Brother's 2023 Tundra won't start, dealer clueless (SOLVED)
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Apr 9, 2024.
  1. Apr 10, 2024 at 7:41 AM
    SDHNTR
    SDHNTR [OP] New Member
    And how could you tow it? There's no tow hooks, LOL!
    MTRock and pyoung62[QUOTED] like this.
  2. Apr 10, 2024 at 8:00 AM
    Henfield
    Henfield New Member
    The recharging voltage should run around 14.5 often a little more during the recharging cycle. It shouldn't vary more than say half a volt at any time. As charge level increases, it will drop to 12.5 gradually..... Pickup one of those 12v power outlet USB/Voltmeters off Amazon or similar and monitor. The truck sat on the lot. Weak battery for a bit but he's had it and been using it for a while.
    I wonder about possible rodent damage to the wiring and or a short. Something isn't getting the signal it needs....Dealer doesn't have the ability to track it down.
    Question: Is there any kind of aftermarket or dealer added anti theft system fitted to the car or one of those lender mandated GPS devices? Drop the panels under the steering wheel.
  3. Apr 10, 2024 at 3:44 PM
    SDHNTR
    Well, I paid close attention to my truck's digital voltmeter gauge today and mine does it too. Apparently the fluctuation is normal. With foot on gas it stabilizes lower on the gauge, assume somewhere near 12v. Take your foot off and coast and it jumps up a couple/few volts.
  4. Apr 10, 2024 at 3:45 PM
    SDHNTR
    What should cold, resting battery voltage be after an overnight sit? Specifically asking 3rd gen Tundra owners with non hybrid motors only. I know the answer as it related to other/older vehicles. I'm trying to establish a baseline with people with these exact trucks and oem batteries.
  5. Apr 10, 2024 at 6:52 PM
    xc_tc
    xc_tc New Member
    At idle or with the engine off? When you the truck is started cold, the voltage goes to 14 V and goes down as you drive. The hybrid and non-hybrid have nearly identical characteristic. Battery operates at 12V usually unless charging is needed so the gauge moves up to 14 V when decelerating, braking, etc.
  6. Apr 10, 2024 at 6:54 PM
    SDHNTR
    Engine off. Before starting, after an overnight sit, measured with a multimeter.
  7. Apr 10, 2024 at 7:16 PM
    xc_tc
    xc_tc New Member
    12ish volts but not less than 11.5 V
  8. Apr 11, 2024 at 7:23 AM
    SDHNTR
    I'm looking for exact readings on a multimeter, not the dash gauge. There's a big difference between 12.1 and 12.5V, yet anything in that range could appear as "12 ish".
  9. Apr 11, 2024 at 9:03 AM
    DRP
    DRP Old Member
    Dave
    I got 12.2 right at the battery about a month ago. Truck sat overnight and ambient temp was 40 degrees F.
  10. Apr 11, 2024 at 9:31 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Did you try disconnecting the battery and reconnecting? My dash volt gauge bounced wildly after my battery got wet. It wasn’t a slow fluctuation with idle, it bounced like crazy at all times. I removed both terminals, sanded the posts, applied terminal grease and the bouncing needle went away.
  11. Apr 11, 2024 at 9:42 AM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    If it doesn't start again I would have it towed to the dealer or a different dealer if possible and tell them not to give the truck back until the problem is fixed or plan on giving you a different new truck. After what these things cost there should not be any issues such as this and their only excuse is we can't find the problem. It is definitely some kind of electrical issue with it being so sporadic for you. I hope that you get this issue resolved.
    Leo's first and Lifer like this.
  12. Apr 12, 2024 at 7:32 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    I have a 21 so I am guessing you don't want a reading from it? I have not started it today. I can measure the 08 too.....
  13. Apr 12, 2024 at 7:57 AM
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    My many years of experience has been about 12.6 if the battery is good as new.
    Lifer likes this.
  14. Apr 12, 2024 at 8:01 AM
    Jckdanls07
    Jckdanls07 We May Not Know Them All, BUT, We Owe Them All !!
    Keith
    Tampa Area
    2015 White Tundra SR5
    Should be around 12.5v ... The gravity of the acid usually dictates volts when cold... 1250-1260 gravity is ideal and that would read 12.5-12.6v... Voltage usually reads what the acid gravity is... Unless there is a bad cell.. then obviously voltage would read lower... Each cell is 2 volts ..
    pyoung62 likes this.
  15. Apr 12, 2024 at 9:01 AM
    SDHNTR
    Battery is consistently holding at 12.3v cold and after sitting a few days now. I don't think that's the problem. New theory is key fob is losing connectivity. Will start a new thread about that.
  16. Apr 12, 2024 at 10:53 AM
    xc_tc
    xc_tc New Member
    Did you check starting in neutral? Or check the shifter?
  17. Apr 12, 2024 at 12:33 PM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    The voltmeter fluctuations are something that is perfectly normal and most likely not noticed until issues popped up, now he's paying more attention to it. The alternator and charging system voltage and charge rates are controlled by the engine control module while it monitors battery overall state of charge percentage. The battery chemistry is not conventional flooded rather enhanced flooded battery technology which uses uses slightly different charge methods also operates at a lower average state of charge percentage than conventional flooded battery, hense suited best for auto stop systems.
    Mattedfred likes this.
