Broken Tailgate handle
Discussion in '1st Gen Tundras (2000-2006)' started by ladywolf, Jun 9, 2018.
  1. Jun 9, 2018 at 7:30 PM
    ladywolf
    ladywolf [OP] New Member
    Kristen
    Clarksville TN
    05 S45 4x4 Double cab Jade Green Mica
    2.5" eibach coils/springs
    Got around to fixing that today. Got the new part in Thursday from Camelback. A 10mm socket, a small flathead screwdriver, and a T30 Torx was all that was needed for this project.
    You can see that the little chintzy plastic clip for one of the 2 rods had finally given up the ghost after 13 years. Not bad for an OEM handle and abuse!
    New one all nice and neat and installed. function test completed. happily put back together and then proceeded to hit the local home improvement store for landscaping stuff for my yard.
    I spent the 90 bucks for an OEM one through Camelback Toyota, instead of going the cheapy route through Rock Auto. With as much as I use my tailgate, and knowing how Toyota's dont like aftermarket stuff (and the fact that rock auto in this case couldnt guarantee which manufacturer or the specs on which one would be sent), I ponied up the money and called it money well spent.
  2. Jun 9, 2018 at 7:51 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    For another $95.00 you can add the pop and lock auto tailgate lock. Pretty damn easy to install
    because_wumbo-truck and 15whtrd like this.
  3. Jun 9, 2018 at 7:53 PM
  4. Jun 9, 2018 at 8:06 PM
    garnaz
    garnaz New Member
    Just the rod clips broke. Was the outer pull broken also? That's what broke on mine. Haven't changed it yet. Don't use the bed as much as the 4x4.
  5. Jun 10, 2018 at 5:31 AM
    ladywolf
    Kristen
    Clarksville TN
    I broke the handle before I realized the rod clip had busted. Joys of it being early in the morning and trying to load stuff up for a trail ride. No matter what I had to buy a new handle.
  6. Jun 10, 2018 at 8:45 AM
    Professional Hand Model
    Hand Protectors
    Nice job. Did mine a few years back with The Rock Auto replacement. Musta got lucky as its pretty solid and holding fine. Pretty easy swap out.
    ladywolf[OP] likes this.
  7. Jul 21, 2018 at 7:48 PM
    Meyatchy
    Meyatchy New Member
    2006 tundra access cab
    Same thing happened to mine...handle broke, bought the parts and found out the clip inside broke before i owned it and he fixed it with a twistie tie of all things...guess it was gonna have to be fixed anywau...who even does that lol
  8. Jul 22, 2018 at 6:11 AM
    ladywolf
    Kristen
    Clarksville TN
    someone who's resourceful and thrifty!!
  9. Jul 22, 2018 at 9:44 AM
    Meyatchy
    Meyatchy New Member
    A 2 cent plastic ziptie would have better than a 1 cent bread loaf twistie tie, lol...who knows, might have been a real pinch and used what was handy
    Darkness likes this.
  10. Jul 23, 2018 at 1:26 AM
    Dragracingdan
    Dragracingdan New Member
    2003 Tundra Limited
    Smart fixing with OEM. Mine broke, fixed with a cheapy one and works only if you pull hard to one side of the handle. Have since bought the OEM... lesson learned
    fudozen likes this.
  11. Aug 29, 2018 at 3:22 AM
    Joel
    Joel New Member
    Joel
    First gen tundra sr5’
    Tailgate handle, and that cheesey fuel door are the suckingest thing on the first gen. Otherwise, a great truck.
  12. Aug 29, 2018 at 6:53 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I beg to differ. The pinch weld in the front fender is the suckiest. It doesn't like tires bigger than 32" :D
    Good job Ladywolf.
  13. Aug 29, 2018 at 9:23 AM
    Joel
    Joel New Member
    Joel
    Buy a bigger truck
  14. Aug 29, 2018 at 11:48 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    No way, I have a sawzall and a grinder :cool::sawzall:
    Casper421 likes this.
