 2019 at 7:30 AM
    gbatpdx
    gbatpdx New Member
    2018 Tundra Limited
    Yes, that could be it. Just ordered 5mm 12v leds from Amazon, here tomorrow.
  2. May 20, 2019 at 7:56 AM
    dumbassdave
    dumbassdave [OP] Member
    Dave
    2016 Crewmax Limited
    You must have a button for it....
  3. May 20, 2019 at 7:59 AM
    gbatpdx
    gbatpdx New Member
    2018 Tundra Limited
    Don’t think so. There’s one on the steering wheel for lane departure alert, but not for BSM.
  4. May 20, 2019 at 8:03 AM
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    Nice, those should work well, just make sure they don't have built-in resistors. If they do, you'll have to cut them out. I actually used 3mm and they are a little small, might change them out for 5mm at some point. Link below shows a pic of the 3mm LEDs installed.
    https://www.tundras.com/threads/power-folding-mirrors.22077/#post-591754
  5. May 20, 2019 at 8:06 AM
    JoeJob
    Joe
    New England
    You can only turn the BSM/RCTA on or off, you can't trigger it. However, you can trigger the RCTA alert by putting the truck in reverse and having someone walk behind it.
  6. May 20, 2019 at 8:21 AM
    dumbassdave
    Dave
    My bsm switch is in the switchbank to the left of steering wheel
    Tundra805 likes this.
  7. May 25, 2019 at 7:44 AM
    mac10tuna
    mac10tuna New Member
    Marc
    19 cement limited CM
    It’s in your dash settings.
    Far right icon.
    You control it from the steering wheel buttons.
  8. Nov 24, 2019 at 11:41 AM
    BillDig
    BillDig New Member
    2016 Tundra DC TRD Bronze
    So all you folks who installed these mirrors, was there an initial BSM error warning that needed to be reset or something? I did a test install of one of the mirrors on my 2016 SR5-TRD and got an error saying "BSM failure, contact dealer" or something like that. I could make it go away by shutting off the BSM on the dash switch, but i would prefer to have that functional, especially because the Trail Ridge tow mirrors have that capability. Any ideas on how to remedy that BSM error before I decide whether to complete the install?
    Also, i bought a replacement mirror control switch with the power fold button but my harness didn't have those wires. So i assume i need to get a replacement pigtail to wire up and enable that function. Right?
  9. Nov 25, 2019 at 11:37 AM
    JoeJob
    Joe
    New England
    The OEM Tow mirrors do not have BSM, so if you install them without installing a new LED, the BSM system will fail. This thread goes over installing new LEDs in the sail panels to take the place of the missing BSM LED once you install the tow mirrors.
    I don't believe the OEM tow mirrors are power-fold either, but if they are, then yes - you need to install new wires for that feature. There should be two slots in the harness, you just have to install the pins and then run two wires to both mirrors.
  10. Nov 26, 2019 at 8:29 AM
    BillDig
    BillDig New Member
    My original mirrors did have BSM, but I get what you are saying. The aftermarket Trail Ridge mirrors have a different resistance and the system senses that as an error. Or is that led addition because people don’t have BSM lights in the mirror. I better go back and read all these threads carefully.
    The trail ridge mirrors have so many damn Lights (turn signals, running lights, read facing lights, puddle lights) I sure didn’t think I needed any more! Ok stay tuned. (It snowed a foot last night so I won’t be working on this again for a week.). Thanks all.
  11. Nov 26, 2019 at 11:20 AM
    JoeJob
    Joe
    New England
    Ah yes, it's definitely going to be the resistance values. My power-fold mirrors came off a 2012 Limited and don't have BSM, so I had to install LEDs in the sail panels. Originally I installed resistors and that gave me the same errors you're seeing. I removed them and it's been working fine. Good luck.
  12. Dec 18, 2019 at 3:42 PM
    Meltz
    Meltz New Member
    Hello all. I just installed some tow mirrors I got off ebay. Everything appears to work, even a blinker located on the inside of the mirror however there's outside LEDs that are supposed to run the blinkers and the running lights and they do not light up off the factory harness. Any ideas how to fix this? I thought they would work since all the other features on the mirror works including the blinker on the inside of the mirror.
  13. Dec 22, 2019 at 6:26 AM
    biebs96
    PA
    Do we know if it is possible to simply connect the two wires without adding an led light to complete the circuit and allow the system to function just without a functioning interior light?
  14. Dec 22, 2019 at 12:06 PM
    dumbassdave
    Dave
    I'd think that you'd be better off with looking up the resistance in an equivalent LED light and installing a resistor. If the computer doesn't like seeing no light there, maybe it gets cranky with a short instead?
  15. Dec 22, 2019 at 1:56 PM
    biebs96
    PA
    Actually tried it today... made no difference. Guess I’ll be ordering some of those LEDs.
    @dumbassdave Do you have a link for the ones you ordered. I tried the one posted earlier but it doesn’t seem to be working for me.