  18. Apr 15, 2024 at 11:07 AM
    SDHNTR
    Failure to start again today. On tow truck back to different dealer. What a joke.
    Leo's first likes this.
  19. Apr 15, 2024 at 12:06 PM
    #49
    Jckdanls07
    Keith
    Tampa Area
    OK.. Lets hope we can get to the bottom of this ...
  20. Apr 15, 2024 at 12:44 PM
    #50
    SDHNTR
    Well the truck arrived at the dealer, and started right up. Ugggghhhhh!
    They have been advised to check the neutral safety switch. Stay tuned.
  21. Apr 15, 2024 at 1:01 PM
    #51
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Sounds like the typical "Can't reproduce the problem, come get your truck" response is coming.
    Hope I'm wrong, but I have about as much faith in dealerships as I do with our current POTUS.
  22. Apr 15, 2024 at 3:48 PM
    #52
    SDHNTR
    Yep. And true to form, as soon as the tow truck arrived at the dealer, it fires right up and started normally. Fortunately, this time he has extensive video of it not starting. They have supposedly elevated his case, whatever that means.
    ZappBrannigan likes this.
  23. Apr 17, 2024 at 8:20 AM
    #53
    SDHNTR
    Well, we finally have an answer.. So as you see above the truck went back a second time after it wouldn't start, and it fired right up at the dealer like normal. Toyota Customer Care wanted him to take it back to the same dealer that originally looked at it and wasn't helpful. So while I mistakenly said he went to a different dealer, he did not, per Toyota's directive. Again, the dealership said, there's nothing wrong with your truck, come pick it up. You're crazy, this truck is fine. Yet he had video of the truck not starting and him doing all the normal steps to start it, including clear video of the dash NOT showing the key icon necessary for start up. They said the video was invalid and didn't prove anything because there was no footage of the actual key shown. COME ON. They were accusatorial. Insane! Like my brother, or any human being, enjoys dealing with new vehicle problems and makes sport of taking perfectly fine vehicle back to the dealership multiple times. As if he had nothing better to do. It was obvious they just wanted him to go away.
    He essentially refused to take the truck back without further investigation. Toyota Customer Care got involved. This time they got their Field Specialist Team involved. Whatever that means. And these guys were able to produce a report of every single start attempt ever logged by the vehicle. Sure enough, there were multiple, dozens, of failed starts. And get this! Due to "Key signal interference. Electrical waves present." Apparently there are electrical waves present in the atmosphere of my brother's neighborhood that interrupt the key signal! Good lord. Can't make this up!
    So this is problematic on two levels:
    1: Why did it take multiple attempts at the dealership and such assertive insistence to get the report that ultimately found the problem? If this report was available all along, why wasn't it run in the first place, saving everyone time and frustration? Because it costs Toyota or the local dealer additional service time/money and they want to see if you'll just give up easily and go away first? Or was the local dealer just unwilling to make the extra effort? Either way, a complaint is being filed.
    and...
    2. Now what? He can't own a truck that won't start in his own driveway/neighborhood. Is there a manual override? He held the fob up to the start button like a dead fob would require and that didn't work. Which goes to show that all this fancy tech is fine when it works, but we are out teching these things to the point of failure, without back up systems to use when the tech fails. He is still working with Toyota (National CS, not the dealer) for other options. It's apparently something they haven't dealt with before.
  24. Apr 17, 2024 at 8:46 AM
    #54
    HLR_NM
    HLR_NM New Member
    Harry
    That’s one of the most ludicrous explanations for a no-start condition I’ve ever heard. Did they sweep the neighborhood with an RF scanner? :rofl:
    easy enough to test the hypothesis - wrap the fob in foil except the tip (yeah I went there) and see if it consistently starts touching the tip to the button (yeah I went there again)
    something tells me the engineering team assigned to your problem isn’t familiar with Occam’s razor.
    Again, did anyone check the battery and NSS?
    Polo08816 and Leo's first like this.
  25. Apr 17, 2024 at 8:46 AM
    #55
    Matt2015Tundra
    2023 1794 CrewMax
    Damn, that's gotta be frustrating. A quick search found this article that may be helpful.
    https://www.mightyautoparts.com/wp-content/uploads/2022/03/Tech-Tip-20630.pdf
    Bottom line, it sounds like you need to find and eliminate the source of the radio frequency interference at your brother's house.
    Tundrastruck91 likes this.
  26. Apr 17, 2024 at 9:02 AM
    #56
    kramerv
    kramerv New Member
    So essentially anyone with a Toyota that sets foot in a place where interference can occur it's f@cked? This sounds like a Toyota problem not a "you" problem.
    Polo08816 likes this.
  27. Apr 17, 2024 at 9:04 AM
    #57
    Lifer
    Lifer New Member
    Vince
    Wow. That is a hard sell to me. Unreal
  28. Apr 17, 2024 at 9:14 AM
    #58
    SDHNTR
    What if it's from a neighbor's house? Or city powerlines/utilities?
  29. Apr 17, 2024 at 9:17 AM
    #59
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
  30. Apr 17, 2024 at 9:18 AM
    #60
    SDHNTR
    Yes battery was checked and test results shown, all good. NSS was supposedly checked. As for the "Key RF Signal Interference. RF Response not received (electrical waves present)." I'm quoting directly off the Vehicle Diagnostic Report from Toyota.
    Tundrastruck91 and Leo's first like this.
