Broken transmission mount.
Discussion in '2nd Gen Tundras (2007-2013)' started by Kn4x2, Feb 26, 2020.
  1. Feb 26, 2020 at 3:23 PM
    Kn4x2
    Kn4x2 [OP] Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    See the attached photo, circled is the area that is broken or separated.
    How critical is that portion of the mount and could it the cause of a shudder I feel around 45mph?
    Thank you for any insight
  2. Feb 26, 2020 at 7:48 PM
    Kn4x2
    2010 DC 2WD
    Bueller......Bueller......
  3. Feb 27, 2020 at 12:41 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I'm wondering if the shutter caused the break or vice versa. Sure does not look very sturdy.
    Weld it or replace it to find out for sure.
    15whtrd likes this.
  4. Feb 27, 2020 at 1:33 PM
    Kn4x2
    2010 DC 2WD
    Hopefully being replaced on Monday. If not, then I will do it myself.
    fixnfly likes this.
  5. Feb 27, 2020 at 1:49 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Any part of any motor, trans or other suspension component is Critical. Doing the right thing to get it fixed. When mounts get hard, worn or otherwise compromised the job they're supposed to do transfers to the surrounding components, which of course are not designed for that abuse, thats the mounts job, hence more parts start to fail, uggg....
    Many let these type of things go on and on, until the warnings are over from the parts....
    ColoradoTJ, 15whtrd and fixnfly like this.
  6. Feb 27, 2020 at 2:24 PM
    15whtrd
    15whtrd Mr. Blonde
    Are you lifted? I would definitely get that fixed. Shouldn’t be a hard job.
  7. Feb 27, 2020 at 2:48 PM
    Kn4x2
    2010 DC 2WD
    No lift. Should be able to jack trans up with floor jack with a piece of 2x4 under pan, correct?
  8. Mar 8, 2020 at 10:47 AM
    Kn4x2
    2010 DC 2WD
    Completed transmission mount replacement this morning (easy 30 minute job on the driveway, dealer quoted $350:eek2:). Smoothed out the ride quite a bit. If you have vibrations or shudder its worth it to replace.
    ColoradoTJ and Wynnded like this.