    Thanks!
  16. Dec 22, 2019 at 2:07 PM
    dumbassdave
    Dave
  17. Dec 28, 2019 at 5:40 PM
    biebs96
    PA
    And DONE!!! Works perfect!! I used these LEDs...
    https://www.ebay.com/ulk/itm/161910928088
    They say there is a resistor in-line but upon testing it there are no error messages and during a test ride vehicles approaching from the rear set off either corresponding led in the sail panel.
  18. Dec 28, 2019 at 6:35 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    can you please explain what you did here
  19. Dec 29, 2019 at 7:39 AM
    #49
    dumbassdave
    Dave
    When I replaced my stock mirrors with tow mirrors, there was no LED for the BSM system. I installed LEDs in the sail panels so that I still get a notification.
  20. Dec 29, 2019 at 11:01 PM
    #50
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    if i just didnt want the feature could i cut a wire? which wire? do u know?
  21. Dec 30, 2019 at 6:55 AM
    #51
    dumbassdave
    Dave
    If you don't want BSM you can turn it off. My 2016 has a switch. Newer ones it's in the menu by the speedometer.
  22. Dec 30, 2019 at 10:24 PM
    #52
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    i have a 2012 that doesnt have it at all (dont think it was around back then?) so i really dont think i have the switch because i dont have the option. i thought i read a review somewhere that when u plug n play - the BSM light stays lit constantly...
  23. Dec 30, 2019 at 10:27 PM
    #53
    dumbassdave
    Dave
    Ah, ok. Sorry, I haven't heard anything about that.
  24. Dec 31, 2019 at 11:13 PM
    #54
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    so yours work as advertised?
  25. Jan 1, 2020 at 8:07 AM
    #55
    dumbassdave
    Dave
    Yup. Tow mirrors with LEDS in the sail panels work just the same as non tow mirrors with LEDS built in the mirror. Rear cross traffic works just the same too.
    biebs96 likes this.
  26. Feb 5, 2020 at 7:28 PM
    #56
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    How much clearance is there in the sail panel? I’m wondering if something like this would work.
    https://www.waytekwire.com/item/47641/Snap-In-Panel-Indicator-Light-47641-/
    I prefer a larger LED than just 3 or 5mm.
  27. Feb 5, 2020 at 8:20 PM
    #57
    dumbassdave
    Dave
  28. Feb 8, 2020 at 5:20 PM
    #58
    chrisbusnut
    Pasadena, CA
    Are the LEDs you got from eBay still working with no issues? I like these because they have a black plastic snap in base and the wire leads on the back, which should make them easier to connect. Any problems with the resistors?
    #58
  29. Feb 8, 2020 at 6:22 PM
    #59
    biebs96
    PA
    They work great still. The built in resistors work with the system perfectly.
    I simply stripped about 1.5” of the wire and wrapped it arounded the de-pinned wires and shrink wrapped it on there.
    #59
  30. Feb 29, 2020 at 7:51 PM
    #60
    chrisbusnut
    Pasadena, CA
    I installed OEM power fold tow mirrors today on my 2020 SR5. I haven't addressed the power fold feature yet (working on that), but spent several hours trying to get the BSM to work. I used T-pins, alligator clips and a variety of different LEDs to test. I was able to get the LEDs to light up most of the time (I had them connected on both driver & passenger side), but almost always got BSM and RCTA error messages in the center screen of my dash.
    A couple of times the LEDs would work when I started the truck, but when I took it for a test drive and another vehicle approached from behind on right or left, the LED would light and then I'd get the error message. Sometimes the LEDs would light but then I'd immediately get the message. Later I used some LEDs that I assume don't have resistors in them, and they worked great until I shut the truck off for a few minutes. When I restarted, with no change in connections, I immediately got the error message and the LEDs would no longer illuminate.
    Following is a diagram that I made of the stock SR5 mirror harness and the connectors on the back of my stock SR5 mirrors (with BSM), and then the new OEM power fold tow mirrors (no BSM). The shaded positions indicate that the mirror connectors have terminals/pins. The white positions mean they are blank (no terminals/pins). I've tried moving the black wire of the LED between positions.
    Below I have the red wire connected at #9 (see above) and the black wire connected at #14. The LED wires are inserted directly into the back of the harness.
    Here's a video of this setup working: https://youtu.be/Go5k746G4uU
    It continued to work until I took it out in traffic. As soon as a vehicle approached from behind and the LED illuminated, I got the error.
    Error screen...
    I also used T-pins with alligator clips for testing.
    For this one, I connected the black wire to #18 (directly below the red wire at #9), and then used an LED that I assume does not have a resistor on it. This one worked from the time I started the truck, driving through traffic with both LEDs lighting up, until I turned the truck off. When I restarted it, I immediately got the BSM/RCTA errors, and the LEDs would not light up at all.
    I'm a bit stumped at this point on what I am doing wrong.
