Broken retainer clip
Discussion in '1st Gen Tundras (2000-2006)' started by Andrew02, Jul 15, 2023.
  1. Jul 15, 2023 at 7:52 AM
    Andrew02
    Andrew02 [OP] New Member
    2002 tundra rclb
    Broke this while replacing the timing belt and having trouble finding a replacement. It holds a plug on the wiring harness against the timing cover.IMG_1376.jpgIMG_1377.jpg
  2. Jul 15, 2023 at 10:10 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    82711-430202
  3. Jul 15, 2023 at 10:19 AM
    bfunke
    South Carolina
    fishordie likes this.
  4. Jul 15, 2023 at 10:43 AM
    Andrew02
    2002 tundra rclb
    Is that the part number for the original part? I tried looking it up and had no luck
  5. Jul 15, 2023 at 1:17 PM
    bfunke
    South Carolina
  6. Jul 15, 2023 at 1:54 PM
    https://www.tundras.com/threads/howto-use-the-toyota-parts-system-to-find-order-parts.113808/
    Use the site linked in first few bullets of that sticky thread ^^. Put your VIN into search box. Click 'Engine, fuel system and tools' section. Click 'Timing gear cover & rear end plate'. Click, 'Open full size scheme' ... Is it not shown in the diagram? (It's possible it's in the 'Electrics' -> 'Wiring & Clamp' section instead of the 'Engine...' section)
    Sorry just trying to teach you to fish here... In the Electrical section they show virtually all the wiring connectors and brackets used in the truck which aren't shown in other sections. Like, here's all of the brackets and some wiring clamps for my '06 with all the part numbers below its image...
    teereqs likes this.
  7. Jul 15, 2023 at 2:10 PM
    bfunke
    South Carolina
    This is what I got from Toyota. It’s different than what was on my 2000 which is exactly what your photo shows. I had temporarily secured the harness to the broken clip with two tiny zip ties behind the clip
    shifty` and BubbaW like this.
